96 eaton m90 swap - Mustang Evolution
Old 01-08-2010, 04:35 AM   #1
96mustang21's Avatar
96 eaton m90 swap
im new here so whats up everyone i have a 96 v6 ive been working on putting a m90 on. Well its done now, but i cant get it to spark im getting power to the coil pack, ive replaced the cam sensor and i tested the crank sensor yesterday all seem to be fine and before i replace the computer i wanted to see if n e one had other ideas btw the bottom end is 96 the top end of the motor is 89 (heads, intake, etc.) the tps and iac i left obd1 just rewired, the rest of the sensors i left obd2 thanks chris
96mustang21 is offline   Reply With Quote
Old 01-13-2010, 07:01 AM   #2
Zebs5408's Avatar
Re: 96 eaton m90 swap
idk man no one in here seems to know i guess, all else fails take it to a shop i hate for you to get this far along then nothing man, i know how u feel, all excited project almost over then this happens, get some prices and just let a shop finish it, Good luck and God bless oh and welcome to Mustang evolution!
04' mustang 3.9 40th Anniversary Edition- (V2 Vortech Supercharger, 38# injectors, 3.73 gears w/ T-lok, Predator Diablo, Mac cold air intake, Port & polished upper AND lower intake manifold, Mac Long Tube Headers, Mac o/r H pipe, flowmasters, 2.5 flowmaster tips)
03' Mustang GT (20" Cobra R's, 40 series Flowmasters)
Zebs5408 is offline   Reply With Quote
Old 01-13-2010, 08:24 AM   #3
thanks man but i figured it out just bought a bad coil took the one off my friends mustang to test it and it fired right up just workin on getting everything put back in place then i will post pics and if n e one needs advice about how to do the swap or wants to know whats involved send em my way. thanks again, chris
96 v6 bottom end, sc heads, eaton m90, sc tb, bbk headers,custom tru dual 2.75 exhaust H-pipe flowmaster 40s, sc 8 rib belts,egr delete,5 speed, etc etc.
Old 01-13-2010, 09:49 AM   #4
Send a message via AIM to VCS_SSSTANG
Pics
VCS_SSSTANG is offline   Reply With Quote
Old 01-21-2010, 03:22 AM   #5
Zebs5408's Avatar
i thought on a 96 you could keep your heads cause they were also single port! i kow my moodel we have split port heads and for me to do the m90 swap i would have had to down graded to single port heads which we have cost me power to,,,,well gain power lol! anyway on mine i had to switch heads cause i didnt have single port heads YOU DO so why did u have to change them or did you just decide the othere heads were in better shape? and im not sure about why it want fire! i would honeslty put it in the shop and just pay to have it done from this point!
Old 01-21-2010, 03:25 AM   #6
Zebs5408's Avatar
ooohhh i feel like an arss i see the post under the first one i wrote lol! u did get it fired thats awesome man
Old 01-22-2010, 04:31 PM   #7
BIG_K's Avatar
pics!
00' Mustang : totaled
06' Mustang : DD
83' AMC Spirit GT: Weekend Warrior
BIG_K is offline   Reply With Quote
Old 01-22-2010, 07:15 PM   #8
i had the intake on the mustang heads but 2 bolt holes didnt line up i was going to put it on any way but someone told me the sc heads are better flowing and have bigger valves so thats the reason for the head change. now i need a throttle cable off of a 5.0 or a 4.6 mustang and customizing an intake. i will take pics and post them tomorrow the way it sits now
Old 01-22-2010, 11:51 PM   #9
sledgehammer's Avatar
Send a message via Yahoo to sledgehammer
good to know
94 v6 manual, 3.45s w/t-lock, cai, straight straight through dual exhaust, sct eliminator.
sledgehammer is offline   Reply With Quote
Old 01-23-2010, 12:25 PM   #10
big show 98's Avatar
Originally Posted by sledgehammer View Post
good to know
+1
big show 98 is offline   Reply With Quote
Old 01-23-2010, 03:02 PM   #11
i posted a few pics tell me what you guys think and btw its not scratched or dented just a little dirty been garaged for a few months and i need to hide some wires and clean it up i will post more pics when it is all done but here it is as of now
Old 03-06-2010, 03:47 PM   #12
odoyle533's Avatar
Region: Wyoming
Send a message via MSN to odoyle533 Send a message via Yahoo to odoyle533
Quick question , i have all the parts to do a swap on my 96 mustang with the eaton m90 as well . Can i use my stock harmonic balancer ? and do i have to change my power steering pulley ? just trying to get everything figured out 100% before i start so there is no surprises .
odoyle533 is offline   Reply With Quote
Old 03-06-2010, 08:59 PM   #13
first off i will tell you its 100% easier just to drop the entire supercoupe engine in the mustang. things changed from the 95 stangs to the 96 which makes it harder to do. i had the entire sc engine to play with for the swap. my first problem was 2 bolts didnt line up when i was bolting the intake manifold to the heads. i was going to go ahead as planned but a guy that knows alot about the sc engine said the sc heads are better flowing because they were made for the supercharged engine. so i changed the heads and everything bolted up fine. 2nd was the water pump the supercharger belt comes to close and will rub the hose that goes to the water pump and the sc water pump will not bolt up so you will have to modify it i used a 90 fitting u will see what i mean. as for the pullies i cant remember why but i had to change them and i changed everything even the brackets. if you have the supercoupe radiator great if not you can use the one on the mustang but you have to take the fan off turn it and bolt it back on to make room for the intercooler.and im sure you know along the way you will have to rewire a few sensors and extend some wires. and there are things im forgetting but when and if you run into a problem just ask me and ill help as much as i can
Old 03-07-2010, 02:31 AM   #14
odoyle533's Avatar
Region: Wyoming
I have everything , jack shaft bracket , power steering bracket , harmonic balancer pulley , all tensioners , maf sensor , tp sensor , throttle body, injectors, all tubing , intake , and the timing cover from the supercharged engine . i need a alt. , thermostat housing , tap covers , and supercharged water pump because it has the extra inlet-outlets on it (which is a bummer because i just replaced the stock one with a new one ) .
Old 03-08-2010, 10:51 PM   #15
if u find a water pump that has the extra outlets let me know because i looked everywhere and cross referenced part numbers and i couldnt find one that would work i tried the one off the s\c engine but it wouldnt bolt up thats why i had to fab mine. do u have the heads off the s\c engine or are u just porting the stang heads
Old 03-09-2010, 03:03 AM   #16
odoyle533's Avatar
Region: Wyoming
Since i am using the supercharged engines timing cover the supercharged water pump bolts up normally , i picked up the timing cover for 30 bucks shipped from ebay . I'm just going to use my original heads because in order to use the supercharger intake you have to have single port heads which 96 is the last year that had the single ports on them . I'm going to port and polish them. i would just change the heads but i can't find any used ones for a cheap price . how did you fab your water pump ? just tap out the two extra inlet and outlet holes and put fittings in them ?
Old 03-10-2010, 11:07 AM   #17
the 96 water pump only has 1 outlet since the outlet would hit the belt and i didnt think the cover off the sc would work i just took the strait fitting out of the pump and replaced it with a 90 fitting and im taking the temp sensor housing off and replacing it with one that has an outlet.
Eaton M90 Supercharger CCT4132 Pre-2005 V6 Mustang 5 09-15-2009 02:46 PM
Eaton M90 SC + Mustang 04 v6 =??? wh!te_stang General Mustang Discussion 19 04-07-2009 09:22 PM
Eaton M90 Supercharger for V6 Mustangs nmaraijko Mustang Parts for Sale and Wanted 10 08-10-2008 05:16 PM
eaton m90 question VindictiveStang Pre-2005 V6 Mustang 8 09-17-2005 11:37 PM
eaton m90 question greenpony02 Pre-2005 V6 Mustang 10 01-23-2005 12:07 PM
02:02 PM
