How much rwHP?? - Mustang Evolution
Old 10-14-2005, 08:15 AM   #1
How much rwHP??
List of Mods:
Ported and Polished Upper Intake
" '' Lower Intake
'' ''' Heads---BV heads + .600 lift 820 flow: 244@550 lift intake, 156@550 exhaust
1.73 Roller Rockers
'' ''' Throttle Body
CAI
Cam284/224 .519 lift 110 centerline
Long Tube Headers
Off Road H-pipe
Gt style Dual Exhaust
A tune from Justin
Thats all the parts I still have to put on my stang and I was just wondering how much rwHP you think I will be pumping out?? SHould I get some underdrive pullies?? How will the transmission handle this power?? Thanks
petrey10 is offline   Reply With Quote
Old 10-14-2005, 12:36 PM   #2
Monkey's Avatar
Re: How much rwHP??
what year car? what kind of tranny (auto, manual)? what are the specs on the cam?
underdrive pulleys = no. waste of money (ESPECIALLY on a 99+)
Old 10-14-2005, 02:48 PM   #3
I_luv_HP&trq's Avatar
Send a message via AIM to I_luv_HP&trq Send a message via MSN to I_luv_HP&trq
Re: How much rwHP??
out of that list the p&p intakes and heads along with the exhaust will be the most benneficial imo. also depends on the cam, you may lose low end hp and trq but get it in the higher range depending on the degree.... the guy at redline performance said i could net 10rwhp with an intake package.
if you're a 99+ i'd say you could be putting down 200 rwhp or more with a bad *** tune.:dunno:
are the heads aftermarket or are they just stock that have been p&p? if you have some big *** valves then that makes a difference too. hard to estimate without knowing the little details.
I_luv_HP&trq is offline   Reply With Quote
Old 10-14-2005, 05:16 PM   #4
Re: How much rwHP??
35-65rwhp/tq .... lol nice wide range for ya, need more info on all of it to get closer. How well ported, cam specs, what year car, what tranny, etc etc
Old 10-15-2005, 07:26 AM   #5
Re: How much rwHP??
its a 2000 V6 Automatic.....I also updated the head, cam, and rr's in my previous messege...thanks
Old 10-15-2005, 07:41 AM   #6
Re: How much rwHP??
i dont see motor builds that dont stroke their motor doing much over 225-235rwhp~ and you having an auto severly hurts your put put so you will be looking at another 6-7.5% loss in power over that~
Old 10-15-2005, 10:26 PM   #7
Monkey's Avatar
Re: How much rwHP??
145rwhp stock 99+ auto
+ mods
= 215rwhp auto
Old 10-16-2005, 06:52 PM   #8
slvr2000stang's Avatar
Re: How much rwHP??
Are you sure about this?? 284/224 ????
Custom Delk motor now DOA
2003 SVT Lightning #1059 of 4270
2000 Vert 4R70W
Only buy from vendors that test and stand behind their products
slvr2000stang is offline   Reply With Quote
Old 10-16-2005, 11:29 PM   #9
Re: How much rwHP??
http://i8.photobucket.com/albums/a24/petrey10/bn.jpg
thats how I took it...look at it for yourself...why what is wrong with that??
Old 10-23-2005, 03:56 PM   #10
RGR
Send a message via AIM to RGR
Re: How much rwHP??
284 is advertised duration, and 224 is the .050" duration...
Both are way big for an auto SPI car with stock runner intakes.
I assume you got your parts used???
Sell your cam to a single port guy and get a cam like Silver is getting...
If you can sell the cam I will spec you out one and you can get it direct
from Comp Cams. BV heads are usually overkill for most 3.8 builds
anyway, but you can work with them.
Originally Posted by Flex:
You are the true cam master dude...
RGR is offline   Reply With Quote
Old 10-24-2005, 04:54 PM   #11
Re: How much rwHP??
Hey RGR just for grins ,I am building a 4.3 stroker 9.5 C/R having custom 8mm valves made ,the valves will be 1.55 /1.94 stainless ,dual springs ,stud mounted rockers ,with pushrod guide plates the rockers are 1.70 What cam would you recommend ? this is in the neighborhood of what I'm thinking 226/238 112 lobe sep .58 lift on the intake .60 on the exhaust .
GT-Eater is offline   Reply With Quote
Old 10-25-2005, 10:03 AM   #12
RGR
Re: How much rwHP??
Sounds pretty close for a boosted application, I could not be more specific
w/o doing a cam form, and I would hope those big durations are being used
with a short runner upper like your SSX I like the lift ranges on the cam!
1 Question, why go to 8mm valves? You can get Manley race valves in those
sizes w/7mm stems, and there are also beehives available that will handle those
lifts and high RPM's also. BeeHives > Doubles, IMO.
Old 10-25-2005, 02:49 PM   #13
Re: How much rwHP??
Behives better ? I don't agree when you get a high
boosted application that boost is trying to push the valve open on top of the
of the high rpm that I will be turning at the trap I need a better spring rate
than beehive could provide the so I am going 8mm because that opens up a whole new world of spring choices .Plus I was told by comp I could not use 918's or 921's when using solid roller lifters.
Old 10-25-2005, 05:43 PM   #14
RGR
Re: How much rwHP??
There are only a couple of BH springs out there that can handle the
boost and RPM and I think you are saying that one of the ones I
thought of is the 921, so that only leaves the 1 other non-Comp spring.
I'd stick with what they say, but Keith Groves (@ COMP) indicated to me
they have solid roller-compatible beehives. That being said I'd use the
package that they are recommending. Sounds like a killer setup!
Which family of roller profiles are you using? I have a Comp catalog
and those solids are very appealing if one can use them and
apparently you can...
Old 10-25-2005, 05:59 PM   #15
Re: How much rwHP??
Actually I am getting the dual springs from their compeditor ,the cam and lifters from comp (Billet)
Old 10-25-2005, 06:02 PM   #16
Re: How much rwHP??
I guess you are refering to the Nascar Springs that they use for restrictor
plate engines ,they are 7mm too.
Old 10-25-2005, 06:24 PM   #17
RGR
Re: How much rwHP??
I believe so, KG said they can also run those to within .030"
of spring stack (bind) and get rock-solid valvetrain motion,
but then the springs are basically totally shot after the 5-600
mile races. I have no part #'s for those (Nascar) springs but
I bet they are really expensive!
Old 10-25-2005, 06:25 PM   #18
RGR
Re: How much rwHP??
PS: are you using the SSX upper on this new project?
Old 10-25-2005, 07:54 PM   #19
Re: How much rwHP??
Yeah It was on the old 3.8 .Going to run it on the new 4.3 stroker with a T-trim this time
Old 11-12-2005, 08:19 AM   #20
RGR
Re: How much rwHP??
I'd love to see some NA numbers on that hog
Especially on the new 4.3!
Any chance of that?
Old 11-12-2005, 09:53 AM   #21
Re: How much rwHP??
Any chance of that?
No I will have the new procharger F-1 on it when I go to dyno ,but you can fiqure about 280ish .N/A
487.4 RWHP 464.8 RWTQ
11.584@124.58
Sponsored by
http://www.Delkperformance.com/
WWW.SUPERSIXMOTORSPORTS.COM
http://www.v6challenge.com
Old 11-13-2005, 08:11 AM   #22
RGR
Re: How much rwHP??
...if not a bit more
Or maybe a bit less due to the lower CR.
What I'm interested in is the torque curve
it generates on the bigger engines. Should
be a narrower torque "band" due to shorter
and closer lengths (between long and short)
but the blower will fix all that. You might ask
the dyno op. if there is a quick way to test it
in NA mode...
Old 11-13-2005, 08:33 AM   #23
Send a message via AIM to white95v6
Re: How much rwHP??
well i could take off the blower belt. and do a N/A tune. but dang more work. and i am also kinda interested in N/A #s. but not that interested.
also i am kinda glad i had N/A #s from my car. and then also Turbo #s. i know i changed the intake and a few other small things.
The First and Only 9 Sec Production Based V6 Stang!!,First over 500rwhp,First and only over 600rwhp
60ft-1.42,1/8th mile-6.25@111mph,1/4 mile-9.83@136.65mph
Sponsored by:
WWW.DELKPERFORMANCE.COM
white95v6 is offline   Reply With Quote
Old 11-13-2005, 08:56 AM   #24
Re: How much rwHP??
Yeah considering we have to start from scratch again with this new blower
I think that would be a major time consuming ordeal .
11.584@124.58
Sponsored by
Old 11-13-2005, 08:59 AM   #25
Re: How much rwHP??
well it would not kill us. just take out alot of fuel. lol and put in alot of timing. make a pull. take out more fuel. make a pull take out more fuel. lol.
put blower belt on. take out timing. add as much fuel as we can.
Sponsored by:
Old 11-13-2005, 10:19 AM   #26
Re: How much rwHP??
can you guys help me with the specs of the cam I posted earlier in this discussion
Old 11-13-2005, 02:32 PM   #27
Re: How much rwHP??
it has too much duration for such a mild combo and not enough lift.
Sponsored by:
Old 11-13-2005, 04:51 PM   #28
Re: How much rwHP??
what is that going to do to my numbers??
Old 11-13-2005, 04:51 PM   #29
Re: How much rwHP??
my heads are BV heads with 820 flow so there will be a lot of air flowing thru
Old 11-13-2005, 05:49 PM   #30
Re: How much rwHP??
ok it will hurt some Low end tq. and make ok high rpm power. but over all its a bad cam for your set up.
and trust me your heads do not flow 820cfm.
Sponsored by:
Old 11-15-2005, 03:54 PM   #31
RGR
Re: How much rwHP??
I gotta go 100% w/Matt on this one, the cam is low on lift and
long on duration for most 3.8's and assuming you have a Single
Port, I'd suggest a rebuilt shortblock with higher compression
then the duration could work well. But still short on lift and the
advertised duration (284) is weak, as in too big. A 224 (@ .050")
cam with 273 to 279-ish advertised is much better, it will perform
much snappier on the bottom end. BV heads could use a 224 cam
but also need more lift since the heads continue to flow up to .600"
lift anyway. I'd like to see at least a 10:1 CR with a cam that size
and maybe more. A guy with an RPM setup similar to yours made
great HP/TQ with a 215* cam and a 10.5:1 CR using Ross forged pistons.
Matt did very well using a 218* cam pre-boost so the single port can
do well with smaller cams than a 224*. That size cam kinda calls for a
shortened runner upper, but probably not as short an SSX if you stay
NA. I'd probably use a 230* cam for that bad boy, and/or boost. It is
a very fine piece (the SSX) with the right combo of parts. Might be a
little wild for your setup.
Old 11-15-2005, 07:18 PM   #32
Re: How much rwHP??
blah. that little 218 cam was soo weak. lol. it realy needed a cam like i am currently putting in. it should perform real well.
Sponsored by:
Old 11-17-2005, 11:20 AM   #33
RGR
Re: How much rwHP??
OK, spill it Matt! At least let us know the intake duration
Old 11-17-2005, 04:09 PM   #34
Re: How much rwHP??
in NA mode...
Higher compression with this engine and much better flow with Bigger intake valves.
11.584@124.58
Sponsored by
Old 11-17-2005, 04:13 PM   #35
Re: How much rwHP??
Any chance of that?
The numbers would be fun to look at ,but the numbers would also be somewhat scewed because the cam will be set up for a high CFM blower ,not N/A.
11.584@124.58
Sponsored by
most rwhp on a stock 3.8 auto? tigerfan2771 Pre-2005 V6 Mustang 9 06-30-2008 03:28 PM
Want to know what kind of RWHP I'm getting robb1320 1996-2004 Mustang GT 5 02-11-2008 07:05 AM
what is my rwhp strike1980 Pre-2005 V6 Mustang 26 04-10-2007 12:32 PM
908 RWHP Cobra Zim Pictures and Videos 17 12-31-2006 04:29 PM
11:02 AM
