need help mustangtuning? - Mustang Evolution
Old 11-13-2005, 05:00 AM   #1
powerhungry966's Avatar
Send a message via AIM to powerhungry966
i know for a fact that there have been many posts on gears etc. but my question is for the kits available in mustangtunging. where it comes with a speed calibrator and gear oil and the gears itself, i was wondering if it is worth buying those kits? and will i need anything else? also the site has diablo tuners with gears and oil.. i mean holy **** which one should i get.. does the diablo tuner correct the speedo? crap guys im hella clueless
1989 coupe 5.0 yeessur.
"Shake n bake"
powerhungry966 is offline   Reply With Quote
Old 11-13-2005, 11:48 AM   #2
Re: need help mustangtuning?
Do have a 5 speed or auto?
The 5 speeds can have the speedo adjusted using a speedo gear.
For an auto, you will have to flash the cpu using some sort of tuner.
Old 11-13-2005, 12:14 PM   #3
Joel5.0's Avatar
It's a matter of checking your requirements and budget, of course. The kits with the calibrator will allow to correct the gear difference and give you an accurate speed reading. You want more?....the diablo tuners will not only correct the gear difference to the installed gears and give an accurate speedo reading but, will cover any other gear ratio changes in the future plus,......you can change timing, MAF, fuel injection, idle setting, ..,.... LUK what you decide. GL
Joel5.0 is offline   Reply With Quote
mustangtuning.com let me down tedness The Bar 2 03-31-2005 02:43 PM
MustangTuning.com review ASSEMbler The Bar 7 02-27-2004 10:13 PM
04:48 AM
