Real quick question about brakes - Mustang Evolution
Old 10-28-2005, 07:32 AM   #1
Matt'sredbeauty's Avatar
Hey if I was to get just pbr brakes off a 99 up would I need anything else??, specifically new brake lines??,
Matt'sredbeauty is offline   Reply With Quote
Old 10-28-2005, 07:33 AM   #2
Re: Real quick question
and I have a 97 just so you know.
Old 10-28-2005, 10:27 PM   #3
Send a message via AIM to tedness
Re: Real quick question about brakes
you might need new lines but for sure probly new mounting brackets and so forth. since you are going from one piston to however many pbr is.
tedness is offline   Reply With Quote
Old 10-28-2005, 10:29 PM   #4
Just the calipers is all you should need.
Old 10-28-2005, 11:27 PM   #5
Danger Dude's Avatar
The only thing you will need is to grind a small area on the side of the mount area on the spindle to allow them to mount. There is a small raised area on the spindle that will not allow the mount bracket attach flush. this takes about 5 minutes with a grinding rock attached to a drill motor or 3 minutes with a die grinder or a dremel tool.
I know because I have PBR's on my 98
Old 10-29-2005, 08:07 AM   #6
some need grinding some do not, at least thats what ive heard. The ones I have done have all required grinding, maybe if you have a 97 up you can get by with it but dont count on it. The griding is not hard, is nearly lined up (you will see where to grind with out issue) the stoping is alot better, I would just save up and buy cobra brakes, not much more and they look great and stop tons better.
Old 10-29-2005, 09:19 AM   #7
All 94-96 need grinding. It is hit and miss on 97-98. I helped people who did not need grinding but my 98 did.
Old 10-29-2005, 10:35 AM   #8
Thanks, I was just wondering if I needed new brake lines, I was gonna get cobra brakes, but I don't have the money now, and I need brakes pretty bad. pecifically pads, Thanks for the help. Matt
Old 10-29-2005, 10:39 AM   #9
You cant go wrong with new SS lines and banjo fittings but tusing the old lines will work
Old 10-29-2005, 11:11 AM   #10
i believe ebay always has cheap cobra brakes, really cheap. You can get teh bullit ones for cheap also. If not now you always can upgrade again down the road.
Old 10-29-2005, 12:48 PM   #11
But PBR's are much cheaper and provide great stopping power with their dual pistons and aluminum housing.
Though I like Cobra brakes I hate 13in rotors on 17in rims. There is no room to clean the inner rims.
Old 11-02-2005, 05:14 PM   #12
NCONTT's Avatar
just as an FYI...this is THE brake page if you are wanting to change brakes....
HTH.
Brad
http://mjbobbitt.home.comcast.net/mu...n95brakes.html
~~~~~The never ending Project~~~~~
If you can't keep up don't step up!!
http://www.street-machines.org/phpBB.../blingauge.jpg
NCONTT is offline   Reply With Quote
quick question durtyred69 1979-1995 Mustang GT 5 01-13-2011 11:15 AM
real quick question!!!!! ryanxup Pre-2005 V6 Mustang 8 09-28-2006 07:06 PM
quick question electricstang Mustang Wheels & Tires 2 05-13-2006 09:44 AM
real quick Kyle The Bar 18 05-06-2006 04:21 PM
02:30 AM
