Start problem - Mustang Evolution
Old 11-15-2005, 03:53 PM   #1
NorwegianMustang's Avatar
Send a message via AIM to NorwegianMustang Send a message via MSN to NorwegianMustang Send a message via Yahoo to NorwegianMustang
Start problem
When I turn the key to start the car all I get is 1 click, then the car goes dead/dark. But when I use a booster, it start right up like nothing is wrong.
I can drive the car, turn it off, then try to start it again, same thing, dead.
My toughts is a grounding issue.
When the car is running, I got a charge on 14.35 Volt. When off I got 12.35 Volt, but when I try to start, it "jumps" to 12.45Volt
I got a new red-top Optima installed in the car.
Gonna check my ground cable on the engine tomorrow. I even got a guy on it, he gonna ask his teacher (girl).
Until then, HELP!!!
Mods: Magnapacks, BBK X-pipe with cats, BBK CAI, hood struts, KYB Shocks/Struts, Eibach Pro springs, SS Inserts, CDC Light bar, Chrome 17" Bullits with Nitto 555 and N2O with dual purge
NorwegianMustang is offline   Reply With Quote
Old 11-15-2005, 03:55 PM   #2
slvr2000stang's Avatar
Re: Start problem
Checking the grounds is a good start.
Custom Delk motor now DOA
2003 SVT Lightning #1059 of 4270
2000 Vert 4R70W
Only buy from vendors that test and stand behind their products
slvr2000stang is offline   Reply With Quote
Old 11-15-2005, 04:19 PM   #3
Re: Start problem
Yeh, follow your ground wire off the battery, it also might not hurt to go ahead and have your alternator checked...
Old 11-15-2005, 08:06 PM   #4
I_luv_HP&trq's Avatar
Send a message via AIM to I_luv_HP&trq Send a message via MSN to I_luv_HP&trq
Re: Start problem
your battery is putting out the right amount of volts.(12.6 is usually perfect but you're ok)
and you say the battery is new right? even with new ones sometimes there's sulfation and that can cause only the outside of each cell to charge which is why it dies after a while.
Try starting your car and taking the negative cable off. Let it run for a minute and if it dies the alt for sure needs to be checked out. If it is the alt then it could just be the brushes are worn or a bad connection with the field coil or commutator.
Clean each terminal post with some baking soda and water and use sand paper if you have to scrap stuff off the terminals. When you re connect them make sure the cables are all the way down.
and like the others said, check your grounds. make sure the top of your battery is dry and nothing that can cause current to travel from post to post.
99 Cobra: flowmasters, 18x9.5 cobra R's, soon to be tuned and geared. daily driver
99 V6:in avatar, Mac Cai, true duals/flowmaster 40's ,UDP, custom tuned, bullitt suspension 18" wheels...taken by mother nature
I_luv_HP&trq is offline   Reply With Quote
Old 11-16-2005, 02:51 PM   #5
Re: Start problem
Think I found out the problem, not sure though. Here is what I did.
I took off the negative connection to the started and cleaned it, then I did the same with the positive.
Then I cleaned the poles and connections, then installed them back on.
Wrom, car started right up. Turned it off and tried to start it again, nope, 1 click. So I took off the positive connection and re-installed it and wrom, started. Turned it off and tried to re-start it, 1 click. So I took off the positive connection and re-installed it, but I managed to break the connection, so now I got to get new once.
Hope the car will be back to normal with new connections.
Oh, and didn't use the booster, so that's a good thing I think.
Old 11-17-2005, 12:49 PM   #6
Re: Start problem
Ok, problem solved, at least it seems like it.
Got 2 new connections and now it fires right up like normal
Old 11-22-2005, 06:02 PM   #7
Joel5.0's Avatar
Re: Start problem
:no: :no: :no: :no: :no: :no: :no: :no: :no: :no: :no: :no: :no: :no: :no: :no:
Sorry.......had to edit your quote just to make a point............. That is the worst way to check the charging system of a car with computer control and electric fuel pump. That type of testing was OK for cars using generators instead of alternators.
If you remove the ground cable from the battery with the engine running this is what happens and its possible consequences:
- you may send a marginal alternator to the grave by causing it to max itself out trying to keep up with the voltage/amps demands of high consumption devices (ie. fuel pump, electric rad fan) and causing it to get burned, literally.
- you remove the reference ground used by other electronic devices in the car (ie. ECM, ign. module, etc) and the possibility of a failure of any of them or combination, with the added cost ($$$$$$) to replace them. Believe me, BTSTDT (the repairs, I mean, caused by someone else, usually a customer).
- the engine would stall anyway due to the explained above, not necessarily because of a bad alternator.
Cheap advice, to check the charging system use a digital or analog multimeter, it's worth the savings and the car's downtime. TC/GL
1986 Mustang GT w/T-Tops :angryfire
NOW: 5.0L Stock shortblock, X303 Cam, SP Offy. Port-O-Sonic, 700 cfm DP Holley, 289 '66 Small Port Heads, 1.7 RR, Richmond Gear 4+1 Trans., Centerforce DF kit, 2.73 Gears
WIP: 3.90 Gears, LS Overhaul, Adj. LCA's (New Design Granatelli Aluminum), Adj. UCA's (Granatelli), New Valve Springs (FRPP, done), Subframe Connectors (MM), Caster/Camber Plates (MM), T-Top weatherstriping and rear braces bodywork :cussing:
Joel5.0 is offline   Reply With Quote
95 mustang wont start, ignition problem? Billy95Gt 1979-1995 Mustang GT 5 07-29-2010 09:03 PM
HELP 2010 Gt Start up Problem edgar_220 2011-2014 Mustang GT 15 07-26-2010 09:35 PM
Won't start 32vMach Pre-2005 V6 Mustang 13 03-28-2010 04:56 PM
V6 won't start...help stang man Pre-2005 V6 Mustang 2 11-26-2006 01:15 PM
09:58 AM
