Detroit Lockers or Ford T-lock? - Mustang Evolution
Old 01-08-2006, 08:39 PM   #1
greekstang's Avatar
Question Detroit Lockers or Ford T-lock?
I was ready to purchase the T-locks, until I went on all ford mustang forums, and some one there said the detroit ones are better, reason there are no discs.
My queastion here is is there any one who is using t-lock or Detroit and what they think of them?
Also is there aby whinny noise? I'm goig to keep the stock gears.
greekstang is offline   Reply With Quote
Old 01-08-2006, 09:05 PM   #2
slvr2000stang's Avatar
Re: Detroit Lockers or Ford T-lock?
The Detroit true track is stronger than the t-lok.
The t-lok is a good part & will do just fine for the majority
Custom Delk motor now DOA
2003 SVT Lightning #1059 of 4270
2000 Vert 4R70W
Only buy from vendors that test and stand behind their products
slvr2000stang is offline   Reply With Quote
Old 01-09-2006, 10:10 AM   #3
DarkShadow's Avatar
Send a message via AIM to DarkShadow
I'm using the Detroit T-Lock. It drives just fine, no noise. Unless you plan on making lots of power, you may not need. If your not sure, go ahead and get a Detroit. If you want, I'll pm you a link to cheap place to get one.
DarkShadow is offline   Reply With Quote
Old 01-09-2006, 11:35 AM   #4
do you plan to drag race the car at the strip? If not then the OEM ford tlok will be perfectly fine.
Old 01-10-2006, 12:38 AM   #5
greekstang's Avatar
no time for the track, just spinning out at the lights
Old 01-10-2006, 06:06 AM   #6
T-Lok will be just fine for you.
2000 Vert 4R70W
Old 06-23-2006, 05:20 PM   #7
Found this while digging up information on Detroit T-Lock, im looking for a cheap place to buy can't really seem to find much. Thanks in advance.
Drunken Ghost is offline   Reply With Quote
Old 06-23-2006, 09:57 PM   #8
There was just a group buy on the Trutrac through DTS.
2000 Vert 4R70W
Old 06-23-2006, 10:53 PM   #9
DarkShadow's Avatar
Yeah the USED to be cheap place was drivetrainspecialists.com.
But I dont know that they are not as chep form what I've heard...
Old 06-23-2006, 11:24 PM   #10
their prices only went up a little but the group thing helped offset it.
2000 Vert 4R70W
Old 06-26-2006, 10:15 AM   #11
Send a message via AIM to Sublime782 Send a message via Yahoo to Sublime782
Hey, ever look into an auburn posi? You can usually get good deals on them and they are stonger than the factoryt-lok.....definalty not as strong as the tru-trac though.
Women are like parking spots; the best ones are either taken or handicap
Sublime782 is offline   Reply With Quote
Old 06-26-2006, 10:30 PM   #12
If you dont plan for big power or sticky tires, the the ford t-lok is all you nee.
Old 06-27-2006, 08:08 AM   #13
before I went with anything more heavy duty than an oem tlok I would save up and buy an 8.8 rear from the same year set as your car with/with out ABS/traction control so its a simple bolt on.
Old 06-27-2006, 03:38 PM   #14
bbunt302's Avatar
NO!!! TeH 7.5 is tEh GOD!
Seriously, listen to Spector and get the 8.8.
Scary stuff.
Old 06-27-2006, 07:01 PM   #15
Region: Iowa
Send a message via AIM to Horse Send a message via Yahoo to Horse
I need to either rebuild my T-Loc or go with something better. I'm running Falken Azenis tires at autocrosses and I'm one wheel burnning them like nothing. Are the Detroit or Auburn lockers built with enough allowable spin that it wouldn't hurt my tight turning?
4.2L , CAI, BBK 65MM throttle body, 30lb injectors, SSM ported intakes, FLEX 1/2" spacer, RPM big valve heads, Comp roller rockers and cam, ASP-underdrive pulley, GT rear swaybar, & Quad Shocks, Full MM Coilover conversion, 17" Grey Torque Thrust wheels, FMS Aluminum driveshaft 8.8 rear w/ 3.73 gears, Tri-Ax Shorthrow shifter & SPEC stage II clutch w/ aluminum flywheel
Horse is offline   Reply With Quote
Old 06-27-2006, 07:44 PM   #16
DarkShadow's Avatar
Yes they do not technically lock your axles like a locker does. You will be fine in turns and you will still only be powering one wheel until it senses slip, then it will engage both wheels.
Old 06-27-2006, 07:46 PM   #17
DarkShadow's Avatar
:worship:
Newbie from Detroit Dsimps New Member Introductions & Greetings 11 03-03-2008 10:28 PM
Official Detroit LSD thread. DarkShadow Pre-2005 V6 Mustang 29 10-28-2005 10:27 PM
detroit locker vs. limited slip oaktonarcher Pre-2005 V6 Mustang 15 07-10-2004 01:27 PM
2004 Detroit Auto Show NAIAS KrazyPony The Bar 9 01-20-2004 12:54 AM
10:23 AM
