how do i mount tranny cooler - Mustang Evolution
Old 10-22-2005, 01:28 PM   #1
Send a message via AIM to charkelly9
i bought a hayden model #1401 tranny cooler.. is there already a write up for the install ? i ask because im unsure of where to mount it.. the directions say 1"from the fan and 6" from exhaust manifolds... im trying to find a play but it doesnt seem possible... any links or suggestions welcome, thanks
charkelly9 is offline   Reply With Quote
Old 10-22-2005, 10:52 PM   #2
Monkey's Avatar
Re: how do i mount tranny cooler
I mounted min in front of the radiator with straps they provided. But I bought the B&M from steeda.com
Old 10-24-2005, 06:35 AM   #3
slvr2000stang's Avatar
Mine is also in front of the rad on the drivers side, but I made full length straps to mount it on/with.
Custom Delk motor now DOA
2003 SVT Lightning #1059 of 4270
2000 Vert 4R70W
Only buy from vendors that test and stand behind their products
slvr2000stang is offline   Reply With Quote
Old 10-24-2005, 01:48 PM   #4
Bane-'s Avatar
dont have a clue...my truck has one stock and its mounted infront of the radiator about mid level towards the pass. side.
Old 10-24-2005, 03:33 PM   #5
Monkey's Avatar
It has to do with where your tranny lines run into your radiator. Mount it on that side. Since the mustang's are on the driver side, they will usually mount them there to keep the extension hoses short.
tranny cooler Kyle Pre-2005 V6 Mustang 18 08-18-2007 08:56 PM
tranny cooler STEVE Pre-2005 V6 Mustang 10 07-10-2004 08:30 PM
Tranny Cooler is in Brent Pre-2005 V6 Mustang 16 06-22-2004 04:06 PM
tranny cooler?? Falcon Pre-2005 V6 Mustang 11 11-17-2003 06:51 AM
08:56 PM
