CAI is on it's way - Mustang Evolution
Old 09-04-2003, 01:37 PM   #1
CAI is on it's way
My CAI is on it's way and I want to clean what I can during the install, but, I've read conflicting advice on cleaning the MAS and the throttle body.
Some say clean the MAS but don't touch the sensor inside ???
Some say clean the throttle body but don't touch the butterfly with carb cleaner???
What's the right way?
Andy
2000 V6 Vert with true duals
mbsales is offline   Reply With Quote
Old 09-04-2003, 02:21 PM   #2
Send a message via AIM to Rellik Send a message via Yahoo to Rellik
"clean the MAS but don't touch the sensor inside"
This is True!!!!!
AS for the throttle body, I cleaned mine out with thinner and a rag, but I didn t touch the butterfly... because it wasn't dirty. So wait on other peoples' advice when it comes to the TB.
Rellik is offline   Reply With Quote
Old 09-07-2003, 10:04 PM   #3
tb cleanin:
carb cleaner toothbrush.
scrub tb. open tb, scrub inside.
Keep spraying tooth brush with carb cleaner throuout.
just be very gentle if you touch the butterfly. Dont spray the carb cleaner inside the tb. Just spray it on a small brush, or rag and be gentle.
you'll be all set.
Old 09-08-2003, 08:28 AM   #4
Thanks guys
CAI comes today
Andy
Old 09-08-2003, 08:56 AM   #5
have fun, i also made a how-to on intalling on just to let uknow
Old 09-08-2003, 02:27 PM   #6
Charles
Where do I find your HowTo?
Andy
Old 09-08-2003, 04:32 PM   #7
pm'ed the sites all messed up.
Old 09-09-2003, 12:26 PM   #8
Installed the CAI last night....pretty straight forward except for three problems:
1.The stock screen was too small to go on with the CAI gasket and too big to go inside it. Discarded it and will install a larger piece, cut to fit, later.
2. The stock vacuum hose from the valve cover had a plastic adapter on the end that would not fit the CAI tube fitting. even without the fitting, the hose was too small for the tube fitting. Found a scrap piece of hose, a size bigger and attached with clamps.
3.The stock grommet for the air temp sensor was at most one inch thick which allowed for the sensor to protrude into the stock tubing. The CAI grommet was over an inch and a half so the the sensor tip would still be in the grommet. Razor knifed about a half an inch off of the CAI grommet so the the sensor would go deeper.
Hope this makes sense to anyone wanting to install a CAI.
this is on a 2000 V6 Vert.
So far the results are good. No whistling, louder exhaust and quicker throttle responce.
Andy
Special thanks to Charles
Old 09-09-2003, 01:10 PM   #9
And... most if not all of your problems were addressed in the CAI article located on this site
Old 09-09-2003, 01:35 PM   #10
Sorry.....new to this site....didn't mean to be redundant.
Andy
Old 09-09-2003, 01:38 PM   #11
dont worry about anything.
Glad you got everything installed.
Old 09-09-2003, 01:38 PM   #12
No appologies needed Andy, none whatsoever!
So how do you like the CAI?
Old 09-09-2003, 02:19 PM   #13
So far so good....couldn't really get into it this morning going to work...will "test" tonite
The only thing that bothered me was cutting that grommet. Wasn't sure if they intentionally made it that thick to keep the sensor "high" or I did the right thing...
Thanks everybody
Andy
Old 09-09-2003, 02:25 PM   #14
i didnt need to cut or customize myn at all to make it fit, but it was a 94-98 one.
Old 09-09-2003, 03:16 PM   #15
Either way, it wouldnt make that much of a difference. I think you'll be fine. Let us know how your test goes
cai
afe stage 2 cai or C&L racing cai b's stang 2005-2010 Mustang GT 5 05-20-2010 06:25 PM
CAI Taywi Pre-2005 V6 Mustang 17 06-30-2007 08:45 AM
need a cai mustang0386 Mustang Parts for Sale and Wanted 4 12-03-2006 08:33 PM
Cai. Seph Pre-2005 V6 Mustang 15 06-21-2005 05:32 PM
98 V6 Cai Ibanezplayer272 Mustang Parts for Sale and Wanted 3 12-05-2004 05:32 AM
12:58 AM
