ecu chiping - Mustang Evolution
Old 10-30-2005, 07:04 PM   #1
ecu chiping
well i have a 2000 v6 manual and when i put it in neutral i rev and it only gets to 4 rpm then it won't pass that it struggles there. and at shifting point when im racing it can only go to 5 rpm. so basically im looking for a chip that will let me red line 6-7 what do you guys recommend
tim11 is offline   Reply With Quote
Old 10-30-2005, 07:06 PM   #2
Re: ecu chiping
The chip I have is SCT tuned. My rev limiter is moved up slightly. The only thing is, on a stock engine, there's really no need to have a higher limiter. Your engine peaks before that.
Old 10-30-2005, 07:43 PM   #3
Re: ecu chiping
what do you mean by peaks before that
Old 10-30-2005, 08:11 PM   #4
Re: ecu chiping
Your peak power on the stock engine is before the rev limiter. The only real reason for raising it would be so you can accidently overrev on the shift and be able to recover.
Old 10-30-2005, 08:11 PM   #5
I_luv_HP&trq's Avatar
Send a message via AIM to I_luv_HP&trq Send a message via MSN to I_luv_HP&trq
Re: ecu chiping
going all the way to 7K RPM's won't bennefit you anymore because your cars peak or highest point of power will be before it redlines or right around there. Taking it up into the higher RPM's is just more wear and tear for a stock engine. You won't get any gain for going well over the redline.
find out where your car produces the most power and that's where you'll want to shift if you're racing.
99 Cobra: flowmasters, 18x9.5 cobra R's, soon to be tuned and geared. daily driver
99 V6:in avatar, Mac Cai, true duals/flowmaster 40's ,UDP, custom tuned, bullitt suspension 18" wheels...taken by mother nature
I_luv_HP&trq is offline   Reply With Quote
Old 10-30-2005, 08:45 PM   #6
Re: ecu chiping
alright thanks for the info
Old 10-30-2005, 09:54 PM   #7
Kiljosh's Avatar
Re: ecu chiping
If you want a chip, there a people on here that can do you good.
I got mine tuned and retuned by Justin at velocitymustangperfomance.com
Old 10-30-2005, 10:36 PM   #8
DarkShadow's Avatar
Send a message via AIM to DarkShadow
Re: ecu chiping
The ultimate mustang tuning authority. I plan to have him tune my turbo set-up. It'll be kinda expensive,but I don't think anyone around where I live has any idea how to tune something ike that.
DarkShadow is offline   Reply With Quote
Old 10-30-2005, 10:41 PM   #9
Re: ecu chiping
Quicker (and the new official name) http://www.vmptuning.com
Old 10-30-2005, 10:48 PM   #10
DarkShadow's Avatar
Re: ecu chiping
He quoted me about $700 for everything , but I guess it's better than taking it localy, have them screw it up or not tune it to it's potential, and end up just having Justin do it right in the end.
Old 10-31-2005, 05:33 AM   #11
Re: ecu chiping
The 99s up have a neutral rev limiter of 4000rpm when you are in neutral (auto) or not moving (5spd). The rev limit when moving is 5600rpm. In my tunes I move both limiters to 6000rpm, at 7000rpm bad things would probably happen.
Justin Starkey
2007 Shelby GT500 705RWHP/708RWTQ
2000 Mustang 3.8 A4 TT 450RWHP/475RWTQ 10.996@127 17psi stock 3.8
2006 F250 CC 4x4 6.0L 14.3 @ 93
2006 Mustang 4.0 M5 Vortech 13psi 395RWHP/374RWTQ wife's car
justin00stang is offline   Reply With Quote
Old 10-31-2005, 04:15 PM   #12
Re: ecu chiping
Its important to note that a large part of the $700 is hardware costs, something you can't avoid when remote tuning through over the net, if you were local you wouldn't need to buy the $200 wideband.
Justin Starkey
Old 10-31-2005, 05:06 PM   #13
slvr2000stang's Avatar
Re: ecu chiping
Or if you are close enough weigh the cost of a road trip to Justin.
Custom Delk motor now DOA
2003 SVT Lightning #1059 of 4270
2000 Vert 4R70W
Only buy from vendors that test and stand behind their products
slvr2000stang is offline   Reply With Quote
Old 11-01-2005, 09:30 PM   #14
Re: ecu chiping
im going to be getting the 8.8 rear end pretty soon.How much of a difference would it do and would i need a chip for that.
Old 11-02-2005, 05:06 AM   #15
Re: ecu chiping
If the 8.8 has stock gears then you don't need to do anything.
Justin Starkey
Old 11-03-2005, 09:27 PM   #16
Re: ecu chiping
im going to get the 3.73 what kinda of chip would i need
Old 11-04-2005, 06:52 AM   #17
Re: ecu chiping
Send me an email.
Justin Starkey
94 5.0 ECU harness help popawoody 1979-1995 Mustang GT 11 03-22-2009 01:02 AM
ecu questions Mikemx250 Pre-2005 V6 Mustang 3 10-29-2008 11:29 AM
ECU upgrades DMAC Pre-2005 V6 Mustang 3 05-13-2007 09:15 PM
reset ecu: how? tedness Pre-2005 V6 Mustang 5 07-04-2005 11:10 PM
ECU number MusclesFromBrussels Pre-2005 V6 Mustang 6 09-19-2003 04:54 AM
08:56 AM
