Economy Minded V6 - Mustang Evolution
Old 12-18-2005, 02:39 AM   #1
Question Economy Minded V6
Is there a past thread that discusses the best way to get the most MPG from a V6 or can anyone suggest the best add-ons to do (besides lowering your speed)?
Eddied
eddied is offline   Reply With Quote
Old 12-18-2005, 03:20 AM   #2
Re: Economy Minded V6
What year is your car?
How many miles do you have on it?
Old 12-18-2005, 08:52 AM   #3
KyleUSAF's Avatar
Send a message via AIM to KyleUSAF Send a message via MSN to KyleUSAF
rear seat delete, aluminum ds can help reduce weight...
Originally Posted by Darkshadow
I could say nothing for my complete awe. He then. confidantly, purchased the gallon.
KyleUSAF is offline   Reply With Quote
Old 12-18-2005, 10:21 AM   #4
pretty much whats above^ but a CAI can also help. running injection cleaner and 87 octane in it will also help. i run injection cleaner every oil change~
change the fuel filter every year~ and other regular stuff. I get 22-23mpg with my modifications(gears cut down on the mpg so keep that in mind)
Old 12-18-2005, 11:07 AM   #5
Send a message via AIM to white95v6
well a pulley and dual exahust helps. a tune can help sometimes.
umm lets see. my 3.8L got 32mpg when stock with dual exhaust.
then i did ported intakes and pulley still got 30-31mpg.
then i added 3.45 gears. and i got like 25-27mpg.
then i added ported heads,Cam and more agressive intake. i got 23-25mpg.
then i added 4.30 gears still got 23-25mpg.
umm then i built a low compression 4.2L and still got 23-25mpg. a month afterwards i did a tubular front suspension to drop weight. this didn't seem to help with my fuel mileage at all.
ok this is when it changed alot. i did my turbo kit and then installed 3.55 gears. for the one week end that it was still a 5spd. i got 21-23mpg and that was with me getting into boost around everycorner.
then i installed a C4 trans(no overdrive) i then got about 15mpg. once i get this converter set-up right i think i will see about 18-20mpg with this set-up.
The First and Only 9 Sec Production Based V6 Stang!!,First over 500rwhp,First and only over 600rwhp
60ft-1.42,1/8th mile-6.25@111mph,1/4 mile-9.83@136.65mph
Sponsored by:
WWW.DELKPERFORMANCE.COM
white95v6 is offline   Reply With Quote
Old 12-19-2005, 07:14 AM   #6
For the best MPG I would say a UD pulley and special MPG tune. I think with those two things you could see a 2-4mpg increase.
Justin Starkey
2007 Shelby GT500 705RWHP/708RWTQ
2000 Mustang 3.8 A4 TT 450RWHP/475RWTQ 10.996@127 17psi stock 3.8
2006 F250 CC 4x4 6.0L 14.3 @ 93
2006 Mustang 4.0 M5 Vortech 13psi 395RWHP/374RWTQ wife's car
justin00stang is offline   Reply With Quote
Old 12-19-2005, 07:44 AM   #7
99% of the V6's get high teens to low twentys in gas milage. The pre 99s got better due to gears mainly. The 99 up's dont expect more than 25-27~ average. A tune can definatly help.
Old 12-19-2005, 10:36 PM   #8
Checkmate's Avatar
Region: Nevada
I just drove from Las Vegas to Ohio, Each tank refil I listed the Milage and how much fuel I used, and the best I got was 29.5 mpg at 75 MPH. I have read my 1996 V6 Mustang was the best mpg stock and I must agree it was.
I used 94 gallons to travel 2,612 miles.
I got about 26 to 27 MPG in the mountains.
Checkmate is offline   Reply With Quote
Old 12-19-2005, 10:38 PM   #9
That is not too shabby.
Is your car stock?
Old 12-19-2005, 11:15 PM   #10
Checkmate's Avatar
Region: Nevada
it is 100% stock, About a year ago I did a head gasket job ( we all know why ) and replaced almost everything under the hood with stock, Now my fan motor went out in the long drive but it was so cold I didn't need it, now they want $130 for a Motor, I will see if I can get one used on eBay or a junkyard before I pay $130 just for a Fan motor.....
Anyone got a spare??
Old 12-19-2005, 11:19 PM   #11
I recall paying far less for a fan motor at Autozone when mine went out on the 95 I owned.
How many miles are on your car?
Old 12-19-2005, 11:21 PM   #12
Checkmate's Avatar
Region: Nevada
126k Miles and Autozone was $130ish
Old 12-19-2005, 11:23 PM   #13
That is pretty impressive right there? 1 Owner? Head gasket the worse problem you have had out of it?
Old 12-19-2005, 11:27 PM   #14
Checkmate's Avatar
Region: Nevada
2 owners, I bought it at 105k in 2003 and I guess he used head gasket sealer, When I tore the top end apart it was clearly blow thru and the radiator got replaced when I seen the sealer and I flushed out the system. Only took me 2 days, 6 hours a day to do the work with the wife as a 2nd set of hands. I beat on the vehical for a year and decided it was up to the trip, thru Oklahoma I was doing about 110 mph for over 1 hour, and no issues.
Old 12-22-2005, 08:42 PM   #15
Very very impressive man. Sounds like your car is more reliable than my 02 lol. Nah, I wouldn't hesitate one bit to drive anywhere in my car, barring ice. But then again, my car only has 70k.
Old 01-06-2006, 11:22 PM   #16
Checkmate's Avatar
Region: Nevada
well my trip back to nevada starts Sunday from Delaware, I made my trip thru NYC and Long island and still running with the bad Fan motor, LOL. But as long as I drive over 25 mph I dont over heat ( I havent overheated yet - came close tho in the Holland Tunnel Entrance) When I get to vegas and that 70 to 80 Degree Heat I think that might change. I will need to get a fan motor asap. I just Hope I keep getting over 27 mpg like I was. Gas prices are going up and it will cost me over $215 in fuel with the 2510 miles I need to cover. Wish me luck
Space isn't remote at all. It's only an hour's drive away if your car could go straight upwards.
[MEDIA]http://www.elitegeeks.com/images/checksmustang.jpg[/MEDIA]
Old 01-07-2006, 07:58 AM   #17
RGR
Send a message via AIM to RGR
I'm making a new post on mileage:
http://www.mustangevolution.com/foru...tml#post278972
check it!
Originally Posted by Flex:
You are the true cam master dude...
RGR is offline   Reply With Quote
Old 01-07-2006, 10:37 AM   #18
Haha, sounds like a drive.
Old 01-11-2006, 05:51 AM   #19
Checkmate's Avatar
Region: Nevada
28 mpg ( 80 mph Average ) Delaware to Las Vegas 38 hours - I did hit a Construction Cone in my last 75 miles of trip, it broke my Power Mirror but I ordered a new set on eBay
http://cgi.ebay.com/ebaymotors/ws/eB...tem=8028714675
3:73 gears-less economy? jimbullit 2011-2014 Mustang GT 17 10-21-2010 07:42 AM
How About That Economy? Brent The Bar 9 09-29-2008 09:23 PM
New Economy Standards Thomas91169 General Car Discussion 15 06-24-2007 09:12 AM
Fuel Economy fossen Pre-2005 V6 Mustang 4 04-11-2007 06:53 AM
For all of you sick minded people out there *WW* Rellik The Bar 14 07-17-2003 11:49 AM
12:39 AM
