O/D Off flashes on and off - Mustang Evolution
Old 12-13-2005, 06:37 PM   #1
It has only done it once so far. I just got the car back from getting the gasket on the tailshaft replaced and I was coming home and it just started flashing on and off. It hasnt done it since I turned the car off and started again but I am just curious as to what will cause that?
Old 12-13-2005, 06:40 PM   #2
slvr2000stang's Avatar
Re: O/D Off flashes on and off
It usually signals a trans problem. Sorry for not being specific.
I would say drive it & if it does not come back you are ok.
Custom Delk motor now DOA
2003 SVT Lightning #1059 of 4270
2000 Vert 4R70W
Only buy from vendors that test and stand behind their products
slvr2000stang is offline   Reply With Quote
Old 12-13-2005, 08:48 PM   #3
Just took it for a drive and the son of a ***** came back on. I am starting to get pissed with this car. I just got it back from having it serviced and a gasket on the tailshaft replaced.
I just took the positive battery cable off and plan to leave that off overnight to see if that might be it.
As far as I can tell the tranny shifts fine.
Old 12-13-2005, 09:02 PM   #4
Brent,
Something I found.
It means the EEC has detected a problem with the transmission, or the control circuits. The most frequent cause is overheated ATF
2000 Vert 4R70W
Old 12-13-2005, 09:14 PM   #5
Brent, just go ahead and put the 5 speed in.
Old 12-13-2005, 09:29 PM   #6
Originally Posted by slvr2000stang
Brent,
Something I found.
How can it be overheated?!?!? It just got serviced and has fresh tranny fluid in it.
And Brad if you want to give me the 1100 dollars to buy the 5speed swap then I will.
Old 12-13-2005, 09:41 PM   #7
Is the fluid circulating properly?
2000 Vert 4R70W
Old 12-13-2005, 09:42 PM   #8
I am going to have to jack it up tomorrow and look at it while running.. I dont understand why it wouldn't be...
Would it throw any check engine light codes if that was the case? My chip has the check engine light turned off I believe so I wouldnt know.
Old 12-13-2005, 10:35 PM   #9
has your tranny been slipping at all? that would cause some overheating.
check the trouble codes.
Old 12-13-2005, 10:46 PM   #10
No slipping.
It shifts fine as far as I can tell....
I mean I literally drove it away from the transmission shop got to school then on the way back from school it came on......
Old 12-13-2005, 10:54 PM   #11
19ClearCobra96's Avatar
Region: Nebraska
Send a message via AIM to 19ClearCobra96 Send a message via MSN to 19ClearCobra96
I would drive that **** right back and say WTF
19ClearCobra96 is offline   Reply With Quote
Old 12-13-2005, 11:03 PM   #12
get the codes read
Old 12-13-2005, 11:42 PM   #13
I am
Old 12-14-2005, 09:46 AM   #14
scan the codes to see if there is anything pending that has not set the actual light, but turning off the CE light with a chip is not something that is usually done
Justin Starkey
2007 Shelby GT500 705RWHP/708RWTQ
2000 Mustang 3.8 A4 TT 450RWHP/475RWTQ 10.996@127 17psi stock 3.8
2006 F250 CC 4x4 6.0L 14.3 @ 93
2006 Mustang 4.0 M5 Vortech 13psi 395RWHP/374RWTQ wife's car
justin00stang is offline   Reply With Quote
Old 12-14-2005, 03:15 PM   #15
check the fluid, they may have not put enough in it and it may be low who knows... its an easy thing to check.
Old 12-14-2005, 03:25 PM   #16
Its got enought fluid I checked that first
Old 12-15-2005, 04:48 PM   #17
Alright took it back up there.
He hooked it up to a code reader WHILE THE DAMN LIGHT WAS FLASHING
and it did not spit out any code about the tranny, just the usual engine codes I have grown to love owning Fords (EGR)
So what now? The car shifts fine, there are no codes pertaining to the tranny while it is flashing.... is there any sensors I need to check?
If so where?
Old 12-15-2005, 11:01 PM   #18
DarkShadow's Avatar
Send a message via AIM to DarkShadow
Maybe a short in the sensor itself? Bad light? If everything thing is fine, I think the sensor itself is suspect. It's about time for all of your sensors to go out at once anyway...
DarkShadow is offline   Reply With Quote
Old 12-15-2005, 11:10 PM   #19
Where is the censor that controls this? It is possible we hit it pulling up onto the trailor or maybe it was shorted when we drained the tranny fluid.
I need to know where to look
Old 12-16-2005, 12:13 PM   #20
Ive heard that when it flashes like that it can mean that your CPS is melting (melted) so you might want to check that.
Old 12-20-2005, 07:27 PM   #21
Joel5.0's Avatar
Since the problem started after replacing the tailshaft gasket, check the two speed connectors in the back of the tranny....one is the Vehicle Speed Sensor (VSS) and the other is the Output Shaft Speed (OSS) sensor. A problem with either one should have showed up in the scan though.
The other reason for the O/D to blink is to have a problem with the EPC solenoid, it should show up in the scan also. Looks to me like they might be avoiding responsibility. My 2
1986 Mustang GT w/T-Tops :angryfire
NOW: 5.0L Stock shortblock, X303 Cam, SP Offy. Port-O-Sonic, 700 cfm DP Holley, 289 '66 Small Port Heads, 1.7 RR, Richmond Gear 4+1 Trans., Centerforce DF kit, 2.73 Gears
WIP: 3.90 Gears, LS Overhaul, Adj. LCA's (New Design Granatelli Aluminum), Adj. UCA's (Granatelli), New Valve Springs (FRPP, done), Subframe Connectors (MM), Caster/Camber Plates (MM), T-Top weatherstriping and rear braces bodywork :cussing:
Joel5.0 is offline   Reply With Quote
Old 12-21-2005, 12:08 AM   #22
I was there when he scanned the codes. It only turned up engine problems.
I was told that my CPS problem could cause it to go off.
The CPS problem is being fixed as we speak so we will see when I get my car back.
Old 12-21-2005, 06:03 AM   #23
Make sure the EEC is reset after the repair and let us know what happens.
2000 Vert 4R70W
Old 12-23-2005, 03:12 PM   #24
Ignition Coil pack.
Car is fixed
Old 12-23-2005, 06:37 PM   #25
That is good news.
2000 Vert 4R70W
Need some help.. when key is on the ON postion check engine light flashes Brent Pre-2005 V6 Mustang 11 11-14-2006 01:23 PM
Jump out and scare you Flashes Ken The Bar 6 12-21-2005 07:07 AM
05:34 AM
