NO OIL PRESSURE - Mustang Evolution
Old 11-18-2009, 07:34 AM   #1
NO OIL PRESSURE
just replaced oil pump and timing cover i have no oil pressure need help
bmxrr1990 is offline   Reply With Quote
Old 11-18-2009, 07:41 AM   #2
Re: NO OIL PRESSURE
how are you checking the oil pressure? the stock pressure sender in the car is worthless~ and comes on at 6psi of pressure, if you are using an actual gauge then thats a different story.
Old 11-18-2009, 07:57 AM   #3
Re: NO OIL PRESSURE
it has horrible lifter chatter i tried to prime the system it is building pressure at all not squirting any oil out the filter houseing with the filter removed and the heads are getting no oil at all i have the coil disconnected so it wont start the engine this is getting annoying i read some where you got to put vasellene in the pump to build pressure on initial start up is it required
Old 11-18-2009, 01:13 PM   #4
Re: NO OIL PRESSURE
any one have any ideas on how to get this system to pump oil once again it makes no sence just put new timing cover and felpro metal gasket from napa and now no pressure
Old 11-19-2009, 07:29 AM   #5
OsirisGuy's Avatar
Re: NO OIL PRESSURE
Are you sure it's not the oil pump :dunno:
OsirisGuy is correct
OsirisGuy is right
2002 Mustang GT
Old 11-19-2009, 02:34 PM   #6
67mustang97's Avatar
Region: Vermont
Re: NO OIL PRESSURE
It does sound like a oil pump problem I'd make sure that the shaft isn't worn, and that it's installed properly.
Old 11-23-2009, 07:23 AM   #7
Re: NO OIL PRESSURE
ok i have good news i got the system primed took a little bit of enginutity to prime the system got whole bunch of hex rods and tacked them all together fitted it in to a drill and got it spinning for a little finnaly started to shoot out the lifters and yells of joy erupted thanks for brainstorming
bobby
Old 11-23-2009, 07:38 AM   #8
Re: NO OIL PRESSURE
hmm odd it took so much effort to get it primed, but glad its working. Keep en eye on it as you run it though to ensure the pressure is good
Old 11-23-2009, 03:41 PM   #9
Re: NO OIL PRESSURE
Ill make sure to keep an eye on it so far today it's had super high pressure which I am kinda happy about
Old 11-23-2009, 07:00 PM   #10
Region: Vermont
Re: NO OIL PRESSURE
Super high? To much can be a bad thing does your gauge ride in the the norm area?
Old 11-23-2009, 09:50 PM   #11
outlawfrog's Avatar
Re: NO OIL PRESSURE
Ok....that tells me what gauges I want in my new pod....was gonna go water and voltmeter....now I think it'll be water and oil psi
lol
1996 GT, 5-speed, Moonlight Blue, Opal Gray leather, Flowmaster Cat-Back exhaust (Delta 40 series), BBK cold air intake & 75mm TBI, Super Chips programmer.
Originally Posted by 67mustang97 View Post
outlawfrog is probably right
Originally Posted by outlawfrog View Post
I might pull an "osirisguy", and make that my new sig quote!
outlawfrog is offline   Reply With Quote
Old 11-23-2009, 10:04 PM   #12
Re: NO OIL PRESSURE
The way I see it oil psi is much like blood psi with out any both you and your car die sooner then later
Oil pressure gauge Scut95 1979-1995 Mustang GT 12 03-24-2008 07:08 AM
oil pressure help jesse4887 1979-1995 Mustang GT 25 06-01-2007 10:39 AM
Oil pressure going crazy Zim Pre-2005 V6 Mustang 9 11-17-2004 10:28 PM
10:34 AM
