Weird sound when turning? - Mustang Evolution
Old 11-15-2009, 02:31 PM   #1
SC_STEEDA's Avatar
I was coming back from church this morning and noticed that almost every time i turned that there was a weird sound coming from the rear. Its like something is scratching or scraping when i turn. any ideas of what this could possibly be?
2003 LAND ROVER DISCOVERY-These are amazing off-road vehicles to be stock!
2001 3.8L TOTALED
CAI; HELI-X Throttle Body Spacer; MOTOBLUE Pulley Kit 42%; Crank 5% Water; Harmonic Balancer; WIRES; EIBACH Sport Springs; FLOWMASTER Dual 40 Series turndowns!
"You want something. Go get it. Period. Don't ever let someone tell you... you can't do something."
SC_STEEDA is offline   Reply With Quote
Old 11-15-2009, 04:51 PM   #2
outlawfrog's Avatar
Re: Weird sound when turning?
Ummm....check the plastic cover inside the fenderwell.....it's possibly loose? Could even be a bad spring. I used to had an 87 thunder-chicken with a 5.0........One night I got on it, and heard one hell of a noise.....turned out to be a bad rear spring, and the fender came down and cut the tire.
1996 GT, 5-speed, Moonlight Blue, Opal Gray leather, Flowmaster Cat-Back exhaust (Delta 40 series), BBK cold air intake & 75mm TBI, Super Chips programmer.
Originally Posted by 67mustang97 View Post
outlawfrog is probably right
Originally Posted by outlawfrog View Post
I might pull an "osirisguy", and make that my new sig quote!
outlawfrog is offline   Reply With Quote
Old 11-16-2009, 04:16 AM   #3
Zebs5408's Avatar
also check for other things like a stick or anything else that could have flow in there! maybe its the bearing.......could be something grinding on the strut when you turn....are you hitting the brakes when you turn? could be something with them! Goodluck man if i find anything else it might could be ill keep throwing them to ya
04' mustang 3.9 40th Anniversary Edition- (V2 Vortech Supercharger, 38# injectors, 3.73 gears w/ T-lok, Predator Diablo, Mac cold air intake, Port & polished upper AND lower intake manifold, Mac Long Tube Headers, Mac o/r H pipe, flowmasters, 2.5 flowmaster tips)
03' Mustang GT (20" Cobra R's, 40 series Flowmasters)
Zebs5408 is offline   Reply With Quote
Old 11-16-2009, 07:03 AM   #4
could be the differential gears/tlok itself but check for any signs of wear first, also you can get a friend to listen while you turn in a parking lot to see if they can pick anything out, perhaps sway bar is loose?
Old 11-16-2009, 06:36 PM   #5
SC_STEEDA's Avatar
i dont think it would have to do with the gears cause I got a new clutch and gears last year.
I think it might be the bearing but i am going to check for debris tomorrow after i get out of class.
thanks for the suggestions and i will keep yall posted.
2001 3.8L TOTALED
Weird Grinding Sound? Gt.Vert 1996-2004 Mustang GT 2 01-14-2010 01:31 PM
squelll when turning right BRIAN 1996-2004 Mustang GT 6 04-17-2009 03:57 PM
how (if it could) make my auto sound to a manual sound MaKaVeLi 1996-2004 Mustang GT 18 10-18-2006 09:56 AM
No turning back now... Bane- Pictures and Videos 5 05-19-2006 07:36 AM
Ever since I bought my car I have had this weird sound under the hood! 03redfire cobra The Bar 31 07-11-2004 07:55 PM
10:00 PM
