how long for engine to learn new fuel type? - Mustang Evolution
Old 10-28-2005, 09:46 PM   #1
Send a message via AIM to tedness
so lets say i wanted to run 93 for the track. basically any lil thing i can do i'm gonna do to help my times. not sure what tech section this belongs to so ya.
what i wanted to know is if i put 93 fuel in on an empty tank tomorrow morning, will my computer adjust itself to it throughout the day?
tedness is offline   Reply With Quote
Old 10-28-2005, 09:48 PM   #2
Re: how long for engine to learn new fuel type?
Do you have a chip burned for 93?
If not then don't waste your money on 93 because it won't make a difference.
Old 10-28-2005, 09:52 PM   #3
no chip.
alright, then ill just mah 97 crappo.
Old 10-28-2005, 09:56 PM   #4
no chip.
87 you mean?
Old 10-28-2005, 10:02 PM   #5
I_luv_HP&trq's Avatar
Send a message via AIM to I_luv_HP&trq Send a message via MSN to I_luv_HP&trq
I didn't think the car had to adjust itself to accept higher octane. When i use 100 octane i feel it right away. I also have a good tune when i do that too so it's not a waste.
here's some cool info on racing fuel and how to mix the chemicals yourself.
http://www.turbofast.com.au/racefuel.html
99 Cobra: flowmasters, 18x9.5 cobra R's, soon to be tuned and geared. daily driver
99 V6:in avatar, Mac Cai, true duals/flowmaster 40's ,UDP, custom tuned, bullitt suspension 18" wheels...taken by mother nature
I_luv_HP&trq is offline   Reply With Quote
Old 10-28-2005, 10:22 PM   #6
Actually...the way our computers work is they are constantly pushing the engine to the knocking point, and backing it off slightly. So technically...it will make a small difference running 93
Old 10-28-2005, 10:24 PM   #7
Can you back that up?
Old 10-28-2005, 10:25 PM   #8
How do you want me to back it up? Technical info or actual articles.
Old 10-28-2005, 10:26 PM   #9
Information supporting it in anyway?
I am not doubting you I just want to know more....
Old 10-28-2005, 10:27 PM   #10
Well, I'll put it this way, my roommate, a car builder says so. And my friend chris, who has written 2 computers for cars says so lol. It makes sense though. But to be honest, it won't make a big enough difference to do anything.
Old 10-28-2005, 10:29 PM   #11
DarkShadow's Avatar
Send a message via AIM to DarkShadow
I've wondered about that too...I've heard it both ways, but I've never realy heard a "This is why...".
DarkShadow is offline   Reply With Quote
Old 10-28-2005, 10:50 PM   #12
I think for regular street driving it would be a waste to fill up your tank with 93. But if you're at the track and trying to get every tenth of a second then i could see it being justified. especially if its just a couple gallons. I know from my personal experience when i used a mix of 100 and crap 87 before i had my predator tuner i could sense a smoother acceleration. (not just something in my head) It wouldn't make much of a difference for regular street driving but at the track it definitely can't hurt.
Old 10-28-2005, 10:53 PM   #13
DarkShadow's Avatar
I never bothered putting 93 in until I got my SCT tuner, so I don't really have anything to compare a before and after to. I did notice it made a difference when I did it with the tuner, but as far as before that, I don't have anything to compare. I would think it would have to make some difference tho, because higher octane fuel burns hotter and more efficiently, so even if the computer doesn't recognize it, I'd think it would still do something unless the computer retards it or something.
Old 10-28-2005, 10:57 PM   #14
The computer burns the fuel the comuter tells it too. If your timing is not advanced it will continue to burn at the same tempature regardless of 87 or 93 hince you getting nothing out of the 93.
Just a waste of a money without your timing advanced.
Old 10-28-2005, 11:01 PM   #15
DarkShadow's Avatar
So the computer does essentialy ****** it?
Old 10-28-2005, 11:18 PM   #16
Danger Dude's Avatar
The difference in burning 87 to 93 is only measurable in instrumentation and will not show up as a gain. The computer adjust to different octane only make minute changes to the oxygen level reading it receives and the knock sensor moving timing around.
So putting higher octane gas in a stock stang for performance gains is as effective as putting spinners on your car.
Old 10-28-2005, 11:28 PM   #17
wow. i guess i need a chip w/ adjustable tunes for 87 and 93. one for track, one for street.
Old 10-29-2005, 01:22 AM   #18
Thomas91169's Avatar
i doubt that.
at WOT the ecu uses a pre programmed fuel and timing map. it only has to think if it detects knock. as for other driving, it may be different, using inputs from the maf, o2 sensors, throttle input, load, and rpm to extrapolate a fuel ratio and timing advance for that moment in time. the knock sensor only sends a signal when it detects knock, meaning the computer only sees it when it is picking up knock, unlike other sensors that are constantly sending data back and forth(as in, the ones the ecu relies on), which means the ecu doesnt rely on the knock sensor to create a fuel/spark table.
unless you are running a other than stock tune, running higher octane fuel would make no difference.
unless were talking boosted vehicles, then running higher octanes allows for higher boost levels with a higher margin for tune error(or closer to the edge tune) due to the higher octanes level of fuel being able to ward off knock and predetonation. i tried to run 100 octane as much as possible on the dsm, but the station that sold it was a 20 min drive out of town, and i only got 100 octane when i was out at that city anyways for business.
-Thomas-
Old 10-29-2005, 08:00 AM   #19
run the cheap crap there is no difference in your vehcile, some people are just retarded.
Old 10-29-2005, 12:37 PM   #20
wiarumas's Avatar
and if there is a difference it will be so small it wont be worth the extra few cents.
Old 10-29-2005, 12:44 PM   #21
Actually about 5 or 6 years ago the DOT and Gov regulators forced the Gasoline industry to remove any advertisements or suggestions saying that using medium or high grade gas is beneficial in any way to a car design to run on regular. It is a scientific fact OIL COMPANIES LIE!!! Just look at them lying now.
Old 10-29-2005, 02:37 PM   #22
DarkShadow's Avatar
Old 10-29-2005, 08:15 PM   #23
It helps my car....lol. Actually..my car knocks pretty dang bad with 87 in it and the chip. Not doing that one again.
Old 10-29-2005, 08:23 PM   #24
Only because the 87 in your town was not really 87. In another words the gas in your area suxs!!!!!!
Next!!!
Old 10-29-2005, 08:32 PM   #25
Next!!!
He is saying it knocks bad because he has a chip (if he uses 87)
Old 10-29-2005, 08:39 PM   #26
Well he is a knuckle head at the very least for confusing me BY GOD
Old 10-29-2005, 08:40 PM   #27
Haha, that was my whole point corey, to confuse you. But yeh...my mom put 87 in it at one point with the chip...it really really didn't like it. Thankfully she didn't put much in and I added about 8 gallons of 93 and it cleared up.
Old 10-29-2005, 11:18 PM   #28
mmm...gas...
trackday imminent...running full interior etc. glee.
haha i want to get outta the 16's
Old 10-30-2005, 03:17 PM   #29
maaudio81's Avatar
Send a message via AIM to maaudio81 Send a message via Yahoo to maaudio81
i know with fuel the higher the grade the hotter it burns hotter is better but you have to have a nice spark there for it to be any help at all unless your running 100 or higher but most fuel injected cars cant handle it
http://i5.photobucket.com/albums/y15.../AUDIOSIG1.jpg
mods
diablo programmer
diablo chip
true dual flowmaster exhuast
CAI
headmen headers (shorties)
leather seats
5% window tint all around
97 cobra rear sway bar
97 cobra strut tower brace
future mods
5 spd swap
lambo doors
ud pulleys
performance intake
dual turbo kit
70 mm throtle body
75 mm maf sensor
1/4 mile time 14.42@98.9 mph
maaudio81 is offline   Reply With Quote
Old 10-31-2005, 06:03 AM   #30
slvr2000stang's Avatar
Higher octane does not burn hotter or faster, It Is just more resistant to knock.
Custom Delk motor now DOA
2003 SVT Lightning #1059 of 4270
2000 Vert 4R70W
Only buy from vendors that test and stand behind their products
slvr2000stang is offline   Reply With Quote
Old 11-02-2005, 01:52 PM   #31
Talking Re: how long for engine to learn new fuel type?
Premium gas burns more slowly than regular gas. That's why you need it in higher compression engines to reduce pinging.
I doubt that you could detect any difference in temperature between regular and premium gas.
All best,
Joe
1998 Laser Red V6 manual . . . Kenny Brown suspension, Eibach pro-kit springs, BBK CAI, JBA shorty headers, Magnaflow duals, GT fogs, Aluminum driveshaft, 3.27 gears, Tri-Ax shifter handle, misc UPR and MGW billet accessories, SS inserts, Redline Goods shift boot
1998Stang is offline   Reply With Quote
engine issues... no codes... fuel pump video added jimmy_beaner 1996-2004 Mustang GT 99 05-02-2009 11:56 AM
Biggest WTF I've seen in a LONG, LONG Time. Zim Pictures and Videos 35 03-09-2007 07:00 AM
Check Fuel Cap & Service Engine Soon Light??????? mattstang Pre-2005 V6 Mustang 8 12-25-2006 01:33 PM
12:44 PM
