Trac-Loc wheel hop - Mustang Evolution
Old 11-28-2009, 02:42 PM   #1
stangaroo's Avatar
Trac-Loc wheel hop
So when I burn out my trac-loc seems to make my car shake violently, the dash bangs around and whatnot... it even does this in the rain, it actually grips pretty well in the rain and wants to launch rather than slide.
I had new tires put on right after I got the trac-loc and I'm wondering if it's the tires or trac-loc itself that is causing the bouncing, is this normal? I thought the wheels were just supposed to spin free.
Any thoughts would be appreciated!
2008 4.0 SOLD (I will miss my first stang forever)
2011 5.0 black on black with 3.73 manual and I still get over 26 mpg
stangaroo is offline   Reply With Quote
Old 11-28-2009, 04:28 PM   #2
MarkuzLS1's Avatar
Send a message via AIM to MarkuzLS1
Re: Trac-Loc wheel hop
I had the same issue when I installed 3.73s and a positrac differential in my old Camaro. Bad wheel hop, whenever I launched it hard. I swapped out the rear lower control arms to a boxed set, with polyurethane bushing. That fixed it right up. I'm not sure what all is different between the rear-ends in the 3rd generation Camaros, and whatever it is you've got, but it would be something worth looking into.
I like turtles.
MarkuzLS1 is offline   Reply With Quote
Old 11-28-2009, 04:31 PM   #3
fast64's Avatar
I had tubular BBK lower control arms on my '90 with a spool and it didn't wheel hop at all.
GO BRAVES
Old 11-28-2009, 05:47 PM   #4
stangaroo's Avatar
Ah ok, I have the stock suspension so I'm sure that's the problem, the weirs thing I that when I powerslide in second gear and let the rear swing out it slides fine with no hop at all, maybe it also depends on the road.
So tires aren't part of the equation here?
Old 11-28-2009, 11:23 PM   #5
DarkShadows's Avatar
Is this the stock posi? Never had an issue with my car. I don't have any wheel hop. Maybe suspension is worn
March 2010 Mustangevolution Mustang of the Month 1st eva biatch!
DarkShadows is offline   Reply With Quote
Old 11-29-2009, 01:35 AM   #6
stangaroo's Avatar
No the stock rear end never hopped, I have a frpp trac-loc with 3.73 gears now and it does but my tires have been gripping a lot better now that they're worn in (about 10k miles) problem seemed to be more mild when the tires were new so I'm trying to figure out if its the tires or not
Old 11-29-2009, 08:57 AM   #7
MarkuzLS1's Avatar
Wheel hop is usually an issue with suspension geometry or weak components/bushings. I've never heard of tires causing it.
I like turtles.
Old 11-29-2009, 08:20 PM   #8
Unless you flat spotted the tires. Then it would me in your suspension. You have the 8.8 solid rear? How many miles on your car?
Old 11-30-2009, 02:04 AM   #9
stangaroo's Avatar
WHAT THE ****
2001 Sport Trac wheel stud Greywolf General Car Discussion 5 07-07-2009 07:48 AM
Wheel Hop Help Needed JustlikeaFox 1979-1995 Mustang GT 7 01-03-2007 07:49 AM
you think you have bad wheel hop! fast64 The Bar 4 08-30-2005 12:57 PM
Changing to a 8.8 trac-loc Sharpie Pre-2005 V6 Mustang 19 08-20-2004 07:09 PM
wheel hop so bad it feels like bogging/shuddering tire The Bar 3 07-18-2003 07:54 PM
12:33 PM
