Theft light, 2001 v-6 mustang - Mustang Evolution
Old 12-02-2005, 05:23 PM   #1
Hello, I just swapped a 2003 v-6 mustang engine into a 2001 mustang that had a blown 3.8 v-6. tried to start today and the engine wont run. Cranks but will not fire. Theft light in dash is flashing. Called ford and they say the 2001 computer wont run a 2003 engine. Does any one have any tips or do you believe Ford is correct.
860stevenp is offline   Reply With Quote
Old 12-02-2005, 10:25 PM   #2
Re: Theft light, 2001 v-6 mustang
Ford is probably correct...you might wanna get ahold of a newer ecu. It'd solve your problem.
Old 12-03-2005, 06:37 AM   #3
How does the computer know what engine is in there car? is has NO WAY to. Most likely you have a blown fuse somewhere, what does your odometer read? That engine will work fine in that car.
Justin Starkey
2007 Shelby GT500 705RWHP/708RWTQ
2000 Mustang 3.8 A4 TT 450RWHP/475RWTQ 10.996@127 17psi stock 3.8
2006 F250 CC 4x4 6.0L 14.3 @ 93
2006 Mustang 4.0 M5 Vortech 13psi 395RWHP/374RWTQ wife's car
justin00stang is offline   Reply With Quote
Old 12-03-2005, 07:46 AM   #4
Ha..ignore me...he knows what he's talking about lol.
Old 12-03-2005, 01:50 PM   #5
Thanks for your input.
Old 12-04-2005, 08:14 AM   #6
Roadhawg's Avatar
What other things did you do during the swap?
What wiring harness and sensors did you use?
Also did you happen to install the instrument cluster from the 2003 into your 2001?
2003 Mustang Mach1
1995 Thunderbird LX 4.6
1995 Mustang 4.2; MPX Supercharger/25%OD
Roadhawg is offline   Reply With Quote
Old 12-04-2005, 08:41 AM   #7
slvr2000stang's Avatar
The instrument cluster & the EEC are tied together with PATS.
A change of either can be fixed with a chip or tune.
Custom Delk motor now DOA
2003 SVT Lightning #1059 of 4270
2000 Vert 4R70W
Only buy from vendors that test and stand behind their products
slvr2000stang is offline   Reply With Quote
Old 12-04-2005, 09:07 AM   #8
I only swapped the engines, the new 2003 engine had the original wiring harness on it. So I dropped in the 2003 engine and the 2003 harness plugged into everything on the 2001 car. I didnt swap any thing else.
So its a 2003 engine and wiring harness in a 2001 car, 2001 computer, cluster etc.
Old 12-04-2005, 09:09 AM   #9
Would a swap of the wiring harnesses work ??? Put the original 2001 harness on the 2003 engine, then the only difference would be the engine itself. Or is there something else that will through it off.
Old 12-04-2005, 05:00 PM   #10
Roadhawg's Avatar
I would use the 2001 wiring harness. Even though it plugged in it may have a different pinout.
2003 Mustang Mach1
Old 12-04-2005, 06:05 PM   #11
Thats what Ive been thinking more and more, Sounds like if I use a newer computer in the car I may run into trouble with the instrument cluster and the PAT system. Thanks for your input.
Old 12-04-2005, 10:07 PM   #12
I liek gramer
WhiteStang99's Avatar
You can get a PATS bypass off of ebay for a few bucks.. ~$20ish
Dunno if that would help though.
Old 12-05-2005, 06:44 AM   #13
Thanks, it would at least narrow down the problems.
Old 12-05-2005, 12:56 PM   #14
I liek gramer
They're usually bought for remote start capabilities for alarms.
Old 12-05-2005, 06:35 PM   #15
thanks for all your help guys, I got it running today, it was plugged injectors on the 03 motor, it must have been sitting for awhile and had bad gas in it. Put in the 01 injectors and she fired right up.
Do these Fox body Mustang 5.0 cars have a high rate of theft? Mercedez L. 1979-1995 Mustang GT 17 06-05-2010 12:21 AM
Protecting the Mustang from theft Rich_Guy General Mustang Discussion 21 07-04-2009 09:44 PM
Theft Light? matthews.stang Pre-2005 V6 Mustang 5 05-22-2007 08:09 PM
New Way of ID Theft bluemustang The Bar 8 03-06-2007 03:04 PM
Theft light and key Angel Pre-2005 V6 Mustang 17 07-23-2003 03:18 PM
02:25 PM
