2006 V6 Manual Trans - Bucks in 1st Gear in AM - Mustang Evolution
View Poll Results: Does your manual tranny buck in 1st gear when cold?
Yes, every morning 2 50.00%
Yes, but not much of a problem 1 25.00%
Yes, but I got it fixed 0 0%
Never does 1 25.00%
Voters: 4. You may not vote on this poll
Old 11-15-2005, 11:45 AM   #1
In the mornings, when I first start my 2006 V6 manual tranny, it bucks in 1st gear and a bit less so in 2nd. I would imagine onlookers think I cannot drive a stick shift. The dealer says "this is how they all are" and tells me to "just warm it up in the mornings". Well, this is not acceptable to me.
Anyone else have this problem? Does this also effect V8's?
Once the engine is sufficiently warm, the bucking goes away, but to my mind this should never happen. The mornings here in OC Calif these days are high 50's, low 60's.
My Honda's with fuel injection never do this...I start them cold and drive off, no bucking, etc.
Is this bucking acceptable? IMHO, I think not.
What say you?
Thanks
lovcom is offline   Reply With Quote
Old 11-15-2005, 08:11 PM   #2
Re: 2006 V6 Manual Trans - Bucks in 1st Gear in AM
its probably the clutch cable, its cold and thus shrinks so you are used to driving it when its normal and warm, expaned and longer. When you drive it while cold it will release faster, thus causing it to engage to fast and you get a bucking.
that may be one explanation, the other may be the idle bypass valve, it can get stuck when cold... but I dont see it causing this.
Old 11-15-2005, 08:12 PM   #3
see if it also does it if you really ride the clutch out
Old 11-16-2005, 02:50 AM   #4
Thomas91169's Avatar
i get this also, the first few take-offs the clutch will sort of "skip" a few times while you ride it out, like its cold and isnt grabbing, makes the car buck a little bit. it does it when i get to the end of my street, and the first stop sign before i hit the country, after that, its fine. but its not just in 1st though, itll skip when going into 2nd and 3rd, but by the time im out of my neighborhood, its warmed up.
i wouldnt worry about it too much. its cause its a mustang, its going to be more rough and rugged than the honduh your used to. its just what comes with the territory.
-Thomas-
Old 11-16-2005, 09:00 AM   #5
thats true, really cold weather hurts the friction of the clutch disk.... so that could also be part of it if its REALLY cold where you are
Old 11-16-2005, 09:43 AM   #6
Well, I doubt the problem is the clutch, at least in my case. It seems to be the programming of the chip that controls the feed of gasoline? It seems that this problem effects more then a few v6's and perhaps v8's too. I am very turned off to Ford for having this "hey, get over it" attitude, at least thats what I get from a few dealers here in OC Calif. I have a hard time accepting this "hey it's a Mustang, it's supposed to be a little rough" explanation. The car should be like most others in this regard....one should be able to start it stone cold, and because it has fuel-injection, it should just drive wonderfully from the get-go. Most other cars do this, so why not the Ford? Ford is not new to Fuel-Injection, so why is this happening? Perhaps I'll never know....once warmed up, it does run just fine, shifts smooth as silk, etc. Perhaps coming from mostly Japanese products, I have developed too high a level of expectations? For the $$ one pays for the V6, it should not do this.
Old 11-19-2005, 08:31 PM   #7
If it goes away 60 sec after start up then its most likely the cold start spark ******, necessary to heat up the cats to meat ULEV-II. An aftermarket SCT Tune by a tuner who knows how to fix this issue is an option.
Justin Starkey
2007 Shelby GT500 705RWHP/708RWTQ
2000 Mustang 3.8 A4 TT 450RWHP/475RWTQ 10.996@127 17psi stock 3.8
2006 F250 CC 4x4 6.0L 14.3 @ 93
2006 Mustang 4.0 M5 Vortech 13psi 395RWHP/374RWTQ wife's car
justin00stang is offline   Reply With Quote
Old 11-19-2005, 09:52 PM   #8
I_luv_HP&trq's Avatar
Send a message via AIM to I_luv_HP&trq Send a message via MSN to I_luv_HP&trq
if you know that this "problem" effected other cars, what did the other people do to solve the problem?
every car needs to warm up properly anyways. just because it's fuel injeted doesn't make it a special case.
99 Cobra: flowmasters, 18x9.5 cobra R's, soon to be tuned and geared. daily driver
99 V6:in avatar, Mac Cai, true duals/flowmaster 40's ,UDP, custom tuned, bullitt suspension 18" wheels...taken by mother nature
I_luv_HP&trq is offline   Reply With Quote
Old 11-20-2005, 07:39 AM   #9
Most of the 01-04 V6s and GTs also have cold spark start ****** that may cause the same type of issue.
Justin Starkey
Old 11-20-2005, 09:08 AM   #10
Monkey's Avatar
Dont forget the tranny fluid needs time to warm up to facilitate the gear changes.
trans problems 1st to 2nd automatic 96 cobra vert 1996-2004 Mustang GT 14 10-19-2007 01:41 PM
Just bought a 2006 V6 Manual trans Pony pkg Rick0636 Pre-2005 V6 Mustang 17 02-22-2006 08:18 AM
05 v6 manual trans.. MonteCitan Pre-2005 V6 Mustang 29 01-07-2005 04:40 PM
auto/manual tranny gear and rear gear STOCK ratios SpectorV Pre-2005 V6 Mustang 0 07-08-2004 02:41 PM
Sound in 1st gear drichard Pre-2005 V6 Mustang 12 10-10-2003 01:17 PM
11:05 AM
