Launchin a 6 - Mustang Evolution
Old 10-04-2005, 10:52 AM   #1
Send a message via AIM to SeadudeRXP
Launchin a 6
I have a stock 03 v6 manual, and I have been to the track already, my best time is a 15.8 @ 89. My launch technique now is basically slip the hell outta the clutch and come out of the hole at about 2 grand. My 60' time was a 2.34, which i know can be better. My question is if any of you guys know of a better technique to get my 60's down. Keeping in mind my tires suck ***, i swear they must have been soaked in WD-40 before they were put on my car. Any suggestions would be great.
SeadudeRXP is offline   Reply With Quote
Old 10-04-2005, 06:38 PM   #2
Re: Launchin a 6
hold it at 2500rpms to start, come off the clutch and get on the gas slow until the front has raised up then get into it hard. It takes practice and finding a sweet spot. With my lca lift bars i could launch amazingly... you may need to upgrade your lcas if your track sucks, or tires if you have the stock turds.
Old 10-06-2005, 10:38 AM   #3
Re: Launchin a 6
Aight that sounds good, hopefully i wont spin too bad, I'm goin to the track this friday so we will see what happens. Thanx
Old 10-07-2005, 08:57 AM   #4
slvr2000stang's Avatar
Re: Launchin a 6
You just need to experiment to see what works for you & the track you are at.
Custom Delk motor now DOA
2003 SVT Lightning #1059 of 4270
2000 Vert 4R70W
Only buy from vendors that test and stand behind their products
slvr2000stang is offline   Reply With Quote
Old 10-25-2005, 11:20 PM   #5
Send a message via AIM to tedness
Re: Launchin a 6
haha wait so is it at 2500 or 2000, because u contradicted urself from one post to another, mang.
tedness is offline   Reply With Quote
Old 10-29-2005, 08:57 PM   #6
Re: Launchin a 6
Well last night was a test and tune and I took your advice about the launches, and it worked out pretty well. I need some more practice at it to get it down but I definitely noticed some difference and a hell of a lot less wheel spin. But on the plus side I turned out a 15.5 @ 90.28 which is a .3 improvement. And that was with a ****ty 2.4 60', so i'm hopin with a good 60' I can hit a 15.3, thats the best I've heard you can get outta a v6 thats bone stock.
Old 10-29-2005, 10:48 PM   #7
Re: Launchin a 6
man that little bit of power boost the 3.9's got really is noticable.
Old 10-30-2005, 01:51 AM   #8
Thomas91169's Avatar
Re: Launchin a 6
im pretty sure any boost in performance from 3.8 to 3.9 was an ego boost.
and seadude what mods do you have, or are you truly stock as stock can be.
-Thomas-
Old 10-30-2005, 03:10 PM   #9
maaudio81's Avatar
Send a message via AIM to maaudio81 Send a message via Yahoo to maaudio81
Re: Launchin a 6
i run an auto trans and the stock tires do suck i even spin off the line but when it hooks i can barkem into 2nd gear
http://i5.photobucket.com/albums/y15.../AUDIOSIG1.jpg
mods
diablo programmer
diablo chip
true dual flowmaster exhuast
CAI
headmen headers (shorties)
leather seats
5% window tint all around
97 cobra rear sway bar
97 cobra strut tower brace
future mods
5 spd swap
lambo doors
ud pulleys
performance intake
dual turbo kit
70 mm throtle body
75 mm maf sensor
1/4 mile time 14.42@98.9 mph
maaudio81 is offline   Reply With Quote
Old 10-31-2005, 06:39 AM   #10
Re: Launchin a 6
I'm as stock as stock can be, so I'm relatively happy with the numbers I'm puttin down, aside from the whole 60' issue.
Old 10-31-2005, 06:46 AM   #11
Re: Launchin a 6
Getting a good 60' with the stock rear-end will be difficult.
You mph is good, so if you can get a decent launch the times will be there.
2000 Vert 4R70W
Old 11-02-2005, 04:24 PM   #12
maaudio81's Avatar
Re: Launchin a 6
with a 3.73 posi would that help my 60 ft times at all?
mods
diablo programmer
diablo chip
CAI
leather seats
future mods
5 spd swap
lambo doors
ud pulleys
performance intake
dual turbo kit
70 mm throtle body
75 mm maf sensor
Old 11-05-2005, 09:39 AM   #13
Re: Launchin a 6
Slipping the clutch to launch is a poor technique and really bad on your clutch .If you want better 60 ft. times you need to get better tires ,like some good drag radials so you can launch around 5000 , then you will see both your 60 ft times and ET times go much lower .Gears will help ,just make sure you put in a good t-loc and a 7.5 girdle that will help protect your rear end
from going South.
487.4 RWHP 464.8 RWTQ
11.584@124.58
Sponsored by
http://www.Delkperformance.com/
WWW.SUPERSIXMOTORSPORTS.COM
http://www.v6challenge.com
GT-Eater is offline   Reply With Quote
Old 11-10-2005, 11:49 AM   #14
wiarumas's Avatar
Re: Launchin a 6
yes. i would recommend gears+chip. the gears wont add any HP to your car, but will increase acceleration. 3.73 for manual, 4.10 for auto
Old 11-10-2005, 02:03 PM   #15
Re: Launchin a 6
I'm still trying to figure out how maaudio has a 14.42....that's not possible
Old 11-10-2005, 03:45 PM   #16
Re: Launchin a 6
2nd............2:
12:34 PM
