Rotors - Mustang Evolution
Old 11-10-2005, 09:19 PM   #1
Matt'sredbeauty's Avatar
Rotors
Are these good ones???.Thanks
http://cgi.ebay.com/ebaymotors/94-03...13492156QQrdZ1
Matt'sredbeauty is offline   Reply With Quote
Old 11-10-2005, 09:21 PM   #2
Re: Rotors
To be honest, I wouldn't buy cross drilled/ slotted rotors. They will crack under any decent amount of breaking. Brandon will attest to this.
Old 11-10-2005, 10:13 PM   #3
Monkey's Avatar
Re: Rotors
don't know which Brandon you're refering to, me or Spector, but I can attest to them cracking.
If you must get drilled, you're looking at at LEAST $150-200 per rotor for a good quality one. eBay cheapies will crack under heavy load. You tell yourself, I won't be putting any heavy load on them, but then you need to stop suddenly one day and your rotor brakes.
The cheapest drilled ones I would buy are the OEM Bullit rotors. (Although they are made by Brembo, as are the Cobra's) I would spend around $350 and get a set of Brembo rotors. They will look good, and be fully functional, and safe. :thumbs2:
Old 11-10-2005, 10:22 PM   #4
Re: Rotors
To be honest, it won't do you much good to even get drilled rotors. With the current advances that have been made in brake pads. I'd get a good set of solid rotors and a good set of brake pads, and you'll be set for a long time with no worries of any problems.
Old 11-10-2005, 10:22 PM   #5
I liek gramer
WhiteStang99's Avatar
Re: Rotors
He meants Spec I'm sure.
Old 11-11-2005, 07:08 AM   #6
Re: Rotors
Ok convinced I am, Thanks, ill go oem, Thanks alot
Old 11-11-2005, 07:20 PM   #7
Re: Rotors
just get some slotted ones from stangsuspension.com
Old 11-11-2005, 09:11 PM   #8
Re: Rotors
cross drilled and slotted are for looks and will warp pretty quick and get annoying and shake your car. Get regular plain rotors and you will not only stop BETTER but you will not have issues. I would get them coated to prevent rust.
Drilled/Slotted Rotors sonicpony03 Pre-2005 V6 Mustang 49 05-11-2009 08:52 PM
rotors and brakes Kyle Pre-2005 V6 Mustang 30 08-09-2007 05:21 PM
Gripforce D&S Rotors 02V6TTcoupe Pre-2005 V6 Mustang 6 01-09-2007 09:20 PM
Rotors electricstang Pre-2005 V6 Mustang 7 05-10-2006 07:38 AM
Rotors going bad? MustangChick88 Pre-2005 V6 Mustang 12 11-22-2005 08:42 PM
03:40 PM
