Car stalls in drive - Mustang Evolution
Old 12-23-2005, 04:31 PM   #1
Send a message via AIM to SeadudeRXP
Car stalls in drive
The other day my car died while I was drivin down the road. I was sittin at a red light lookin through some cd's and I looked up and realized traffic had started moving. So I sped up pretty quick to catch up, and as I let off and started cruisin at the speed limit the car just died. I had to swerve across traffic to get off the road before I stopped coasting. Once I got out of the way, I stopped the car and turned the key, and sure enough it started right up like a champ. So once I got close to work I tried speeding up quickly again (on a deserted road) and sure enough once I let off it died. A guy I worked with used to be a mechanic and he told me he thought it was a sticking valve. Anyone heard of this problem? My car is an 03 and has about 25k miles on it. Also, he said it was the EPV valve (I think) supposedly it has somethin to do with recirculating exhaust gases.
2003 Oxford White Mach 1
Best Time: 13.31 @ 106
Mods: Steeda Tri-Ax, BBK X-Pipe, Magnaflow Catback
SeadudeRXP is offline   Reply With Quote
Old 12-24-2005, 01:09 AM   #2
a00v6stang's Avatar
Re: Car stalls in drive
i had a similar problem but i just changed the battery and it was fine
It's all about how fast you get from point A to point B, now how you get there
a00v6stang is offline   Reply With Quote
Old 12-24-2005, 01:54 AM   #3
Kiljosh's Avatar
RPM Decay Rate? :dunno:
Old 12-24-2005, 07:42 AM   #4
Could be a dirty or bad IAC.
487.4 RWHP 464.8 RWTQ
11.584@124.58
Sponsored by
http://www.Delkperformance.com/
WWW.SUPERSIXMOTORSPORTS.COM
http://www.v6challenge.com
GT-Eater is offline   Reply With Quote
Old 12-25-2005, 03:35 PM   #5
With 25k miles, I'd carry that thing back to ford and make them fix it. It's still under warranty.
Old 12-25-2005, 04:42 PM   #6
BTW, where is the IAC? I have a friend with the same problem....
Old 12-25-2005, 05:06 PM   #7
slvr2000stang's Avatar
On the throttle body next to the TPS
Custom Delk motor now DOA
2003 SVT Lightning #1059 of 4270
2000 Vert 4R70W
Only buy from vendors that test and stand behind their products
slvr2000stang is offline   Reply With Quote
Old 12-25-2005, 06:42 PM   #8
Ya, figured that out. Have a friend with a taurus and the 3.8 and his IAC is sticking, gonna pull it off and clean it out for him.
Old 12-28-2005, 07:30 PM   #9
a00v6stang's Avatar
check the alternator also, mine did that about two weeks abo and my alternator jsut went today, would an alternator from a 1994 Mercury Cougar fit my 2000 Ford Mustang??
Old 12-29-2005, 08:40 AM   #10
my idle bypass valve (IAC, located no the upper intake next to the throttle body and is cylinder shaped) Its a cheap part and easy to change, when it goes out the car wont idle. This may or may not be the problem, but its a cheap place to start looking. It acts up worse when its cold outside~
stalls when decelerating 2003stangmachI 1996-2004 Mustang GT 1 11-11-2009 08:17 AM
2nd Drive By + In Car at night Seph Pictures and Videos 5 01-19-2006 07:59 PM
DONT let your friends drive your car SpectorV The Bar 26 01-03-2005 08:58 PM
Code reading? and Car that idle Lobes and stalls stick0014 Pre-2005 V6 Mustang 4 09-03-2004 08:33 PM
Do you let others drive your car? Brent The Bar 22 10-24-2003 01:19 AM
11:46 PM
