Just ordered My New Procharger - Mustang Evolution
Old 11-10-2005, 07:57 PM   #1
Today I ordered a new Procharger set up, a polished F-1 and a aluminium racing intercooler .The F-1 is good to 1050 HP and the intercooler is good for 1300. Should be an interesting set up.
487.4 RWHP 464.8 RWTQ
11.584@124.58
Sponsored by
http://www.Delkperformance.com/
WWW.SUPERSIXMOTORSPORTS.COM
http://www.v6challenge.com
GT-Eater is offline   Reply With Quote
Old 11-10-2005, 08:10 PM   #2
Tbird232ci's Avatar
Re: Just ordered My New Procharger
i know someone running one of those on a 408 stroker, he's deep in the 9's, in a fully dressed street car, im interested to see what it does for your car
Old 11-10-2005, 09:11 PM   #3
Freakin awsome dude.
Can not wait to see this put together.
Old 11-10-2005, 09:16 PM   #4
Man, that's gonna be a mean setup.
Old 11-11-2005, 07:28 AM   #5
Send a message via AIM to whipster24 Send a message via Yahoo to whipster24
That ought to be crazy fun to drive!
"This year will go down in history. For the first time, a civilized nation has full gun registration. Our streets will be safer, our police more efficient, and the world will follow our lead into the future!"
-Adolf Hitler, 1935
whipster24 is offline   Reply With Quote
Old 11-11-2005, 08:12 AM   #6
DarkShadow's Avatar
Send a message via AIM to DarkShadow
There's a guy where I live that has a stroker 5.0 and is in the process of trying to get all the stuff he needs fixed to get his Procharger up to 25 psi. According to specs, he should make 1100whp.
DarkShadow is offline   Reply With Quote
Old 11-11-2005, 10:41 AM   #7
Tbird232ci's Avatar
Better hope he isnt running the stock block
Old 11-11-2005, 03:01 PM   #8
KyleUSAF's Avatar
Send a message via AIM to KyleUSAF Send a message via MSN to KyleUSAF
gah
Originally Posted by Darkshadow
I could say nothing for my complete awe. He then. confidantly, purchased the gallon.
KyleUSAF is offline   Reply With Quote
Old 11-11-2005, 03:38 PM   #9
slvr2000stang's Avatar
Congrats Gary.
You can see it in person if you come out to the Southern V6 Ford Challenge.
Sunday March 26th from 9-3 at South Georgia Motorsports Park in Cecil, GA
This is a don't miss event.
Custom Delk motor now DOA
2003 SVT Lightning #1059 of 4270
2000 Vert 4R70W
Only buy from vendors that test and stand behind their products
slvr2000stang is offline   Reply With Quote
Old 11-11-2005, 05:21 PM   #10
Just got some good news on the Procharger Kit they are going to upgrade a
the piping from 3.0" to 3.5 " and upgrade to BOV to a procharger racing Bov
11.584@124.58
Sponsored by
Old 11-11-2005, 09:04 PM   #11
DarkShadow's Avatar
Wow, the 3" was already pretty nice!
Old 11-11-2005, 10:57 PM   #12
stroker and block are two different things
the 5.0 block has been known to crack at like 500 hp i believe
Old 11-12-2005, 12:27 PM   #13
Yeah thats true but thew intercooler outlets in there are 3.5 so this will make it both easier to install and give much need airflow for the bigger blower
it's capable of 1525 cfm's .
11.584@124.58
Sponsored by
Old 11-12-2005, 02:39 PM   #14
Gary, you've gotten good at the double posts lol.
Old 11-12-2005, 02:58 PM   #15
Fixed
11.584@124.58
Sponsored by
Old 11-12-2005, 11:05 PM   #16
Tbird232ci's Avatar
Stroker refers to the rotating assembly, the crank will have a longer throw, and the rods and pistons will be modified also, usually using longer rods, and changing the wrist pin location, to allow the piston to come down farther into the cylinder, effectivly changing displacement, you can do this to a stock block, or an aftermarket block, hopefully he used a Dart block or something similar
Gary, is 3.5" really needed? i usually hear that size doesnt matter so much as long as it isnt a restriction, such as using 1" pipe on my hybrid turbo
Old 11-12-2005, 11:26 PM   #17
Yeah I think so look at the CFM flow and the boost capability of the F-1 I think the 3.5 will be needed .http://www.procharger.com/models.shtml
11.584@124.58
Sponsored by
Old 11-13-2005, 05:33 PM   #18
I_luv_HP&trq's Avatar
Send a message via AIM to I_luv_HP&trq Send a message via MSN to I_luv_HP&trq
what would be the difference between the bov you have now and the racing one? Is there a better quality in one then the other? I thought that a bov was just a bov that gets rid of the extra air controlled by the wg.
does one brand leak at a higher psi or something?
just curious.
99 Cobra: flowmasters, 18x9.5 cobra R's, soon to be tuned and geared. daily driver
99 V6:in avatar, Mac Cai, true duals/flowmaster 40's ,UDP, custom tuned, bullitt suspension 18" wheels...taken by mother nature
I_luv_HP&trq is offline   Reply With Quote
Old 11-13-2005, 05:44 PM   #19
Well just about like everything else BOV 's have a psi rate if the BOV valve is not matched to the blower when you let off the TB it will not be able to dump the excess air it needs to ,plus if you get one thats rated to 11 or 15 psi and you are making like 20 psi you would start by-passing the metered air = not good cause there goes your boost.
11.584@124.58
Sponsored by
Old 11-13-2005, 08:58 PM   #20
DarkShadow's Avatar
Yeah, but most people go ahead and forge it if they're going to do all that, so I figured that was understood. I know what you mean tho, that may still not be good enough.
Old 11-13-2005, 11:35 PM   #21
a forged rotating assembly has nothing to do with the block it self cracking
Old 11-14-2005, 02:18 PM   #22
Tbird232ci's Avatar
The blocks crack starting around the crankshaft, and work their way up to the camshaft, and up the valley, like this:
Old 11-14-2005, 05:31 PM   #23
that is so cool
Old 11-17-2005, 03:54 PM   #24
Glad I don't have a 5.0
11.584@124.58
Sponsored by
Old 11-17-2005, 03:59 PM   #25
the 3.8>*
Old 11-17-2005, 04:06 PM   #26
Stock block to stock block the 3.8 >5.0 ,thats already been proven .
11.584@124.58
Sponsored by
Old 11-17-2005, 05:13 PM   #27
i agree, there is matt with that white car he proved it
Old 11-17-2005, 09:19 PM   #28
DarkShadow's Avatar
Wow! 5.0's suck.
Old 11-17-2005, 11:14 PM   #29
Wow! 5.0's suck.
not exaclty, only the block does
Old 11-26-2005, 05:43 PM   #30
i want your set up!!!! with the new f-1 I am guessing you will be between 525-575rwhp. Good luck,I can't wait to see the results.
bigpomps is offline   Reply With Quote
Old 11-26-2005, 07:02 PM   #31
Yeah me too I havn't recieved it yet ,I should get it this week ,I will post up some pics when it comes in .While we are waiting on the procharger we are continuing the work on the shortblock and the heads .The engine girdle came in the other day so now David has to get that to clearence.Then the heads get done ,then assembly will begin .
11.584@124.58
Sponsored by
Old 11-27-2005, 12:01 AM   #32
may i ask why you did not opt for a turbo?
Old 11-27-2005, 07:50 AM   #33
We have never seen what a BIG blower will do on these engines everybody is on V1 ,V2 ,or the procharged equivalent.I was having to overspin these blowers just to get to the HP level I wanted so I decided to go with something intercooled ,and something that I would not have to get out if it's efficiency range to make the power I am looking for .So I went with something I would not outgrow for a while anyway.
To the Turbo question yes I could have gone turbo,it would have to be a T-76 trim or higher to make the same amount of power as the F-1 is capable of making .This would have been more expensive because I would have wanted a ball bearing turbo and one that big would cost a pretty penny not to mention the header pipes and all the rest of the parts that go with it like a
water to air Intercooler .I am already in the middle of an engine rebuild with new custom heads and other neat things and I have to have it ready for tune
and paint before the March race so we already have our hands full.
11.584@124.58
Sponsored by
Old 11-27-2005, 07:54 AM   #34
I appreciate the props ,if we guessed the pulley size correctly we should make over 600+ RWHP.
11.584@124.58
Sponsored by
Old 11-27-2005, 09:37 AM   #35
well if you meet your power goals with this setup thats all that matters.
ITs going to be sick, the supercharge six with what im predicting to be 600 rwhp.
what kind of mods do you have for traction?
v6 procharger on a 5.0? can it be done? Zim 1979-1995 Mustang GT 10 06-16-2006 11:41 PM
Procharger f/s 1kwik6 Mustang Parts for Sale and Wanted 5 06-07-2005 08:04 AM
Procharger Help tedness Pre-2005 V6 Mustang 19 02-15-2005 09:20 PM
Procharger??? Falcon Pre-2005 V6 Mustang 6 12-21-2003 10:33 PM
Procharger Squirrel Pre-2005 V6 Mustang 2 07-24-2003 08:17 PM
12:30 PM
