Has anyone filled up with E85 105 Octane gas? - Mustang Evolution
Go Back   Mustang Evolution > 4 Cylinder | V6 | Classic Mustangs > Pre-2005 V6 Mustang
Closed Thread
Old 01-04-2006, 10:04 AM   #1
Vash is unknown around these parts
Will it hurt our car?
Does anyone have a tuner? can it flash our chips to use 105 octane effectively?
Vash is offline
Old 01-04-2006, 10:20 AM   #2
Terminator Owner
SpectorV is just getting started.
Re: Has anyone filled up with E85 105 Octane gas?
why would you want to even consider doing that.
SpectorV is offline
Old 01-04-2006, 11:04 AM   #3
Danger Dude's Avatar
Danger Dude is unknown around these parts
What are the differences in an FFV compared to a regular gasoline-only model? Are different parts used?
There is only one major additional part that is included on an FFV, the fuel sensor that detects the ethanol/gasoline ratio. A number of other parts on the FFV’s fuel delivery system are modified so that they are ethanol compatible. The fuel tank, fuel lines, fuel injectors, computer system, anti-siphon device, and dashboard gauges have been modified slightly. Alcohols are corrosive. Therefore, any part that comes in contact with the fuel has been upgraded to be tolerant to alcohol. Normally, these parts include a stainless steel fuel tank and Teflon lined fuel hoses.
Will I hurt a gasoline-only vehicle if I use E85?Yes. Longer-term use of E85 in gasoline-only vehicles may cause damage because of the incompatibility of the alcohol fuel with the parts in gasoline-only engines. Performance and emissions will also be compromised.
Can a car be retrofitted or converted to use E85?
We do not recommend the conversion of a gasoline-only vehicle to operate on E85. FFVs that come with original equipment from the manufacturer have the same warranties as gasoline vehicles and they are specially suited to use E85 as efficiently as possible and to burn cleaner.
DO NOT USE IT !!!!
Danger Dude is offline
Old 01-04-2006, 05:23 PM   #4
jimmy_beaner's Avatar
jimmy_beaner is unknown around these parts
woot, go ethanol... and Iowa.. for making it
jimmy_beaner is offline
Old 01-04-2006, 09:00 PM   #5
MarkuzLS1's Avatar
MarkuzLS1 is unknown around these parts
Send a message via AIM to MarkuzLS1
I've heard from some of my Grand National buddies, that have that in their area, of ultra-high, race-gas type boost numbers with it.
I like turtles.
MarkuzLS1 is offline
Old 01-05-2006, 08:08 AM   #6
justin00stang is unknown around these parts
Not worth it, a lot of problems as Danger said. The E85 will make your car run lean, and it may be high octane but most stock cars do not benefit from anything over 93 oct.
Justin Starkey
2007 Shelby GT500 705RWHP/708RWTQ
2000 Mustang 3.8 A4 TT 450RWHP/475RWTQ 10.996@127 17psi stock 3.8
2006 F250 CC 4x4 6.0L 14.3 @ 93
2006 Mustang 4.0 M5 Vortech 13psi 395RWHP/374RWTQ wife's car
justin00stang is offline
Closed Thread
would higher octane gas? help? Scorpion1 Pre-2005 V6 Mustang 16 06-28-2008 03:42 AM
Anyone heard of E85? Dom The Bar 5 04-27-2006 12:20 PM
Gas Octane for 05' jones4stangs 2005-2009 Mustang GT 6 02-17-2006 10:02 AM
Using 93 Octane gas is bad for my engine? Chonk Pre-2005 V6 Mustang 9 12-20-2003 04:18 AM
Chick ran a 13.38 @ 105 MaestroSC Pre-2005 V6 Mustang 14 12-19-2003 10:23 PM
12:55 PM
