What's Missing on the V-6? - Mustang Evolution
Old 12-26-2005, 01:21 PM   #1
SN95's Avatar
Aside from the obvious a V8 , dual exhaust, bigger wheels and Mach 400 Stereo, what else is missing when compared to a GT coupe? I just found the standard v6 has no rear sway bar.
SN95 is offline   Reply With Quote
Old 12-26-2005, 03:32 PM   #2
dark's Avatar
Send a message via AIM to dark Send a message via Yahoo to dark
Re: What's Missing on the V-6?
shocks and struts are different. possibly springs as well
I don't own a mustang at the moment
dark is offline   Reply With Quote
Old 12-26-2005, 04:18 PM   #3
Dark02Pony's Avatar
Send a message via AIM to Dark02Pony
GT has a bigger front sway bar, an H pipe vs our v6 Y pipe,dual exhaust of course, 2more cylinders, 17" wheels with 245-45-17 goodyears,150mph speedo vs our 120,ti3650 transmission(5spd) vs the v6 which is either a t-5 or t-45, an 8.8 rear end,i believe the suspension is the same except for the swaybar,diff. ecu. The v6 and v8 can come with the mach-460 or mach-1000..just depends on what options you get through the factory or dealer
http://img.photobucket.com/albums/v6...rtandgrill.jpg
Operation: Evolutionization.......Member #3
Originally Posted by MonteCitan
Ford Motor Company = FoMoCo..
what does that make Honda Motor Company????
Originally Posted by Nicole
Mineral Gray is such a hott color. Much better then orange
Dark02Pony is offline   Reply With Quote
Old 12-26-2005, 04:37 PM   #4
Springs are dif, I dunno bout the s/s. Uhm...
Old 12-26-2005, 04:52 PM   #5
Depends on the years you are comparing as well
Old 12-26-2005, 06:10 PM   #6
Send a message via AIM to white95v6
yea cause every 94-98 i have ever picked up or looked under had a rear sway bar.
The First and Only 9 Sec Production Based V6 Stang!!,First over 500rwhp,First and only over 600rwhp
60ft-1.42,1/8th mile-6.25@111mph,1/4 mile-9.83@136.65mph
Sponsored by:
WWW.DELKPERFORMANCE.COM
white95v6 is offline   Reply With Quote
Old 12-26-2005, 06:28 PM   #7
My 96 came with one but my 95 didn't so I am pretty sure it is hit and miss for atleast 94-96
Old 12-26-2005, 06:30 PM   #8
i guess i got lucky. but i don't use it anymore.
Sponsored by:
Old 12-26-2005, 08:46 PM   #9
SN95's Avatar
I have a 2001 v6, can you adapt a sway bar from a 01 GT? Or just buy one from a kit?
Old 12-26-2005, 09:17 PM   #10
One from a 01 GT would work perfect for you. I have one from a bullitt mustang.
Old 12-26-2005, 09:18 PM   #11
you can do ether. but you will need the bolts and nuts to hold it on. or you can buy some 10.9 grade metric bolts or some grade 8(standard) bolts.
Sponsored by:
Old 12-26-2005, 09:20 PM   #12
Yeh, I bought the bolt kit from ford, it was right around 40 bucks for the 4 nuts and bolts, but worth it to me for the original parts, made the install a snap.
Old 12-27-2005, 08:48 AM   #13
I found a site that compares the 2001 v6 to 2001 gt.
http://www.carsdirect.com/research/c...,USB10FOC051B0
hope this helps
cmanzi79 is offline   Reply With Quote
Old 12-27-2005, 11:43 AM   #14
the 99 up gt rear sway bars are stiffer than the 94-98 so make sure to get a 99 up gt one.
the brake pads are different, not the struts/shocks.
Missing Images Brent ME Site Help & Announcements 5 03-02-2009 07:57 PM
Girl missing!! MidnightSpeed The Bar 10 05-09-2007 07:08 PM
Missing... DarkShadow Pre-2005 V6 Mustang 11 07-10-2006 07:45 PM
VA is missing?? Rick0636 Regional Mustang Discussion 1 06-18-2005 01:17 AM
02:10 PM
