stock front brakes, cobra rears...bad? - Mustang Evolution
Go Back   Mustang Evolution > 4 Cylinder | V6 | Classic Mustangs > Pre-2005 V6 Mustang
Closed Thread
Old 10-05-2005, 02:03 PM   #1
tedness is unknown around these parts
Send a message via AIM to tedness
i was wondering this because i need to replace my rear everything. pads and rotors...
and wondered how it would affect my brake bias to just get the rears upgraded to cobra/bullitt spec?
tedness is offline
Old 10-05-2005, 04:05 PM   #2
STEVE is unknown around these parts
Re: stock front brakes, cobra rears...bad?
nah, you still have more pressure and a bigger swept area in the front
no problems
STEVE is offline
Old 10-05-2005, 08:44 PM   #3
19ClearCobra96's Avatar
19ClearCobra96 is unknown around these parts
Send a message via AIM to 19ClearCobra96 Send a message via MSN to 19ClearCobra96
are the cobra/bullit rear different, I know the front is?
19ClearCobra96 is offline
Old 10-06-2005, 07:44 AM   #4
Senior Member
Tbird232ci's Avatar
Tbird232ci is unknown around these parts
actually, i think he cobra brakes are 11" in the rear, ive heard 11.65", but im not sure
the fronts on your car are 11"
its best to do the front and rear conversion, or just the front in one shot, having the rear brakes being that size will usually cause a lot of nose dive under braking
Tbird232ci is offline
Old 10-07-2005, 01:59 AM   #5
i decided to wait and piece it all together as i can.
so far got some bullitt calipers from a friend for $75. working on getting everything else and gonna powdercoat it all red.
tedness is offline
Old 10-07-2005, 05:09 PM   #6
Danger Dude's Avatar
Danger Dude is unknown around these parts
The Cobra rear brake calipers are the same caliper except they use larger rotors. There is absolutely no benefit to swapping out rear calipers unless you like to waste money
Danger Dude is offline
Old 10-07-2005, 06:23 PM   #7
Terminator Owner
SpectorV is just getting started.
the cobra rear brakes are IDENTICAL to yours in all ways but the bracket that moves the caliper out farther to make it worth with the larger rotors... the calipers are the SAME so all you need is the brake bracket and your set. (alog with rotor)
SpectorV is offline
Closed Thread
BRAKES front & rear chris7869 Pre-2005 V6 Mustang 1 09-08-2007 07:16 PM
front brakes 96bluegt 1996-2004 Mustang GT 2 05-21-2007 08:20 PM
Stage 3 roush front OR keep 01 cobra front? SpectorV Mustang Audio & Video 16 11-27-2004 12:17 AM
Cobra Front Brakes, MM Rack Bushings, and PICTURES added... Rick0636 Pre-2005 V6 Mustang 32 03-29-2004 08:46 AM
Cobra front brakes, MM rack bushings, and Pics ADDED Rick0636 Pre-2005 V6 Mustang 8 03-28-2004 09:39 PM
04:13 AM
