any 3.37 gears or 8.8 rear for sale - Mustang Evolution
Old 10-25-2005, 07:25 PM   #1
does any one have hook up or know anyone that sells these parts
i'd really appreciate it
thanks
i have a 2000 v6 manual stang
tim11 is offline   Reply With Quote
Old 10-25-2005, 08:12 PM   #2
DarkShadow's Avatar
Send a message via AIM to DarkShadow
Re: any 3.37 gears or 8.8 rear for sale
I know this isn't what your asking for but I'd really recommend forgetting the 8.8 and get a Detroit True Trac T-lock for the 7.5, it'll be stronger than an 8.8 and cost less.
DarkShadow is offline   Reply With Quote
Old 10-25-2005, 08:31 PM   #3
it will be stronger how much does it cost and will my car still be right wheel only or does the Detroit True Trac-lok make them both burn out
Old 10-25-2005, 08:38 PM   #4
Kiljosh's Avatar
How can a 7.5 be stronger than an 8.8 by adding only a truetrac?
Old 10-25-2005, 08:40 PM   #5
Old 10-25-2005, 08:55 PM   #6
DarkShadow's Avatar
The weekness in rear ends is the differential. How often have you heard of the axles themselves breaking, it happens but not very often.
http://3.8mustang.com/forum/showthread.php?t=131325
For more info, do a search for it on 3.8mustang.com.
Old 10-25-2005, 09:40 PM   #7
Meh
Old 10-25-2005, 09:58 PM   #8
Monkey's Avatar
Why do you want to put a locker in your car???? I am sure he wants to take this on the road as a daily driver. A locker is terrible idea for a daily driven car.
And it's the spider gears that break most often. However, it can break the pinion gear and warp the pumpkin too if you have some power. It all depends on what he wants to do w/ the car. I know when I was in the 13s, I needed an 8.8. But I also had an auto with 4.10s, torque converter, shift kit and slicks to put it down to the ground. And I would spray nitrous off the line. Fun times and 1.7-1.8 60' times too
Old 10-25-2005, 10:03 PM   #9
Your spider gears are what break, and your spider gears are still 7.5" (As Monkey has said)
Old 10-25-2005, 10:17 PM   #10
DarkShadow's Avatar
Sorry I keep using the wrong terminology, it's an LSD, not a locker. Just puts power to both wheels, but it's the strongest you can buy regardless of whether you believe it's stronger tha the 8.8 or not. Read the thread for arguements on both sides and decide for yourself.
Old 10-25-2005, 10:20 PM   #11
The diff. may just be stronger but the diff. is not the main thing breaking in the 7.5. The spyder gears are usually the first thing to go.
Old 10-25-2005, 10:33 PM   #12
Kiljosh's Avatar
It has been proven that the 7.5 can take a good amount of punishment, but if your going to put posi in your 7.5 and your trully worried about strength, an 8.8 will always be stronger.
I think the 8.8 and the 7.5 use the same axles too right? 28 spline?
Old 10-25-2005, 10:38 PM   #13
I_luv_HP&trq's Avatar
Send a message via AIM to I_luv_HP&trq Send a message via MSN to I_luv_HP&trq
^yea what's the deal here? i thought someone mentioned on another thread the 7.5 can support up to 300 hp.
and what if you want a stronger *** but not the bigger gears?
99 Cobra: flowmasters, 18x9.5 cobra R's, soon to be tuned and geared. daily driver
99 V6:in avatar, Mac Cai, true duals/flowmaster 40's ,UDP, custom tuned, bullitt suspension 18" wheels...taken by mother nature
I_luv_HP&trq is offline   Reply With Quote
Old 10-25-2005, 10:42 PM   #14
Kiljosh's Avatar
The 7.5 can support atleast 250 maybe more. When you have slicks and try to hook up is when they start to break, i.e. the spider gears strip/explode.
Old 10-25-2005, 10:44 PM   #15
It's be proven to break at 190hp and been proven to break at 300rwhp
Old 10-25-2005, 10:44 PM   #16
Then buy a GT rear end those have 3.27's in them as well.
Old 10-25-2005, 10:46 PM   #17
look at the design of the detroit trutrac then say that its spyder gears break. lol
Old 10-25-2005, 10:51 PM   #18
Kiljosh's Avatar
Wait what. What do you mean? That the line is blurry as to when they will break?
Old 10-25-2005, 10:52 PM   #19
Exactly. SpectorV broke his with just boltons at the track.
Old 10-25-2005, 10:53 PM   #20
Kiljosh's Avatar
O snap, well no ****.
Well that settles it. Bye an 8.8.
Old 10-26-2005, 12:15 PM   #21
DarkShadow's Avatar
Exactly what I'm saying! That thing is incredible, and at $354 on that site a real deal.
Old 10-26-2005, 12:27 PM   #22
Monkey's Avatar
I broke a 7.5 with 140rwhp. I just had bolt-ons.
You can say that adding that posi will make it stronger. It will. But an 8.8 with a posi will still hold more abuse than a 7.5. If he's spending $354 for the posi + ~$200 for gears + $200+ for install, then he can buy an 8.8 for $600 with the gears already set that he wants and bolt it on himself. I'll let you figure out which is cheaper
Even though I don't have a mustang anymore, I still know a thing or two about:
nitrous
drivetrain
engine
turbo
suspension
I helped write the HUGE mega thread on gear swaps over at 3.8 since you seem to be using that as a reference
Old 10-26-2005, 12:32 PM   #23
Exactly
Old 10-26-2005, 01:24 PM   #24
DarkShadow's Avatar
The Detroit includes the gears.
Old 10-26-2005, 01:27 PM   #25
Your still spending close to 600 dollars to beef up a weak rear end.
You can buy a brand new 8.8 for 800 dollars with 3.73 gears in it.
I bought my 8.8 for 275 dollars with 4.10s in it.
I just do not see the point of beefing up a 7.5 rear end when for just a couple hundred more bucks you can get a stout 8.8 that is tried and true.
Old 10-26-2005, 01:57 PM   #26
Danger Dude's Avatar
Here is the deal 8.8 and 7.5 use the same 28 spline axles. They do go bad from time to time. Actually the spiders gears are not what go bad first. It is the clutch packs that wear and that causes the spiders to receed away from the other spider gears and the teeth get ground from contacting the tips of the gears. The 7.5 is a pretty beefy diff but the 8.8 is beefier. I have also seen many 8.8's at the track on close to stock GT's break. If you are not the first owner you just dont know how much the diff is abused. The 7.5 TLok is much beefier than the stock open diff. If you can get a good price on a 8.8 go for it. But I would not waste my money on a high dollar 7.5 LSD when the FMS TLoK does the job well.
Old 10-26-2005, 02:08 PM   #27
DarkShadow's Avatar
I agree Danger dude. Everyone agrees that both axles are temperamental as far as breaking is concerned. Now, if some people had actually read what the components of the Detroit LSD are (like 232stang obviously did), they would know it doesn't even use spyder gears. Yes, it's and expensive one, but on the site shown above, it's comparatively cheap when compared to the $500 shown elsewhere.
Old 10-26-2005, 03:45 PM   #28
the detroit true trac does not use clutches, its not like a regular for t-lok. look at the design
Old 10-26-2005, 03:46 PM   #29
nope its just the diff unit. you still need to buy gears for it. the ring and pinion are different than the gears inside the detroit truetrac
Old 10-26-2005, 04:50 PM   #30
stock 99 up v6's and Gts all have 3.27 gears stock, dont upgrade your rear. www.speedconcepts.net used to carry complete rear ends, minus brakes and axles(easy to use off your stock rear end, those parts are interhcangable)
the weak part of the 7.5 is the spider gears in the rear end, then the gears themselves.
Old 10-26-2005, 04:57 PM   #31
No it is not the spider gears that are the problem they are not weak it is worn clutch packs. The clutch pack force all the spider gears to contact evenly. When the clutch packs wear they cause the spider gears to receed and the gears contact at the tip of the gear teeth instead of the side surface area of the gear teeth. Any gear will wear out if they dont contact properly. I know I have recently rebuilt 3 Tloks and they all had the same problem. So lets stop blaming the gears. It is the Clutch packs fault BY GOD
Old 10-26-2005, 05:37 PM   #32
DarkShadow's Avatar
And the Detroit uses neither.
Old 10-26-2005, 06:13 PM   #33
so wait so what your telling me is to not get an upgrade don't get the 8.8 rear
i have a 2000 v6 manual about 105000 miles
Old 10-26-2005, 07:00 PM   #34
I will have to correct you a Detroit LSD has spider gears a Locker does not but a D Locker is not a wise choice for street cars unless you like to drag the outside tire on slow turns
Old 10-26-2005, 07:39 PM   #35
the Detroit true trac is an lsd.
Rear Gears sledgehammer Pre-2005 V6 Mustang 16 12-06-2007 07:19 AM
3:73 gears and t-lock for 7.5 rear end for sale laf7773 Mustang Parts for Sale and Wanted 8 06-07-2006 10:52 AM
rear gears tim11 Pre-2005 V6 Mustang 45 11-12-2005 01:40 AM
Rear Gears TBone Pre-2005 V6 Mustang 16 05-04-2004 10:10 PM
Rear End gears? RedDragonV6 Pre-2005 V6 Mustang 3 03-18-2004 03:12 PM
05:37 PM
