Going to drop the oil pan and replace end seal Monday need some info - Mustang Evolution
Old 12-07-2005, 09:00 PM   #1
I went out and bought this: Fel-Pro Oil Pan Gasket OS30625R for an Automatic
2001-1982 Ford V6 232ci 3.8L; 1995-1989 Ford V6 232ci 3.8L Supercharged; 2000-1995 Ford Truck Light Duty V6 232ci 3.8L; 2000-1997 Ford Truck Light Duty V6 256ci 4.2L; RTV Black silicone with Rubber end seal.
When I take the oil pan off where is the end seal going to be? How hard is it to replace? Is there anything else I should be looking out for?
Old 12-07-2005, 10:12 PM   #2
Re: Going to drop the oil pan and replace end seal Monday need some info
the oil pan seal? dude drop the oil pan by removing all the bols then clean the mating surfaces, lay down new gasket put in a bolt at each corner to keep it stable, bolt it back up. your done. might as well change the filter while your at it.
Old 12-07-2005, 10:34 PM   #3
... I am replacing the rear seal in the tranny.
The oil pan doesn't have a gasket on it, it has silicone.
Old 12-07-2005, 11:54 PM   #4
you may use gaskets on oil pans.
in the first post you put oild pan gasket.
do you mean the seal that goes around the tail shaft or the gasket that mates the tail shaft housing to the tranny case, im not sure if the aod has the TS housing integral or not
Old 12-08-2005, 12:04 AM   #5
This is what I got
ID:	11627   Click image for larger version
Old 12-08-2005, 12:18 AM   #6
This is what I got
man thats the rar seal where the output shaft rides, does the aod have an integral tail shaft housing? if it does not, it would be easier to do if you take out the tail shaft housing
Old 12-08-2005, 12:23 AM   #7
I have no idea....
but they said that I just use the silicone on the oil pan before I put it back on and that they dont sell a actual gasket for it.
How much of a problem is it to take the tail shaft housing off?
Old 12-08-2005, 09:24 AM   #8
I have no idea....
4 bolts to take off the tail shaft housing, one at each corner. but it might be integral
you can use silicon on the oil pan , i just prefer using gaskets, rtv smells so horrible.
they should sell gaskets for the pan i have bought them before.
Old 12-08-2005, 01:44 PM   #9
Integral means....?
Old 12-08-2005, 06:31 PM   #10
Integral means....?
that it is part of the case, thats how the metal was molded, it is not detachable
Old 12-08-2005, 10:00 PM   #11
and if that is the case... how do I change it?
Old 12-09-2005, 12:06 AM   #12
take off drive shaft and press it in there.
need help removing my oil pan! jkaminski24 1996-2004 Mustang GT 7 08-23-2010 05:54 PM
OIL PAN REMOVAL MR.PEE Pre-2005 V6 Mustang 2 05-01-2008 07:00 PM
Oil pan question... lowflyn Pre-2005 V6 Mustang 9 03-15-2006 06:14 PM
Possibly found metal in my oil pan!!! Horse Pre-2005 V6 Mustang 5 09-23-2005 01:39 AM
Punch a hole in my oil pan for my vortech danstang Pre-2005 V6 Mustang 20 07-20-2005 08:28 PM
11:05 AM
