exhaust leak - Mustang Evolution
Old 11-13-2005, 06:45 PM   #1
exhaust leak
I have a 00 V6 mustang and at times you can hear a noticeable leak in the exhaust manifold. It has the same old stock exhaust system and crazy as it sounds Im fairly happy with it. The question I have is who makes headers that would be a direct bolt on for the rest of my exhaust or do I need to replace it all?
mustangruss is offline   Reply With Quote
Old 11-13-2005, 07:01 PM   #2
Re: exhaust leak
Is it on your passenger side?
Old 11-13-2005, 07:05 PM   #3
Re: exhaust leak
No I believe it is on the drivers side.
Old 11-13-2005, 07:13 PM   #4
Re: exhaust leak
Hm...ok. I know on my car, my passenger manifold separated where the manifold meets the midpipe.
Old 11-14-2005, 05:35 PM   #5
Re: exhaust leak
Thanks Ill check that out.
Old 11-28-2005, 11:01 PM   #6
Post Re: exhaust leak
I have a 00' and the right head split apart on me too. Right by the mide pipe and egr line. You're better off replacing it but if you must you can either take it to a fab shop or a muffler shop and have them weld it back for you. Before I replaced the heads this is what I did with no problems. Watch out though muffler shops want to rape you like 70 dollars for a simple weld!!!! This exhause leak is very very common. Its been highlighted all over the web! In the exact same place. When you get the head off look at where the heads are welded and then look at the left one. You'll notice that the left one is much much more stronger!!!!
af00mustang is offline   Reply With Quote
Old 11-28-2005, 11:50 PM   #7
Re: exhaust leak
It's not the heads..it's the manifold. But yeh, Ford just won't do a recall on it, and I want my 180 bucks. I still have the split manifold and my receipt if they ever decide to do a recall lol.
Old 11-30-2005, 05:22 AM   #8
Re: exhaust leak
Disconnect the egr line and mid pipe and what do you have? Headers.
Old 11-30-2005, 09:18 AM   #9
Scoot99V6Stang's Avatar
Send a message via AIM to Scoot99V6Stang Send a message via Yahoo to Scoot99V6Stang
Re: exhaust leak
Same thing happened to me on the passenger side. I just went with MAC LT headers, but any Shorty header for our car from any company will bolt directly up. Change the sound a little, but not much. If you decide to change the headers BE SURE to replace the header gaskets too. If not it'll prolly leak after the install. If you are gonna install them yourself, be prepared for a BEAST of an install, Not hard just slow,hard to reach, and tidious. Good luck.
Scoot99V6Stang is offline   Reply With Quote
Old 11-30-2005, 11:26 AM   #10
Re: exhaust leak
Haha...I took off my blown manifold and put a new one on...with no jack...with my car lowered 1.5. It was very very interesting. Luckily I had already done an egr delete.
Old 12-01-2005, 12:02 AM   #11
Kiljosh's Avatar
Re: exhaust leak
Get yourself a pair of Mechanix gloves if your swapping headers or be prepared to bleed.
Old 12-01-2005, 03:00 PM   #12
Re: exhaust leak
Nah, it's not that bad.
Old 12-02-2005, 02:38 PM   #13
Re: exhaust leak
Please quit calling it a manifold!!!
Old 12-02-2005, 10:20 PM   #14
Re: exhaust leak
Well what do you want to call it? It's not a head, it's an exhaust manifold. It's not headers b/c well...it's not aftermarket.
Old 12-03-2005, 07:05 AM   #15
01mineralgrey6's Avatar
Re: exhaust leak
I call it a manifold aswell....don't headers also merge into a single collector instead of the 3 pipes going into 1 one at a time? And the install isn't too bad, just takes some time. I put jba shorties on my v6 with handtools in my driveway in probably about 3 hours
-Tony
'99 cobra 'vert
Old 12-05-2005, 07:40 PM   #16
Re: exhaust leak
Im thinking of getting Mac shorty headers but do I have to get a H pipe too if I go the header route. I can do it just dont want to do it if i dont have to.
Old 12-05-2005, 08:10 PM   #17
Re: exhaust leak
You don't have to get an H-pipe. Your car will run fine with true duals. That's what my exhaust is run as.
Old 12-05-2005, 08:22 PM   #18
Re: exhaust leak
Thanks I appreciate it. Just ordered them.
Old 12-05-2005, 08:26 PM   #19
Re: exhaust leak
But....the only thing is...will shorties hook up to the stock y pipe? I'm kinda curious now...
Old 12-05-2005, 09:15 PM   #20
Re: exhaust leak
quit calling it a head!!!!!!!!!!!!!!!!!!!!!!!!
head is this
exhaust manifolt as it should be called is this
Its called an f'ing manifold
Old 12-06-2005, 07:17 AM   #21
Re: exhaust leak
my JBA shorties did:dunno:
-Tony
'99 cobra 'vert
Old 12-06-2005, 10:06 AM   #22
Re: exhaust leak
Ah ok, well good deal then.
Old 12-10-2005, 08:26 AM   #23
Ibanezplayer272's Avatar
Send a message via AIM to Ibanezplayer272 Send a message via MSN to Ibanezplayer272
Re: exhaust leak
head is this
Oo those are some pretty rusty leaf springs.
2007 Windveil Blue Mustang GT
Mods : Intake, Stubby antenna
Rolls are for fat chicks
Ibanezplayer272 is offline   Reply With Quote
exhaust
2001 Cobra fuel leak (I know wher3e the leak is) badcrc General Mustang Discussion 2 12-27-2008 11:54 PM
Exhaust Leak Help 97_GT 1996-2004 Mustang GT 8 05-20-2007 11:49 AM
exhaust leak 98StangGT 1996-2004 Mustang GT 8 08-29-2006 03:38 PM
I have an exhaust leak... Ibanezplayer272 1979-1995 Mustang GT 19 12-15-2005 11:47 AM
exhaust leak Scorpion99 Pre-2005 V6 Mustang 1 03-27-2004 02:47 PM
02:37 PM
