PCM question...car's not starting! - Mustang Evolution
Old 12-12-2005, 09:49 AM   #1
Unhappy PCM question...car's not starting!
Okay, I give up. I don't have a clue what's going on. Here's my problem. The fiance ran the car out of gas in my driveway (maybe coincidence but I'll start there). She put a gallon of gas in, car cranked, went to the gas station, car cranked there, came home...no more crank! At first, I thought it was the fuel pump or filter. Neither...engine's getting gas. Then, I thought it was the corroded battery terminals. Changed those and cleaned the posts. Battery is reading 12.4 so it's not that. My only other thought was that it was a sensor somewhere but the car isn't throwing a code or a check engine light. Just to be safe, I rented an OBDII scanner and when I connected it, it read that there was a problem linking to the ECU. I thinkn this is my problem...bad PCM. I bought a new one and went to go replace it but I can't find it! My shop manual says it's under the driverside dash in the corner but...I don't see it! So I have a couple of questions for the gurus: '95 Mustang 3.8L...if not the PCM, what else could be wrong? If it is, where's the $^^$%$#$# thing? Thanks in advance for your help, guys!
Oxygenetic is offline   Reply With Quote
Old 12-12-2005, 05:30 PM   #2
Re: PCM question...car's not starting!
Did you hit the fuel pump reset button in the trunk? And the ECU is located behind the passenger side kick panel, behind wires, bolted to about a billion things. But it's back there.
Old 12-12-2005, 05:30 PM   #3
slvr2000stang's Avatar
It's the the right of the passengers feet behind the kick panel.
Custom Delk motor now DOA
2003 SVT Lightning #1059 of 4270
2000 Vert 4R70W
Only buy from vendors that test and stand behind their products
slvr2000stang is offline   Reply With Quote
my car's new look hottcobra 2005-2010 Mustang GT 68 03-11-2009 09:12 PM
Question regarding PCM flashing 05bluestang 2005-2010 Mustang GT 8 01-27-2008 09:23 AM
Video of my car's hard starting Kiljosh Pre-2005 V6 Mustang 15 06-14-2006 05:25 PM
98' V6, 3.8 AUTO PCM PART#??? alexx_302 Pre-2005 V6 Mustang 0 01-23-2006 03:27 PM
Getting my PCM out Brent Pre-2005 V6 Mustang 5 07-07-2004 09:10 AM
07:32 PM
