Best Spark Plugs For a 2003 3.8L V-6 - Mustang Evolution
Old 12-09-2005, 03:40 PM   #1
Which are the best plugs to run in a 2003 V-6 3.8L (Stock Engine).
1-Bosch Platnum?????????
2-MotorCraft????????????
3-Autolite???????????????
4-Other
And what reasons do you have for the Plugs you recommend............
860stevenp is offline   Reply With Quote
Old 12-09-2005, 03:54 PM   #2
slvr2000stang's Avatar
Re: Best Spark Plugs For a 2003 3.8L V-6
I run Motorcraft copper.
You have to change them more often but their performance is better & cost a lot less than Platinums.
Custom Delk motor now DOA
2003 SVT Lightning #1059 of 4270
2000 Vert 4R70W
Only buy from vendors that test and stand behind their products
slvr2000stang is offline   Reply With Quote
Old 12-09-2005, 03:56 PM   #3
The Ford Dealer told us that alot of people have problems with the Bosch plugs, I`m just wondering if they are just blowing more smoke.
Old 12-09-2005, 03:58 PM   #4
Problems in the mustangs, due to the heat range.
Old 12-09-2005, 04:11 PM   #5
I`ve been reading the forums and found most people dislike the Bosch plugs, except for a few..... I will go with the majority, Autolites or MotorCraft............
Old 12-09-2005, 04:11 PM   #6
Thanks......................
Old 12-09-2005, 04:13 PM   #7
Autolite are my second choice.
2000 Vert 4R70W
Old 12-09-2005, 04:37 PM   #8
SonicV616's Avatar
Send a message via MSN to SonicV616 Send a message via Yahoo to SonicV616
Do Mustangs heat up quickly or something?
SonicV616 is offline   Reply With Quote
Old 12-09-2005, 04:51 PM   #9
I know mine sure doesn't.....lol. I think he's talking about the spark temperature not being consistant with that certain plug. I run autolites in my car, never had a problem other than regapping when it gets cold/ hot
Old 12-09-2005, 05:07 PM   #10
run the OEM's they work just as good as any of them
Old 12-09-2005, 07:44 PM   #11
LOL too, thanks for the input............ I a`m going to switch to Autolites, or motorcrafts, the engine is detecting a misfire once in awhile and is most likely due to the plugs. Bosch Platniums. We had just put the plugs in and the original MotorCrafts didnt do that. THANKS FOR ALL THE INPUT..........
Old 12-10-2005, 09:25 PM   #12
DarkShadow's Avatar
Send a message via AIM to DarkShadow
The stockers are just fine, I've heard of problems with Bosch, Autolite, ACDelco, Champion, etc. but not Motorcraft.
DarkShadow is offline   Reply With Quote
Old 12-12-2005, 06:40 AM   #13
dark's Avatar
Send a message via AIM to dark Send a message via Yahoo to dark
i've got autolites in mine and have no problems. just make sure you space the spark gap correctly
I don't own a mustang at the moment
dark is offline   Reply With Quote
Old 12-12-2005, 06:56 AM   #14
No but if the heat range of the plug is higher than normal it can cause pinging.
With advanced timing I actually run 1 heat range cooler plugs.
2000 Vert 4R70W
Old 12-13-2005, 08:11 PM   #15
Region: New Mexico
Send a message via MSN to miwago
A simple copper or a good hybrid plug like an Autolite Platinum.
I'd say anything OTHER than a Bosch Platinum. I tried running them in my '98, and the electrodes burned up into the ceramic in 6,000 miles.
I learned, on another site, that oddly enough, half of the cylinders (drivers side) fire their plugs from the electrode to ground(normal), and the other half (passenger side) from ground to the center electrode(reversed). It has to do with the way the coil pack fires.
This (reverse polarity) also seems to cause Bosch Platinums to burn up faster.
'98 T-5, 3.8 .. Ebay CAI, 25% 2 pulley UDP, 1.8 roller rockers 19 lph inj's, Xcal2, Reworked-ported upper intake, Full emissions delete, Dual 2.5" exhaust,2" drop Future mods:4.2 stroker kit, Locker diff w/3.73's, 18" Bullit wheels
miwago is offline   Reply With Quote
Old 12-13-2005, 08:13 PM   #16
Yeh, bosch sucks on hte v6
Old 12-14-2005, 03:30 PM   #17
i wouldnt get anything but motorcraft platinum (stock). i got autolites a couple months ago because they were out of motorcraft... i thought my engine was going to die. i had to change them out after a week or two. i put motorcraft platinum in and never had another problem
1999 3.8 V6 Electric Green Mustang
5 speed
Mods: MAC Dual Catback Exhaust, MAC Shorty Headers, CAI, Sequential Taillights, 03 17" Cobra Rims
My Garage
electricstang is offline   Reply With Quote
spark plugs v6stang04 Pre-2005 V6 Mustang 4 01-24-2010 06:22 PM
What spark plugs should I go with? Frogleg 1996-2004 Mustang GT 30 06-21-2009 03:44 AM
Which spark plugs should I use??? koch_A_tyler 1996-2004 Mustang GT 5 03-18-2008 06:36 AM
Spark Plugs megax29 Pre-2005 V6 Mustang 20 10-09-2006 05:36 PM
Spark Plugs megax29 Pre-2005 V6 Mustang 13 03-25-2006 07:51 AM
06:22 AM
