whick intake is better? - Mustang Evolution
Old 01-02-2006, 07:44 AM   #1
i have a 98 v6 and wondered if the 99-up intakes are any better? i was looking into getting a 4.2 longblock to put in and wanted a good intake for it. any suggestions
myillwillinc is offline   Reply With Quote
Old 01-02-2006, 07:53 AM   #2
Danger Dude's Avatar
Re: whick intake is better?
The stock 99+ intakes will not fit on the 98 heads. You can do a complete head intake and fuel conversion swap or just buy a newer 4.2 and then you will only need a 99+ upper intake and fuel conversion setup. The 4.2 upper intake found in a truck will not fit under a stock hood but a 99+ mustang upper intake will fit on it.
Old 01-02-2006, 08:05 AM   #3
cool, so i can get a 99+ 4.2 and 99+ mustang intake an it will drop into the 98?
Old 01-02-2006, 08:10 AM   #4
You will need to get a fuel rail conversion because of the changes to the fuel system from 98 to 99. Basically it is welding the back end of a 94-98 fuel rail to a 99+ fuel rail. They can be had on the mustang boards. Several people make them. The other thing is a tune. you will need to either get a chip or dyno tune
Old 01-02-2006, 10:08 AM   #5
slvr2000stang's Avatar
a search for split port swap will also give you an idea of what's needed.
Custom Delk motor now DOA
2003 SVT Lightning #1059 of 4270
2000 Vert 4R70W
Only buy from vendors that test and stand behind their products
slvr2000stang is offline   Reply With Quote
intake porting and powdercoating intake(RGR) 232SCstang Pre-2005 V6 Mustang 7 01-11-2004 08:41 AM
04:25 AM
