yeah, those maximas are pretty quick, and expeditions are slow - Mustang Evolution
Old 10-04-2005, 08:38 AM   #1
04 maxima.........bone stock
5-speed auto w/ manual shifting thingy
vs
04 mustang.......x-cal2 (street setting), cai, 25% udp
4-speed auto
results:
0-100 him by 1 1/2 - 2 cars on me.....i took him outta the hole, his front tire was at my back tire. by the end of first he was back even with me and by the end of second my front tire was a little in front of his back tire...........when i shifted into third it looked liked i stopped racing him, he just kinda slowly pulled away and there was nothing i could do he put the 1 1/2 - 2 cars on me from ~80-100
then we kinda messed around on the way back home and ran from 80-115 with me about 1 car ahead of him and he couldnt pass me ......all he did was reel me in and stay even with me until he let up he's not one to mess with someone either so i'm wondering if i actually stuck with him up higher, maybe 80-100 was the only range he could put cars on me :chin:
okay, well we got to a red light and an expedition saw us playin, so he decides to play as well and runs me....it had a stock 5.4 V8
0-80 i won by a wide margin .........i really couldnt tell ya how many cars i won by. he stuck with me from 0-15, but after that, he was falling back, and even quicker once i hit 2nd
Kyle is offline   Reply With Quote
Old 10-04-2005, 10:43 AM   #2
Monkey's Avatar
Re: yeah, those maximas are pretty quick, and expeditions are slow
maximas have 260bhp.
Old 10-04-2005, 03:41 PM   #3
:yup:
and he puts down about 240 or so............and had better gearing........why didnt ford give me a 5-speed auto
Old 10-04-2005, 06:32 PM   #4
the older 205hp maximas run 16.0s~ or a tad better
Old 10-04-2005, 07:02 PM   #5
i wish he had one of those.............i've beaten those kinds by about 2 cars from 60-90
Old 10-04-2005, 08:34 PM   #6
Thomas91169's Avatar
Originally Posted by 04stang
:yup:
nah, theres more loss than that. if hes making 260 crank, hed be about 200 wheels. no car loses only 3-5% in the drivetrain, its at least 15%, even more so for autos.
-Thomas-
Old 10-04-2005, 08:35 PM   #7
yeah but its fwd though.......doesnt that make a difference
and if he was only puttin down 200, before my programmer, i put down 183, so just say i gain 10rwhp, then i am only ~7 off of him, and i am a few hundred lbs lighter than him.........
Old 10-04-2005, 08:46 PM   #8
yes but its a different kind of power he makes. his is more tuned for top end, whereas you just have power all over.
fwd drivetrain loss is just under rwd. basically its like this
FWD 5spd - 15% loss
RWD 5spd - 17-18% loss(take into effect the rotational mass of the driveshaft)
FWD Auto - 20% loss
AWD 5spd - 20% loss
RWD Auto - 20% loss
AWD Auto - 25% loss
-Thomas-
Old 10-04-2005, 08:53 PM   #9
hmm, so we have the same drivetrain loss...........but i'm lighter and he has better gearing.....so i guess the fact that he has better gearing is what caused him to win b/c he didnt pull until i shifted into 3rd
Old 10-05-2005, 04:43 PM   #10
dark's Avatar
Send a message via AIM to dark Send a message via Yahoo to dark
04 maximas are front wheel drive.. so are the 05s
Originally Posted by nissan
Type: V6
Displacement cu in : 214
Power bhp at RPM: 265/ 5800
Torque lb-ft at RPM: 255/ 4400
Redline at RPM: 6600
Weight lb: 3436
so maximas have pretty decent specs
I don't own a mustang at the moment
dark is offline   Reply With Quote
Old 10-06-2005, 02:02 AM   #11
what gears do you have? im assuming stock 2.73's if youre auto.
most FWD cars have between 3.23-3.73 gearing. dodge neons run like 3.94 or something, and im pretty sure my gst's final was 3.73, if not a little higher.
and he has less than you in terms of driveline loss. FWD-15%, RWD AUTO-20%+. plus his engine is designed to run in the higher rpm's, is yours? i think those suckers redline at 6600, whats your redline? and do you even make enough power up there like he does to warrant going that high?
its where he makes the power as opposed to you on how he won.
-Thomas-
Old 10-06-2005, 03:48 PM   #12
Dark02Pony's Avatar
Send a message via AIM to Dark02Pony
i could be wrong but i thought both the 5spd and auto 99+ had 3.27
http://img.photobucket.com/albums/v6...rtandgrill.jpg
Operation: Evolutionization.......Member #3
Originally Posted by MonteCitan
Ford Motor Company = FoMoCo..
what does that make Honda Motor Company????
Originally Posted by Nicole
Mineral Gray is such a hott color. Much better then orange
Dark02Pony is offline   Reply With Quote
Old 10-06-2005, 04:26 PM   #13
stock gears on my car is 3.27s.......my 1-2 shift is at 6k and the 2-3 shift is at 5.5k..........and my dyno sheet does show me making good power to 5.5k rpms.......in 105* weather, i put down SAE 173.84rwhp/207.84rwtq.......of that, and looking at the sheet, at 5.5k rpms i am at ~170rwhp/~160rwtq.....the tq is on a steady decline after 4.75k rpms.......and keep in mind, this was 105* in the shop with 25% humidity
Old 10-07-2005, 06:45 PM   #14
street races do not matter at all lol beating him by two cars could be him winning by a full second vs you at the track so you cant go by that.
Old 10-07-2005, 06:53 PM   #15
Tbird232ci's Avatar
what makes the track different?
there is a starting light, a finish line, and a timer
youre both racing on the same surface...just like on the street, you generally launch off of a light, same on the street, but the difference is where do you determine that the race is over?
Old 10-07-2005, 08:53 PM   #16
AAAAAAAAAHHHHHHHHHHH I GIVE UP!!!!!!!!!
well the only difference i see is track prep...............but as far as your other points go.........................THANK YOU!!!!!!! i knew someone knew where i was coming from
Old 10-08-2005, 04:34 PM   #17
Dark02Pony's Avatar
im with you on this kyle . i know the track here ( englishtown ) prices keep going up, then they drop, up and drop, screw that..but i must admit i drive around the speed limit unless somebody wants to race and definitely dont race in traffic like the ricers do
Is the site slow to anyone else? PureVenom ME Site Help & Announcements 12 02-06-2008 09:46 AM
revs up quick, revs down slow....flywheel? tedness Pre-2005 V6 Mustang 1 07-31-2005 12:23 AM
yeah, so DHL is pretty much a worthless company. fast64 The Bar 19 03-29-2005 12:24 PM
pretty slow tonight Ken The Bar 18 04-22-2004 08:07 PM
01:28 PM
