3.8 swap - Mustang Evolution
Old 11-15-2009, 05:24 PM   #1
67mustang97's Avatar
Region: Vermont
3.8 swap
Has anyone done a 97' 3.8 to 99' 3.8 engine swap? It jumps from 150 to 190hp. What would I need? I think I would do the motor and 5spd. transmission at the same time. If I did the swap I think I would be ahead of the game when it came time for the SC. Or should I just swap heads and intake from the newer 3.8? If I take this route what else would I need? My current 3.8 has around 81k.
Old 11-15-2009, 08:26 PM   #2
Zebs5408's Avatar
Re: 3.8 swap
yea the 94-98 v6 really are slow cause they have single port heads, i would think getting a used set of heads (low miles), new gaskets, used lower & upper intake manifolds (port and polish them while there out) would be cheaper than a whole swap but im not 100% positive that you can swap it out, i mean its the same block so i wouldnt see why the hell not but if theres a reason not to one of the veterans or staff will be on here shortly to let you know and give the reason why, on the othere hand i have seen a 99-04 3.8 &3.9 v6s go for little as $400 bucks with only 60,000 miles on them, once again not sure about the transmission cause if you had to swap that out to then im sure it wouldnt be cheaper ......**** idk ..... SPECTOR ,SONICPONY,HERBSTANG, ONE YOUS GUYS HELLLPP LOL.....not tryin to blow sunshine up there *** but all 3 of them usually have really good advice! good luck man ill be checkin this one
04' mustang 3.9 40th Anniversary Edition- (V2 Vortech Supercharger, 38# injectors, 3.73 gears w/ T-lok, Predator Diablo, Mac cold air intake, Port & polished upper AND lower intake manifold, Mac Long Tube Headers, Mac o/r H pipe, flowmasters, 2.5 flowmaster tips)
03' Mustang GT (20" Cobra R's, 40 series Flowmasters)
Zebs5408 is offline   Reply With Quote
Old 11-15-2009, 10:51 PM   #3
Re: 3.8 swap
Yah Zebs put up some good information. In addition to what he said, you do have a few options.
You could do the single to split port swap. That'll put you around a 99+ 3.8/3.9 hp ratings.
If you have the time, patience, and funds the engine swap is possible. I'm guessing you don't need the car as a dd. As Zebs said, v6 engines are abundant and fairly cheap.
I would consider either the engine swap or at least some upper/lower intake/internals work if you plan to supercharge. At 81k, the engine may have issues after running boost. Hell, an engine with 5k miles could fail or suffer serious problems, any extra unintended stress is fully capable to be a pita.
4.6 swap to a 5.4 b's stang 2005-2010 Mustang GT 9 06-21-2010 09:26 PM
Possible V8 Swap? NeedSomeMods Pre-2005 V6 Mustang 5 05-18-2010 02:43 PM
4.6 - 5.4 swap bruyn 1996-2004 Mustang GT 19 01-21-2010 06:25 AM
5.8 swap ? Z-EATER 1979-1995 Mustang GT 1 05-19-2008 05:29 AM
t5 swap powerhungry966 Pre-2005 V6 Mustang 7 10-19-2005 08:18 PM
02:36 AM
