what now? - Mustang Evolution
Old 01-03-2006, 02:13 PM   #1
what now?
Just changed to headers on my car and did a spark plug change while I was at it and now the car is running like crap. I ran the car up the road and when I came back the number 4 header pipe is hot as hell and the rest are not nearly as hot. What could cause this? Could a bad catalytic converter cause this?
mustangruss is offline   Reply With Quote
Old 01-03-2006, 02:20 PM   #2
Re: what now?
if you just swaped headers and thats it (other than a standard spark plug change) I would review the install, check for leaks and what not.
Double check the spark plugs and inspect their gap. I hope you didnt pull all the wires off and then stick them all back on... possibly in the wrong order.
Old 01-03-2006, 02:26 PM   #3
Re: what now?
Im fairly certain there are no leaks ...the reason I went to headers was because there was a noticeable leak up front and I figured the stock manifold was cracked and my gas mileage went from like 20 in the city to 17. Im also fairly certain that I didnt mix up the plug wires because I only pulled them off one at a time.
Old 01-03-2006, 02:57 PM   #4
Re: what now?
if you only pulled them off one at a time then chances are its not that, but double check to make sure. check the bolts on the headers, when they get hot and cool again they can become a bit loose.
Old 01-03-2006, 04:59 PM   #5
Kiljosh's Avatar
Re: what now?
Look into locking header bolts. They will svae you some trouble.
Old 01-03-2006, 06:19 PM   #6
Re: what now?
Thanks Ill check into those. I ordered off road h pipes for it so maybe that may fix it too. I appreciate all the help.
Old 01-03-2006, 10:15 PM   #7
I_luv_HP&trq's Avatar
Send a message via AIM to I_luv_HP&trq Send a message via MSN to I_luv_HP&trq
Re: what now?
maybe not all the cylinders are firing. compare the threads on the previous plugs to the ones you just installed and make sure they have the same thread length.
99 Cobra: flowmasters, 18x9.5 cobra R's, soon to be tuned and geared. daily driver
99 V6:in avatar, Mac Cai, true duals/flowmaster 40's ,UDP, custom tuned, bullitt suspension 18" wheels...taken by mother nature
I_luv_HP&trq is offline   Reply With Quote
Old 01-06-2006, 05:59 PM   #8
Dman's Avatar
Send a message via AIM to Dman
Re: what now?
what year is your stang because I can get you the order of the spark plugs to heads.
here you go this is for 1994-2003 stangs
http://www.shooshshare.com/viewimg.php?img=MjMzMw==
Dman is offline   Reply With Quote
08:01 PM
