Rotors going bad? - Mustang Evolution
Old 11-12-2005, 11:43 AM   #1
Question Rotors going bad?
Hey guys, newbie here at cars so im not all there as to what is goin on, I have a 96 v6 mustang and whenever I go to brake ( liek at a stopsign or stoplight) the front end feels like it is vibrating alot, its got to the point where the steering wheel will also vibrate alot too and I was tol it might be my rotors? could this be true? any help or advice will be greatly appreciated.
MustangChick88 is offline   Reply With Quote
Old 11-12-2005, 12:18 PM   #2
Re: Rotors going bad?
Yeap buy a new set of rotors and pads and be sure to check the calipers
if they are sticking thats causing the warping .
487.4 RWHP 464.8 RWTQ
11.584@124.58
Sponsored by
http://www.Delkperformance.com/
WWW.SUPERSIXMOTORSPORTS.COM
http://www.v6challenge.com
GT-Eater is offline   Reply With Quote
Old 11-12-2005, 12:22 PM   #3
Yep front rotors are warped
Old 11-12-2005, 04:43 PM   #4
Dark02Pony's Avatar
Send a message via AIM to Dark02Pony
i had this problem a while back , there was a high spot on 1 of my front rotors but it wasnt anything they couldnt machine down so i didnt have to put out cash for brand new rotors
http://img.photobucket.com/albums/v6...rtandgrill.jpg
Operation: Evolutionization.......Member #3
Originally Posted by MonteCitan
Ford Motor Company = FoMoCo..
what does that make Honda Motor Company????
Originally Posted by Nicole
Mineral Gray is such a hott color. Much better then orange
Dark02Pony is offline   Reply With Quote
Old 11-12-2005, 04:45 PM   #5
Yeh..check and see if they can be turned first. I had all 4 of my rotors turned last year....seems to still be doing ok after 20k miles on them.
Old 11-12-2005, 06:18 PM   #6
97Stallion's Avatar
no way, this is what I would do. Find a set of 99+ dual piston caliper and swap those over. you'll lose some weight and have better stopping power. Also get a set of power slot rotors and you'll be all set.
Living one day at a time!
Old 11-12-2005, 07:01 PM   #7
I_luv_HP&trq's Avatar
Send a message via AIM to I_luv_HP&trq Send a message via MSN to I_luv_HP&trq
If you do end up getting new rotors, make sure you check out prices first before taking it to a shop.
99 Cobra: flowmasters, 18x9.5 cobra R's, soon to be tuned and geared. daily driver
99 V6:in avatar, Mac Cai, true duals/flowmaster 40's ,UDP, custom tuned, bullitt suspension 18" wheels...taken by mother nature
I_luv_HP&trq is offline   Reply With Quote
Old 11-13-2005, 07:35 PM   #8
Ok here is what happened a while back when this was going on, I did have a mechanic swap my rotors which took care of the problem for like a few weeks but then it came back, when it rains outside it doesnt seem to do this at all so I wasnt sure on what it could be, I bought new rotors and am going to have them put on this weekend since I need the car through out the week for school and work..Thanx for the nice replies guys, some people from another site gave me remarks like " well if you didnt drive with your foot on the brake then you wouldnt have this problem" but thanx for the replies and advice, im hoping putting new rotors on will help.
Old 11-18-2005, 10:20 PM   #9
wait so you are replacing the rotors that you already swaped out a few weeks ago? I'd try to find what keeps warping them so you don't end up replacing them all the time. If they went bad after a few weeks then there's gotta be something else wrong.
Old 11-19-2005, 11:39 AM   #10
Zim
You want to **** me?
Zim's Avatar
the shop probably tried to take advantage of a girl and only turned the rotors instead of putting new ones on there. Whenever someone does work on my car, ill stand outside the garage and watch them do the work so i know theyre not screwing anything up. Sounds like you may have been scammed... not cool.
I like toys
Old 11-22-2005, 06:58 PM   #11
Sorry i havent been on guys, yes I did have the rotor swaped over like a few weeks back, They charged me 486 dollars for new rotors and brakes all the way around the car, stole a few lug nuts from me and then said that nothing had came with a warranty and that it wasnt their fault that the brakes and stuff was rusted...YES RUSTED! when they put the new brakes and stuff on they were rusted like all get out! I knew I was scammed but hey people or the guys propbably thought oh shes is just 17 she doesnt knpow anything..BS! I knopw when stuff on my car is messed up or has been touched or messed with wrong!Like I said before when it rains it never hardly does this though...wierd huh?
Old 11-22-2005, 07:06 PM   #12
I'd be raising some hell if I were you.
They wouldn't like me very much
Get your dad to go up there with you and raise hell. It always works.
Old 11-22-2005, 08:42 PM   #13
get a new set of rotors and put em on, its pretty darn easy and you can learn a bit on the car. Basically jack the front of the car up and take the wheels off (loosen the lugs before you jack it up though)
then turn the wheel to which ever side you need to so the caliper faces out, then remove the 2 15mm bolts on the back (there are 4 bolts, the ones you want to remove are the ones that are holding the brake onto the base mount, not the top caliper bolts.
after that slide the caliper off and hang it up so the line is not pinched or has stress on it then slide the old rotor off (tap with hammer if its stuck a bit) then slide the new one on and go in reverse making SURE you tq the brake bolts to stock specs (definatly have to do that)
easy project that you can do, make sure the brake pads dont fall out of the caliper, if they do remember how to put them back in.
Drilled/Slotted Rotors sonicpony03 Pre-2005 V6 Mustang 49 05-11-2009 08:52 PM
rotors and brakes Kyle Pre-2005 V6 Mustang 30 08-09-2007 05:21 PM
Gripforce D&S Rotors 02V6TTcoupe Pre-2005 V6 Mustang 6 01-09-2007 09:20 PM
Rotors electricstang Pre-2005 V6 Mustang 7 05-10-2006 07:38 AM
Rotors Matt'sredbeauty Pre-2005 V6 Mustang 7 11-11-2005 09:11 PM
04:15 AM
