what would i need... - Mustang Evolution
Old 10-15-2005, 07:02 AM   #1
dark's Avatar
Send a message via AIM to dark Send a message via Yahoo to dark
to build my own rear axle?
i found a 31 spline 8.8 diff on ebay, as well as 31 spline 5 lug axle shafts, 3.27 gears for same, and an aluminum rear diff cover. all for very decent prices
so what else would i need? differential housing i know, but any small parts or gaskets or anything?
thanks
I don't own a mustang at the moment
dark is offline   Reply With Quote
Old 10-15-2005, 07:46 AM   #2
Re: what would i need...
does it take a diff housing? (other than a stock 8.8) I dont think it does. I wouldnt buy used parts, probably better off with new 28 spline parts.
Old 10-15-2005, 07:46 AM   #3
unless you are putting down 300+ rwhp and tq with slicks 31 spline wont really be useful
Old 10-15-2005, 08:10 AM   #4
dark's Avatar
good points. i'll check and see if the auctions tell the part condition. and i know i don't have 300+ rwhp... yet
Old 10-15-2005, 09:27 AM   #5
i doubt you would even need it if you totaly went out on the 6 (i mean unless you pushed like massive power 500 or so rwhp~)
I know 28 spline 8.8s that take 400rwhp with out issue... better safe than sorry though.
Old 10-15-2005, 11:02 AM   #6
dark's Avatar
well, some day i hope to push 500rwhp in the 6. but those days are a couple years down the road still
i'll just get a normal 8.8
Old 10-15-2005, 11:03 AM   #7
you can find a used 8.8 that would work fine since its oem build. If you want 3.73s... thats more work just get it part by part, maybe a donnor rear end then gears and get it built.
Old 10-15-2005, 01:43 PM   #8
dark's Avatar
delk perf carries used rears. and i'm staying with 3.27s
Old 10-15-2005, 11:46 PM   #9
Tbird232ci's Avatar
boo, ditch the 3.27's and go 3.73's, in some cases youll actually gain milage because your engine isnt lugging at speeds
you can buy an 8.8 housing and carrier, buy some axles, then buy a rear end rebuild kit, that comes with all the bearings, seals, shims, and all that, but i warn you, a rear end is VERY touchy and needs to be done very accuratly, or your gears could bind, whine, wear out fast, or make that annoying hum type sound at only certain loads...like both of my thunderbirds do
Old 10-16-2005, 02:13 PM   #10
dark's Avatar
3.27 = good turbo gear
Old 10-16-2005, 03:13 PM   #11
3.55's i have heard work best
Old 10-16-2005, 05:44 PM   #12
dark's Avatar
well, matt tells me he has 3.55s and he tops out at 130... so he's thinkin about 3.27s
*shrugs* i just don't want to pay extra for a gear swap
Old 10-16-2005, 05:58 PM   #13
what are his tranny ratios thats a very low top speed for his car.
Old 10-17-2005, 06:56 AM   #14
dark's Avatar
no idea on his tranny gears. i know it's an auto and it has a 4200 tq'verter, but as for the tranny, you'd have to ask him
09:40 PM
