PATS, 2001 V-6 Mustang - Mustang Evolution
Old 12-03-2005, 08:28 PM   #1
Does the PATS Still allow the engine to crank over, or does it deactivate everything.
860stevenp is offline   Reply With Quote
Old 12-03-2005, 08:40 PM   #2
Re: PATS, 2001 V-6 Mustang
Does anyone know for a fact if a 2003 V-6 3.8 L Engine harness is not compatable with a 2001 mustang V-6 3.8L Computer. I know for a fact that all the harness plugs matched and plugged right in. Ford tells us that some of the wiring may be different on the 2003 harness, causing the engine not to run. I did the swap and the theft light is flashing with the ignition off, the service engine light is on, the engine turns over good, trys to fire, builds fuel pressure, but will not fire and run. Already tried the magic red reset for the fuel pump (didnt work as I expected) Please need some Tech Help. Before I try any thing else.
Old 12-03-2005, 08:44 PM   #3
Ford says I need to buy a 2003 computer, I thought I might try swaping the wiring harnesses. Put the 2001 Harness on the 2003 engine. Or maybe pull the engine and just use the long block with all the 2001 components, intake, wiring etc. Ford also says a new computer is $1500 and would take lots of programing to make it work.
Old 12-03-2005, 09:09 PM   #4
Ford is full of the good stuff.
email Sales@VMPtuning.com and ask them about it
Old 12-04-2005, 08:25 AM   #5
Will Try E-mailing them Thanks For the suggestion.
Old 12-04-2005, 08:59 AM   #6
I E-mailed the link you gave me and explained everything I have done in detail, hopfully they will have some advice. I dont plan on doing anything else until I get some facts that make sense. THAKNS AGAIN. STEVE.
Old 12-04-2005, 08:57 PM   #7
all 01-04 should be the same
PATS just doesn't let injectors fire, the engine will still turn over
Justin Starkey
2007 Shelby GT500 705RWHP/708RWTQ
2000 Mustang 3.8 A4 TT 450RWHP/475RWTQ 10.996@127 17psi stock 3.8
2006 F250 CC 4x4 6.0L 14.3 @ 93
2006 Mustang 4.0 M5 Vortech 13psi 395RWHP/374RWTQ wife's car
justin00stang is offline   Reply With Quote
Old 12-04-2005, 09:04 PM   #8
Do you believe that swapping the wiring harnesses over (put the 2001 harness on the 2003 engine) will correct the problems. This way the harness will be 2001 the computer will be 2001, just the engine will be 2003.
Old 12-04-2005, 09:08 PM   #9
One ford guy says that the pin out put is different on the o2 sensors and that the 2003 engine is tuned alittle differently. And thats why it will not run. I am afraid that if I put in a 2003 computer that it will not read the instrument cluster OK, still giving me the same problem with the PATS
Old 12-05-2005, 06:19 PM   #10
Smile Re: PATS, 2001 V-6 Mustang
Thanks JUSTIN00STANG You the man, you helped us out so much. You were right go back to the basics and check fuel, spark, grounds, all harnesses ETC... Within 5 mins we pulled the plugs and spun er over and found that fuel was only coming out of 2 cylinders. We pulled the top intake and the injectors and found 4 out of the 6 were plugged with bad gas. I guess the 03 motor has been sitting for awhile. replaced the injectors with the ones off the 01 motor and she fired right up and was running great. No check engine lights and no leaks anywhere.
The only problem now is the car has no heat, the thermostat is opening but the water pump does not seem to be moving water. Belt is on right, So I believe we have air in the system. Tomorrow we will try and bleed the coolant system better. We did open the bleeder on top, got some air out. But still must be more. Thanks again, you saved us a million......................
Old 12-05-2005, 06:28 PM   #11
Glad to see you solved your problem!!!
Old 12-05-2005, 06:32 PM   #12
Thanks Brent, this forum has been great. Let me know if you have any tips on my cooling problem, like is there a trick to figuring out if the water pump is bad.
Old 12-05-2005, 06:33 PM   #13
slvr2000stang's Avatar
Cool.
Open the bleeder with it running until you get a stream of coolant running out.
You may have to do it several times. Also make sure the heater is turned on while doing this.
Custom Delk motor now DOA
2003 SVT Lightning #1059 of 4270
2000 Vert 4R70W
Only buy from vendors that test and stand behind their products
slvr2000stang is offline   Reply With Quote
Old 12-05-2005, 06:34 PM   #14
bleeding that thing is a *****
Justin Starkey
Old 12-05-2005, 06:38 PM   #15
Thats what I thought, we will try and get-R-bleed tomorrow.
Old 12-05-2005, 06:39 PM   #16
Is there any way to no if you have a bad water pump
Old 12-05-2005, 06:40 PM   #17
Originally Posted by slvr2000stang
Cool.
Thanks for the tips will definitly do so.
Mustang PATS system? kenneth01GT General Mustang Discussion 5 07-07-2009 09:39 AM
How 'bout them Pats? 04MonteSS The Bar 33 01-23-2008 08:53 AM
w00t, pats 13-2 Rellik The Bar 4 12-27-2003 08:18 PM
pats pats pats! Rellik The Bar 14 08-08-2003 05:04 PM
02:14 PM
