EGR delete concerns - Mustang Evolution
Old 12-16-2009, 03:54 AM   #1
sledgehammer's Avatar
Send a message via Yahoo to sledgehammer
Question EGR delete concerns
sent my chip in to get egr turned off so i can delte it. just was concern and curious if i could also delete the DPFE vavle too? thanks
Jared
94 v6 manual, 3.45s w/t-lock, cai, straight straight through dual exhaust, sct eliminator.
sledgehammer is offline   Reply With Quote
Old 12-17-2009, 02:53 AM   #2
Re: EGR delete concerns
Well when you delete the EGR with a tune, it will turn the whole EGR system including the DPFE sensor which is a headache on these cars. They are always setting off a check engine light.
96 GT- Who knows what's in it.
Old 12-20-2009, 09:19 PM   #3
Send a message via AIM to dtbback
yea it will turn it off and you should remove the PITA DPFE
3.8L with Forged and Balanced Internals,65mm BBK Throttle Body, JBA Headers, Mild Cam, KN CAI, Port/Polished Heads, T5 with GT Clutch, Steeda Short Throw Shifter, 180rwhp/200rwtq, Foose Df-5 18", 14" Roush Alcon Front Brake Kit
dtbback is offline   Reply With Quote
Old 12-24-2009, 10:57 PM   #4
Region: Iowa
Send a message via AIM to Horse Send a message via Yahoo to Horse
Does anybody know how the computer calculates the injector pulse width if the DPFE is removed? Does the tune just assign a default value or what?
4.2L , CAI, BBK 65MM throttle body, 30lb injectors, SSM ported intakes, FLEX 1/2" spacer, RPM big valve heads, Comp roller rockers and cam, ASP-underdrive pulley, GT rear swaybar, & Quad Shocks, Full MM Coilover conversion, 17" Grey Torque Thrust wheels, FMS Aluminum driveshaft 8.8 rear w/ 3.73 gears, Tri-Ax Shorthrow shifter & SPEC stage II clutch w/ aluminum flywheel
Horse is offline   Reply With Quote
Old 01-02-2010, 06:57 AM   #5
Zebs5408's Avatar
hey bro i read your sig man very impressed what year is your 3.8?
04' mustang 3.9 40th Anniversary Edition- (V2 Vortech Supercharger, 38# injectors, 3.73 gears w/ T-lok, Predator Diablo, Mac cold air intake, Port & polished upper AND lower intake manifold, Mac Long Tube Headers, Mac o/r H pipe, flowmasters, 2.5 flowmaster tips)
03' Mustang GT (20" Cobra R's, 40 series Flowmasters)
Zebs5408 is offline   Reply With Quote
Old 01-02-2010, 08:26 AM   #6
its a 2000. before the IMRC's were placed in the intake.
Old 01-02-2010, 08:28 AM   #7
thanks. its a 2000. before the IMRCs were place in the intake.
Old 01-02-2010, 08:30 AM   #8
not sure how it calculates the injector pulse. but when you remove it and turn off the EGR withthe tune it should take care of the DPFE
Old 01-03-2010, 07:04 AM   #9
Zebs5408's Avatar
are we talking bout those little KNOTS inside the lower intake? sorry to seem like an idiot but i was told the were egr valves and to shave them so while i was porting the lower intake i grinded them down....i wasnt aware a tune was required after that lol.....ooopss
Old 01-03-2010, 04:01 PM   #10
thank you for the help. I'm waiting for my chip to come back. but another question. ZEb refered to the egr inlets in the lower manifold on splitports, i was curious if those could be removed rather than shaved?
Old 01-03-2010, 06:34 PM   #11
Zebs5408's Avatar
nah this lil bastard have to be grinded down....they smoke almost to a fire when you grind them
Old 01-03-2010, 08:21 PM   #12
yea those are the egr inlets. when porting grind them down as far as possible and then fill with some jb weld and then grind smooth. this way your runners are a smooth as possible.
Old 01-03-2010, 08:23 PM   #13
what do i use to grind them down?
Old 01-04-2010, 07:19 PM   #14
Zebs5408's Avatar
wow bro i didnt think about that the info i used off the internet never said anything about JBin them in and smoothing them out, i just got holes in mine but i still for the results lol, oh well im tearing her down again and ill be sure to do that thanks man, and sledgehammer you use a dye grinder im attaching a pic so you know what it looks like and then you get grinding stones to shave them down with, this all can be purchased at home depot or wal mart!
Old 01-07-2010, 11:52 PM   #15
thanks, i was wondering was bit worked best. i worked with die grinders but mostly using cut off wheels
egr delete kit Dark02Pony Pre-2005 V6 Mustang 17 05-29-2005 09:58 PM
Idle concerns 98GreenStallion Pre-2005 V6 Mustang 22 03-14-2005 09:40 AM
egr delete InVaDeR Pre-2005 V6 Mustang 18 11-23-2004 09:05 PM
EGR delete kits plus other stuff for sale 97Stallion Mustang Parts for Sale and Wanted 0 05-27-2004 08:15 PM
EGR delete kits Stylin97V6 Mustang Parts for Sale and Wanted 8 03-05-2004 09:04 AM
10:50 PM
