tq convertor - Mustang Evolution
Old 09-06-2003, 07:44 PM   #1
Send a message via AIM to v6white98
tq convertor
what exactly will this do for my tq?? is this something that really needs to be done?? good brands??
thx.
v6white98 is offline   Reply With Quote
Old 09-06-2003, 08:18 PM   #2
Send a message via AIM to greenflash00
Off the line tq will be GREATLY improved. I just got a 3k stall and i love it. IMO only go with Precision Industries
http://www.mustangmods.com/data/990/sig_2_resize.jpg
Gt takeoff exhaust with Flowtech Warlock mufflers, Mac CAI, ASP UDP, Flex Phenolic Spacers, 17 by 9 Cobra R's, 275/40s all around, FMS C-Springs, Tokico shocks and struts, FMS T-loc, FMS 4.10 gears, fordchip, 3000 stall PI tq converter, B&M Supercooler, and some various appearance stuff.
greenflash00 is offline   Reply With Quote
Old 09-06-2003, 08:59 PM   #3
Monkey's Avatar
www.howstuffworks.com this will tell you quite a bit about it, but basically it acts as the clutch for an automatic car. a good aftermarket one will be lighter, multiply the torque thru the tranny at a higher ratio (more torque at the wheels) and will have a higher stall
basically they are almost good for about 0.5 off your 1/4 time and good amounts of torque at the wheels
Old 09-08-2003, 05:29 PM   #4
Send a message via AIM to Outk4stV6
how much do these things go for?
Silver 2000 V6 auto w/ 17" silver cobra rims, 20% tint all around, mach 1 grill delete, cai, halfshafted and ported TB, P&P upper intake, dual flow 40s w/ pacesetter h-pipe w/ gt take-offs
representin' www.sacstangs.com
Outk4stV6 is offline   Reply With Quote
Old 09-08-2003, 06:17 PM   #5
Monkey's Avatar
700 for a PI (this belongs in drivetrain) plus install
Old 03-16-2004, 08:07 PM   #6
what kind tq?
what kind troque conveter best for our v6?
Lightningf150 is offline   Reply With Quote
Old 03-16-2004, 11:12 PM   #7
Monkey's Avatar
get a Precision Industries Stallion with between a 2600-3000 stall. the higher the stall relates to the higher the mods on your car
Old 03-18-2004, 08:24 PM   #8
Uh... Someone correct me if I'm wrong... But TQ convertors don't provide more measurable TQ at the wheels? I always heard they let you "get to your power faster" like gears. Is that not true? How much more torque do they provide, then?
Laser02 is offline   Reply With Quote
Old 03-18-2004, 08:32 PM   #9
correct, torque converters have a multiplucation factor. It's the same idea as gears. It accelerates you faster, but doesn't do more work(via torque) than before.
1998 Subaru Legacy L Sedan
New Hottness
1999 V6 5-speed
14.6 @ 95 w/ 2.22 60'
Wrecked
stangin99 is offline   Reply With Quote
Old 04-03-2004, 05:37 PM   #10
Question on the same (old) topic:
If you have two stock V6 stangs.. One is a manual, and one is an automatic. And you swap a 2800-3000 stall 9.5" TQ converter in the auto... Will they be the same speed? Will the auto be faster? Just how much drivetrain loss does a TQ converter make up for? Discuss amongst yourselves.
Old 04-03-2004, 06:08 PM   #11
Monkey's Avatar
if you put a shift kit and a converter in the auto, it will beat the manual even if it has a short throw.
Old 04-03-2004, 06:58 PM   #12
Rick0636's Avatar
Yep, that is why you don't see many big time drag racers with straight drives, they run automatics.
Old 04-03-2004, 07:52 PM   #13
That's badass.
Brandon: What'd you run with all your drivetrain mods?
Old 04-03-2004, 10:43 PM   #14
Monkey's Avatar
with my single port 98, i was running 15.2 N/A. (which is about 2.0 sec off a stock 98 auto's time)
that was with 8.8 w/ 4.10s and auburn posi
shift kit
2600 stall w/ tranny cooler.
alum driveshat
cai and UD pulley
and suspension.
Old 04-03-2004, 11:41 PM   #15
I need to get gears and go to the track one of these days.
I've got a 3k Stallion, Alum. Driveshaft, Fairbanks competition shift kit, CAI, true duals w/ flowtech warlocks and h-pipe, and suspension, as far as performance mods go.
I have no idea what I run, but I have beat (3 times) my bosses 350 Buick Roadmaster that supposedly runs 14.9 stock. :chin:
Old 04-03-2004, 11:49 PM   #16
Monkey's Avatar
i doubt youre in the 14s with those mods. are you single port or split?
if youre split, then its possible. if youre single, then its not. 4.10s will knock off about another .4 off your 1/4 time so that will help quite a bit too.
no one realizes how much an auto v6 can benefit from just drivetrain mods. you dont even have to get into the engine to be really running low 14s on a 99+ and high 14s on a pre99
Old 04-03-2004, 11:54 PM   #17
I am splitport. 2002.
But yeah, I know what you mean. I did the tq converter and shift kit at the same time and it really woke up my car. Gears are somewhere next on my list... But I don't want to get them and have to get a chip.. And then reburn the chip over and over when I start doing major engine stuff.
Old 04-04-2004, 01:12 AM   #18
Send a message via AIM to SDStangV6
i want one soo bad...itll probably be my last mod but im a little worried about the mpg. i drive 26miles on the freeway each day and it sucks already with my 4.10s.
SDStangV6 is offline   Reply With Quote
Old 04-04-2004, 03:10 AM   #19
I drive 38 miles each way. Yes. It will hurt your gas mileage. Yes. It is worth it. Your car will never drive the same again. I remember when my friend and I first installed it at his shop, I tried to drive like I usually would and all of the sudden I'm doing this huge burnout out of his parking lot with a ****-eating grin on my face. Well worth the money. Besides nitrous and gears, it's probably the best bang for your buck.
Old 04-04-2004, 11:35 AM   #20
Monkey's Avatar
i think the converter is more of a bang than the gears IMO.
anyway, just get a speed-cal from www.dallasmustang.com and that will correct your speedo w/o having to get a chip. and you wont ever have to get the speed-cal reburned.
Old 04-04-2004, 11:52 AM   #21
Speed cals are only available for 94-98 automatics.
Old 04-04-2004, 02:54 PM   #22
Monkey's Avatar
email them. I know for a fact that SpectorV has an 01 and has a speedcal on his car.
Old 04-04-2004, 03:11 PM   #23
Hmm. That's news to me. Thanks.
Old 04-16-2004, 10:43 AM   #24
Suprman's Avatar
Send a message via AIM to Suprman
i got my 2800-3000 I about ready to go in! i'm running 15.4 right now with stock engine from TB to Oil Pan. just bolt ons. when i get the TC in i should be running 14.99999999 hopefully!
so that will be fun! but ain't fast enough for me! i got Fully NA Heads and a nice custom cam from RGR, and to go with: RPM cut and weld intakes! and then a dynotune may 22 if i can get it all installed by then!
Click On Sig For More Info
http://www.mustangmods.com/data/6447/suprman.jpg
Best 1/4: 15.49@88MPH
Originally Posted by a232stang
SUPRMAN KICKS ***.
Suprman is offline   Reply With Quote
Old 04-16-2004, 01:08 PM   #25
Monkey's Avatar
subtract 0.1sec from that and that is what you should run with the converter if you get traction. but you have an 8.8 with slicks, right? put them on and you'll hook fine.
Old 04-16-2004, 08:23 PM   #26
01mineralgrey6's Avatar
I belive his is a manual
-Tony
'99 cobra 'vert
09:56 PM
