ignition coil - Mustang Evolution
Old 01-06-2010, 06:40 PM   #1
v6stang04's Avatar
ignition coil
will an ignition coil do better than the stock one? i know theres 2 different parts that begin with coil, but one is coil pack, and idk where that would go. and the ignition coil is for the spark plugs and wires. what is the purpose of a coil pack, and where does it go?
04 v6 gun metal grey
bbk cai, bbk 65mm throttle body, bbk shorty headers, straight pipes, 18x9 front 18x10.5 rear rims, gt bumper, red neon underglow, ford racing lsd with t-lok, summit racing tuner
v6stang04 is offline   Reply With Quote
Old 01-08-2010, 02:20 PM   #2
96mustang21's Avatar
Re: ignition coil
someone correct me if im wrong i think some people say coil pack and some say ignition coil same thing. but if u want to upgrade to a better pack heres a link ive heard good things about these
Mustang Engine Parts 1994-2004 at V6MustangStuff.com
96 v6 bottom end, sc heads, eaton m90, sc tb, bbk headers,custom tru dual 2.75 exhaust H-pipe flowmaster 40s, sc 8 rib belts,egr delete,5 speed, etc etc.
96mustang21 is offline   Reply With Quote
Old 01-08-2010, 07:39 PM   #3
SonicBlueV6's Avatar
Re: ignition coil
Those are two different parts. An ignition coil is one coil for all the spark plugs (usually in a carb engine) a coil pack has many smaller coils in a pack (one for each plug, usually in a FI engine). Just go with the Accel Coil Pack, it works great for me.
2003 Ford Mustang 3.8L V6
Current Mods: SCT 4 Bank Chip, K&N CAI, 25% UDP, ZEX 75 Wet Shot, MSD 8.5mm Wires, Autolite XP Iridium Plugs, BBK Shorty Headers, Flowmaster Super 44 Muffler, 3.73 Rear Gear, Ford Racing T-Lok, 18x9 Saleen Chrome Rims Front, 18x10 Saleen Chrome Rims Rear w/Nitto 555R Drag Radials (Track).
SonicBlueV6 is offline   Reply With Quote
Old 01-09-2010, 05:49 AM   #4
Re: ignition coil
a coil pack is an ignition coil when i worked at advance and someone come in and said i need a coil pack i had to look up ignition coil. if u go to advanceautoparts.com and type in coil pack it will say sorry no results if u go to anwers.com and type in coil pack it will redirect u to ignition coil and if u scroll down and read what it says unless i misread its commonly called coil pack on modern vehicles because theres more than 1. and all this talk about coil packs got me thinking about my no spark problem i do believe u just helped me solve my problem thanks sonic
Old 01-09-2010, 11:54 AM   #5
v6stang04's Avatar
Re: ignition coil
well if you go to american muscle and type in coil pack, it brings up 2 different parts. the 1st few parts are of a block looking thing, with the tips of where the wires plug into. and if you go down further, theres just wires with a small cylinder looking thing at the end, what is that, cause they call that a coil pack as well. if anyone can tell me what the difference in them let me know.
Old 01-09-2010, 01:36 PM   #6
Re: ignition coil
i have never researched these i thought u could only use these on ohc engines i dont know but they are coil on plug each plug gets its own coil they eliminate wires according to accel they give you hotter spark so you burn off more fuel in the cylinders inreasing power and fuel economy i found this site they explain them
Coil-On-Plug Ignition
Old 01-09-2010, 01:56 PM   #7
Re: ignition coil
The coil-on-plug is a different part but they are all ignition coils, they are just made differently. The standard ignition coil is just a bigger coil for all the plugs, the coil pack is a pack of coils and has one coil for each plug (like the one for the 99-04 3.8 V6). The coil-on-plug is exactly what the name says it's a coil on the plug wire, I think that's the kind that is used on 99-04 GT's.
Coil on Plug Ignition Coil Pack Set (8) 99-04 Mustang W/ Wiring Harness Cobra GT Mustang Parts for Sale and Wanted 7 12-28-2008 09:59 PM
Evaporator coil adumortier 1979-1995 Mustang GT 3 05-31-2008 11:24 PM
Demon Coil? corkwood06 Pre-2005 V6 Mustang 3 05-28-2008 03:37 PM
Coil Over Suspension bluemustang 1979-1995 Mustang GT 12 04-04-2007 12:14 PM
!!!!Coil Overs!!!! !*!STANG!*! Pre-2005 V6 Mustang 12 10-13-2003 06:19 PM
12:02 PM
