00 v6 problem!! - Mustang Evolution
Old 12-19-2009, 05:22 PM   #1
will_0828's Avatar
Unhappy 00 v6 problem!!
WHEN I START THE CAR IT STARTS TO SHAKE I MEAN A LOT. IN REVERSE ITS FINE BUT THEN WHEN I START GOING FORWARD IT START AGAIN IT SEEMS LIKE ITS IN LOW RPM'S, ITS AN AUTO AND WHEN ITS IN (P) AND I GIVE HER A BIT OF GAS IT SHAKES ALOT, UNDER THE HOOD YOU CAN SEE THE ENGINE SHAKING IT SCARED ME :
BTW I NEED TO CHANGE THE SPARK PLUGS DU YALL THINK IT MIGHT BE THAT, (I DONT THINK SO)
CAN YOU LIST PLEASE GOOD SPARK PLUGS FOR MY STANG, ALSO ARE THOSE BOSCH SPARK PLUGS GOOD ?
THANKS GUYS
will_0828 is offline   Reply With Quote
Old 12-20-2009, 01:57 AM   #2
upton7's Avatar
Re: 00 v6 problem!!
Dood i'll be honest just go with the stock ford motorcraft plugs they won't cause you any problems. Go ahead and replace those if your sure they are bad of course you can just check a couple of them and make sure. They'll either be chipped on the white part or just look plain nasty.
Old 12-20-2009, 05:19 PM   #3
Re: 00 v6 problem!!
What year, mileage, and what have you recently replaced?
There is a whole list of things it might be, but before spending 200 dollars on alot of things let's try and narrow this down some.
Old 12-21-2009, 12:54 PM   #4
will_0828's Avatar
Re: 00 v6 problem!!
ita a mustang v6 2000 with 114000 miles i change the headers and intake but the problem was there before the mods
Old 12-21-2009, 01:28 PM   #5
Re: 00 v6 problem!!
change the spark plugs, change the plug wires (use the regular ones as aftermarket dont do anything different), and finally check the coil packs as they may be bad.
My daily driver has a v6 and has the coil pack setup like the 2000 mustang v6 has. When one went bad the engine would shake very bad and it would not run good. It was a misfire. A misfire can be a coil, a coil wire, or a spark plug.
Old 12-21-2009, 03:46 PM   #6
BIG_K's Avatar
Re: 00 v6 problem!!
really bad misfire with some possibly worn out motor mounts.
start with plugs and wires, and if it still does it, then get the coil pack.
00' Mustang : totaled
06' Mustang : DD
83' AMC Spirit GT: Weekend Warrior
BIG_K is offline   Reply With Quote
Old 12-21-2009, 07:30 PM   #7
Region: Iowa
Send a message via AIM to Horse Send a message via Yahoo to Horse
Re: 00 v6 problem!!
I agree with Big K. A moderate shake could be plugs and wires, but if it "scares you" I'd say it might very well be a broken or badly worn motor mount AND needing new plugs.
4.2L , CAI, BBK 65MM throttle body, 30lb injectors, SSM ported intakes, FLEX 1/2" spacer, RPM big valve heads, Comp roller rockers and cam, ASP-underdrive pulley, GT rear swaybar, & Quad Shocks, Full MM Coilover conversion, 17" Grey Torque Thrust wheels, FMS Aluminum driveshaft 8.8 rear w/ 3.73 gears, Tri-Ax Shorthrow shifter & SPEC stage II clutch w/ aluminum flywheel
Horse is offline   Reply With Quote
Old 12-21-2009, 07:50 PM   #8
Re: 00 v6 problem!!
Good call on the motor mounts, I have a customer who is having a major shuttering issue at any rpm over idle and I think that just might be it. Gonna have to give it a try, they've tried everything else.
Old 12-22-2009, 01:52 PM   #9
BIG_K's Avatar
Re: 00 v6 problem!!
had that problem with my stang! so look into it real good, cuz spending $40 bucks on motor mounts is way better than $120-$150 on plugs,coilpack and wires!
06' Mustang : DD
Old 12-22-2009, 04:10 PM   #10
00STANG00's Avatar
Send a message via AIM to 00STANG00 Send a message via Yahoo to 00STANG00
Re: 00 v6 problem!!
check engine mounds
SUCK MY DUST
00STANG00 is offline   Reply With Quote
Old 12-22-2009, 10:20 PM   #11
big show 98's Avatar
Re: 00 v6 problem!!
Had the same problem today with mine. The engine was shaking bad.The number two cylinder wasn't firing. Replaced the coil & problem solved.
big show 98 is offline   Reply With Quote
Old 12-23-2009, 06:51 AM   #12
Zebs5408's Avatar
Re: 00 v6 problem!!
i was gonna say check MOTOR MOUNTS just to be safe! my 3000gt has a bad motor mount and it shakes like that!
04' mustang 3.9 40th Anniversary Edition- (V2 Vortech Supercharger, 38# injectors, 3.73 gears w/ T-lok, Predator Diablo, Mac cold air intake, Port & polished upper AND lower intake manifold, Mac Long Tube Headers, Mac o/r H pipe, flowmasters, 2.5 flowmaster tips)
03' Mustang GT (20" Cobra R's, 40 series Flowmasters)
Zebs5408 is offline   Reply With Quote
97 A/C problem phaw16 1996-2004 Mustang GT 7 07-20-2009 12:39 PM
a/c problem 02MustangV6 Pre-2005 V6 Mustang 0 12-26-2006 02:44 PM
Problem.. lowflyn Pre-2005 V6 Mustang 15 07-25-2005 12:52 PM
» Members Mustangs
Sonya
akdoggie
Ted
whyxitx
Add your Mustang
12:13 PM
