stripped a bolt hole on lower intake. HOw to fix? - Mustang Evolution
Old 01-02-2006, 09:32 AM   #1
Now I am stuck. I have a 2000 V6. When I took off the upper intake yesterday, I stripped a bolt hole on the lower intake where the uppper intake fastening bolt goes in. Although I managed to put the upper intake back, there is one bolt (long bolt and close to the firewall on the driver side) that I have no way to tighten due to the stripped hole. The upper intake has no leaking whatsoever right now. But the loose bolt really concerns me.
Now what do I do? Just leave it there? Anyone know how to fix it? Shold I make a larger hole and use a larger bolt to replace the stock bolt?
rstang is offline   Reply With Quote
Old 01-02-2006, 10:04 AM   #2
slvr2000stang's Avatar
Re: stripped a bolt hole on lower intake. HOw to fix?
Can you restore enough threads by cleaning it out with a tap?
Custom Delk motor now DOA
2003 SVT Lightning #1059 of 4270
2000 Vert 4R70W
Only buy from vendors that test and stand behind their products
slvr2000stang is offline   Reply With Quote
Old 01-02-2006, 05:24 PM   #3
Kiljosh's Avatar
Yea clean it with a tap, if that doesn't work try retapping it with the next size up.
Old 01-02-2006, 11:49 PM   #4
pinto beast's Avatar
I already told you that on 3.8
pinto beast is offline   Reply With Quote
Old 01-07-2006, 08:02 AM   #5
RGR
Send a message via AIM to RGR
I've actually done this, and used a 1/4-20 when I converted
Kirk's intake to a post-deleted upper. If that hole is so bad that
1/4" will not work, go 5/16" and that will work for sure. Those
taps and bolts are cheap too, lots less than metrics.
Originally Posted by Flex:
You are the true cam master dude...
RGR is offline   Reply With Quote
Lower Intake snake428CJ 1979-1995 Mustang GT 5 08-06-2008 09:17 AM
So my lower intake manifold... MonteCitan 1979-1995 Mustang GT 3 11-20-2006 08:22 PM
Lower intake and heads rydog Mustang Parts for Sale and Wanted 2 10-19-2006 08:38 PM
99-00 lower intake work on a 01 v6? SpectorV Pre-2005 V6 Mustang 4 08-01-2004 05:36 PM
Lower intake gaskets... 98GreenStallion Pre-2005 V6 Mustang 4 01-27-2004 09:09 PM
09:20 PM
