AC Clutch - Mustang Evolution
Old 12-20-2005, 12:43 AM   #1
Checkmate's Avatar
Region: Nevada
AC Clutch
Is a AC Clutch supposed to engage when the heat is on? I put it on Floor with the heat all the way on and I noticed my AC Compressor still kicks in ....
Checkmate is offline   Reply With Quote
Old 12-21-2005, 05:09 PM   #2
Re: AC Clutch
I believe it should...if you think about it something has to compress the air enough to blow it out.
Old 12-22-2005, 06:54 AM   #3
Checkmate's Avatar
Region: Nevada
Re: AC Clutch
uh?? :stupid:
The Clutch on the AC Compressor has nothing to do with the Blower in the Dash.
See when the Temp needs to be cold the A/C Compressor Kicks in to Compress the R134 into a Liquid then it goes to the area where the blower is and Evaporates into a gas that Draws the heat out of the air, this seems to defeat the logic of heating the car.
I think what I will do is Disconnect the Power to the Compressor in the winter.
Space isn't remote at all. It's only an hour's drive away if your car could go straight upwards.
[MEDIA]http://www.elitegeeks.com/images/checksmustang.jpg[/MEDIA]
Old 12-22-2005, 10:10 PM   #4
Re: AC Clutch
Well **** nevermind then, glad you cleared that up for yourself.
Old 12-23-2005, 09:56 AM   #5
232stang01's Avatar
Send a message via AIM to 232stang01 Send a message via Yahoo to 232stang01
Re: AC Clutch
Reminder:
It's a good idea to run your A/C a few times in the winter, just to keep oil on all the seals and O-rings. It would suck to kick the A/C on for the first time in the summer only to find out that you lost your refrigerant charge to a dried out O-ring.
(sorry, slightly off topic)
232stang01 is offline   Reply With Quote
Old 12-24-2005, 10:22 PM   #6
Checkmate's Avatar
Region: Nevada
Re: AC Clutch
Its not like the A/C Pump runs alot, just every now and then for a few seconds... Like it is just maintaining a little presure. Being in Las Vegas I run the A\C 9 months out of the year and sometimes more, Maybe it forgot that in the Cold it needs to not run
Old 12-25-2005, 01:31 AM   #7
Kiljosh's Avatar
Re: AC Clutch
You got owned by Lowflyn
clutch help guerrerosal Pre-2005 V6 Mustang 4 03-22-2009 12:19 PM
need a clutch and... DarkShadows 1996-2004 Mustang GT 12 01-02-2009 12:54 PM
New clutch electricstang Pre-2005 V6 Mustang 2 05-22-2006 04:04 PM
best clutch ? jedwards242000 Pre-2005 V6 Mustang 5 04-09-2005 04:21 PM
Clutch Murph00 Pre-2005 V6 Mustang 2 06-30-2004 05:00 PM
08:35 PM
