motor swap v6 to v8 - Mustang Evolution
Old 12-21-2009, 05:24 PM   #1
motor swap v6 to v8
hey i was thinking of not wasting my time with my stock 3.8l v6 that came with my 1998 mustang and putting a 5.0l in its place. i was wondering if anyone knew exactly what i would need to do this swap. thanks. and let me know what you think about my idea. thanks.
El Jefe is offline   Reply With Quote
Old 12-21-2009, 08:26 PM   #2
upton7's Avatar
Re: motor swap v6 to v8
If you have the mechanical ability and time and another car to drive and actually want to do it i think its a great idea as long as the motor you are putting in is worth that time.
Old 12-21-2009, 08:49 PM   #3
big show 98's Avatar
If you want to do it to look factory. All parts listed are for a 94-95 gt.
1. 5.0 h.o with 94-95 timing cover & front brackets,upper intake, engine & trans harness.
2. Throttle & cruise control cable.
3. One ac line.
4. Computer & harness with the vac lines that go inside the pass fender.
5. Computer will need to match the transmission style.
7. Auto you will need the a gt flexplate. (AODE )
8. T-5 you will need a gt flywheel,clutch, & bell housing.
9. 98 fan & rad should work fine. Fan is bigger than the 94-96gt's.
10. Fuel lines are the same. The fuel pump is ok for a stock 5.0
11. 8.8 will be needed soon.
This will give you a good idea where to start, I may have missed a few things.
big show 98 is offline   Reply With Quote
Old 12-23-2009, 06:49 AM   #4
Zebs5408's Avatar
im not sure never done it but please document it if you do it! take pics and even some video feed and maybe you can make it a sticky post on here! good luck man
04' mustang 3.9 40th Anniversary Edition- (V2 Vortech Supercharger, 38# injectors, 3.73 gears w/ T-lok, Predator Diablo, Mac cold air intake, Port & polished upper AND lower intake manifold, Mac Long Tube Headers, Mac o/r H pipe, flowmasters, 2.5 flowmaster tips)
03' Mustang GT (20" Cobra R's, 40 series Flowmasters)
Zebs5408 is offline   Reply With Quote
Old 12-23-2009, 07:07 AM   #5
you may can find a donor car (94-95 GT) for around 1-2k at a junk yard. Then you will have all you need. Rebuild the engine and drop it in then the rear. If you have a manual T-5 it will work with, if not GET ONE lol dont do it with an auto.
Old 12-23-2009, 09:06 AM   #6
when i start i will document
03' motor and tranny swap with 98' GT PLEASE HELP!!! BAttitude7689 1996-2004 Mustang GT 10 01-20-2010 06:33 PM
2003 3.8 swap 2001 4.6 motor mustang0386 Pre-2005 V6 Mustang 3 06-16-2009 10:18 AM
Motor Swap Help IbleedBlue General Mustang Discussion 2 03-12-2008 06:18 PM
Motor Swap coolstang 1996-2004 Mustang GT 1 04-20-2005 09:04 PM
Motor swap question. ShwoffGT 1996-2004 Mustang GT 32 02-21-2005 09:57 AM
10:01 PM
