Whats wrong? - Mustang Evolution
Old 11-03-2005, 01:59 PM   #1
Whats wrong?
As of a week ago my car was running great and sounded great. Well over the weekend I discovered I needed a new water pump put in my car so I had it done. Now the car runs fine, but the exhaust sounds different. I have true duals with Flowmaster 40s Series at the tail. The left pipe has good compression and sounds fine, but the right pipe has a weak compression and almost sounds as though it has a "putt" to it. I know this may not be a huge problem but if something in the slightest is wrong with my car I hate it. BTW I have a 2000 V6 stock besides the exhaust.
Also, since I am posting already, I have to get new tires shortly. I have the 2000 V6 aluminum polished wheels and after much research I concluded that I was the BF Goodrich g-Force series for $79 was my best choice. It is a 16" wheel, but I want a tire with a summer tread for better handling. Just to consider all options, I live in southern Ohio where rain is occasional but the past two winters haven't been to snowy. Does anyone know if this is a good tire for the conditions or if it is a good tire in general? Thanks for all the help, greatly appreciated.
00StangV6 is offline   Reply With Quote
Old 11-03-2005, 02:02 PM   #2
MarkuzLS1's Avatar
Send a message via AIM to MarkuzLS1
Re: Whats wrong?
Exhaust leak?
I like turtles.
MarkuzLS1 is offline   Reply With Quote
Old 11-03-2005, 02:10 PM   #3
Re: Whats wrong?
Well, before I replaced the water pump it did. Now I put my hand on the right pipe and a few drops of water (dirty) did appear on my hand whereas that didnt happen on the left pipe.
Old 11-03-2005, 04:20 PM   #4
slvr2000stang's Avatar
Re: Whats wrong?
Not bad all around tires. I have them on my car now.
Custom Delk motor now DOA
2003 SVT Lightning #1059 of 4270
2000 Vert 4R70W
Only buy from vendors that test and stand behind their products
slvr2000stang is offline   Reply With Quote
Old 11-04-2005, 10:43 AM   #5
97Stallion's Avatar
Re: Whats wrong?
Hmm, their are a few possibilities. An exhaust leak would be the most likely thing, but if you don't have an h-pipe or something, you could have something like a blown head gasket. Start from the back of the exhaust and work your way forward up to the head.
Living one day at a time!
Old 11-04-2005, 03:41 PM   #6
I_luv_HP&trq's Avatar
Send a message via AIM to I_luv_HP&trq Send a message via MSN to I_luv_HP&trq
Re: Whats wrong?
try taking the rubber hose connected to your coolant reservoir and submerge the tip in a cup of water. Start your car up and see if it makes bubbles in the cup. If you do then it's a possibility you have a blown head gasket like 97stallion was saying.
If you have a stethoscope available you can touch it to the pipes and listen for any leaks.
or if you're like my brother it could just be paranioa. lol...
99 Cobra: flowmasters, 18x9.5 cobra R's, soon to be tuned and geared. daily driver
99 V6:in avatar, Mac Cai, true duals/flowmaster 40's ,UDP, custom tuned, bullitt suspension 18" wheels...taken by mother nature
I_luv_HP&trq is offline   Reply With Quote
Whats all wrong with this turbo setup? eddie1 1996-2004 Mustang GT 11 09-09-2009 09:33 AM
tell me whats wrong here..... STEVE The Bar 23 06-27-2005 12:59 PM
whats wrong with this? meteorachick The Bar 14 03-07-2005 07:28 PM
Whats wrong with canada? SpectorV The Bar 28 12-16-2004 04:43 PM
Crazy Vid, wrong place wrong time Black95GT The Bar 19 06-26-2004 03:38 PM
12:58 AM
