1995 mustang automatic help. - Mustang Evolution
Old 12-18-2009, 10:57 PM   #1
im trying to get a little more bang out of my pony, what mods should/can i do for it to get some more power. its all stock.
Taylor is offline   Reply With Quote
Old 12-19-2009, 07:37 PM   #2
SC_STEEDA's Avatar
Re: 1995 mustang automatic help.
4.10 gears/ t-loc and a tuner. gears will run about $500/$600 installed. t-loc is about $100 and NEEDS to be installed when the shop puts in the gears cause it goes where the gears are. T-loc will help you get traction better by spinning the both tires instead of just the passenger side spinning. The tuners are about $350 but are well worth it for the autos cause it gives better shift points and it will help when you get more mods. Unfortunately you have to have the tuner after the gear install because the speedo has to be set.
2003 LAND ROVER DISCOVERY-These are amazing off-road vehicles to be stock!
2001 3.8L TOTALED
CAI; HELI-X Throttle Body Spacer; MOTOBLUE Pulley Kit 42%; Crank 5% Water; Harmonic Balancer; WIRES; EIBACH Sport Springs; FLOWMASTER Dual 40 Series turndowns!
"You want something. Go get it. Period. Don't ever let someone tell you... you can't do something."
SC_STEEDA is offline   Reply With Quote
Old 12-20-2009, 10:17 AM   #3
will_0828's Avatar
will_0828 is offline   Reply With Quote
Old 12-20-2009, 12:55 PM   #4
big show 98's Avatar
Here are the mods I've done to my 98. They woke the car up a good bit. I'm having my shift kit installed in the morning. I'll keep you posted.
big show 98 is offline   Reply With Quote
Old 12-21-2009, 01:53 AM   #5
jwalthersoccer's Avatar
Where did u get ur shift kit from?
35th Anniversary Laser Red Convertible V6
All I can do is try and live up to my V8 brotherens glory... :burnout:
First mod AM CAI
jwalthersoccer is offline   Reply With Quote
Old 12-21-2009, 07:26 AM   #6
for an auto 4.10 gears/tlok and a good tune will make a big impact (as said above) just make sure the transmission is taken care of (fluid should be changed every 20k miles honestly~)
Old 12-21-2009, 11:54 AM   #7
B&M kit from Jegs $70
Old 12-21-2009, 12:00 PM   #8
I went with the 3.73's due to alot of interstate driving. If that's not a factor I would def go with the 4.10 gears. 3.73's made a big difference but it could use more gear.
Old 12-21-2009, 01:32 PM   #9
The reason I recommend 4.10s for the auto is the worse gearing of the transmission vs a manual, but you are correct the final drive hurts gas mileage with 4.10s
Trans-Go makes (or made back when I used them) a good shift kit for 94-98. But for 99+ they stay to steer clear of them.
Google a mod call the "Jerry Mod" for your transmission, its very popular for 99-04 and might work for 94-98 as well, its something you can do yourself I do believe and some say works better than a shift kit.
1995 mustang
For Sale: 1995 Mustang GT 5.0 / auto Otlaw80 Mustangs for Sale and Wanted 0 05-04-2010 03:33 PM
FS: 1995 mustang 5.0 Motor fitabe Mustang Parts for Sale and Wanted 9 09-15-2006 08:22 AM
1995 Mustang Exhaust StreetRacer4371 1979-1995 Mustang GT 8 02-24-2005 10:22 PM
05:00 AM
