sway bars? - Mustang Evolution
Old 01-08-2006, 08:50 PM   #1
greekstang's Avatar
Question sway bars?
i have an 04 3.9L V6, and i want more control, tell me what you guys have or know of , im looking at Eibach anti roll kit ($280) or steeda rear and front sway bar? I'm looking for a good set up that wont brake the bank and time?
greekstang is offline   Reply With Quote
Old 01-09-2006, 09:35 AM   #2
Re: sway bars?
A rear sway bar will make a huge difference. I have the bullitt suspension kit from rdmotorsport.com, along with subframe connectors, and I have control I never thought I would before. Ran an autocross yesterday, and kept up with cars I never thought I would.
Old 01-09-2006, 10:06 AM   #3
Re: sway bars?
find a 99-04 GT rear sway bar at a junk yard or on ebay, they work really nice. I would upgrade the springs to ford C springs unless you want more than a 1.1 inch drop~ the drop for optimal handeling is 1.25 inches all around~
Ford C springs are 650lbs front and 300~ rear (eibachs are usually softer than this, some not some are so be leary) and the C springs run 100 bucks.
Old 01-09-2006, 11:45 AM   #4
I liek gramer
WhiteStang99's Avatar
Re: sway bars?
If you get C Springs you will probably want to go ahead and count on needing c/c plates. Some do, some don't. I did after C Springs.
Rear sway bars (all that I have experience with) are amazing and I would have never thought they would make the kind of difference that they did.
Old 01-09-2006, 02:24 PM   #5
greekstang's Avatar
Re: sway bars?
thanks guys, I'll stay away from The eibach, i'm going to try the junck yard but if not should i go with the steeda sway bar heavy one?
Old 01-09-2006, 03:50 PM   #6
I liek gramer
Re: sway bars?
generally the heavier/thicker/stronger it is, the better.
Old 01-09-2006, 08:32 PM   #7
Re: sway bars?
if you want an 01 gt front sway bar i have one.
Old 01-10-2006, 12:35 AM   #8
greekstang's Avatar
Re: sway bars?
thanks 232, how much? I just ordered a steeda rear sway bar and a t-lock, to be honest i'm kind of out of funds till next week.
Old 01-10-2006, 04:04 PM   #9
Re: sway bars?
i dont know how much they are worth. wonder how much it would cost to ship it through usps, or is it possible.
Old 01-19-2006, 07:43 AM   #10
Cool Re: sway bars?
The sway bar on the front should be thicker/heavier/stronger than the one on the rear.
Otherwise you could wind up with unwanted handling problems . . . or death!
All best,
Joe
1998 Laser Red V6 manual . . . Kenny Brown suspension, Eibach pro-kit springs, BBK CAI, JBA shorty headers, Magnaflow duals, GT fogs, Aluminum driveshaft, 3.27 gears, Tri-Ax shifter handle, misc UPR and MGW billet accessories, SS inserts, Redline Goods shift boot
1998Stang is offline   Reply With Quote
Old 01-19-2006, 09:15 AM   #11
Pony Ride's Avatar
Re: sway bars?
This suspension set up is awesome! The difference is amazing! The car is so much more stable and sure-footed in the corners.
The lesson here is make sure the component upgrades you do with your suspension compliment each other, and don't make it worse. Also, you'll get the best results by doing it all right up front. In other words, save up to upgrade your shocks/struts that will compliment your new lowering springs. And make sure the rear sway bar you get will compliment the front sway bar. If not, you'll get under- or over-steer issues that will make the handling worse than stock.
Pony Ride 2!! 2007 Grabber Orange GT Premium with 5-speed manual transmission
Pony Ride is offline   Reply With Quote
Old 01-19-2006, 09:36 AM   #12
OR_Red98's Avatar
Region: Oregon
Re: sway bars?
I've got GT bars, front and back, C springs w/half a coil off, Mach 1/Tokico struts and shocks and 18X9 rims with suitable rubber on my "98." She turns wicked fast and flat and is as stable as a rock.
Dennis........Retired USAF, Disabled Vet.
http://www.mustangmods.com/data/666/the_stang_005.jpg
Red "98" coupe V6 AT. Saleen boby kit, 18" replica Saleen rims, FMC "C" springs, Mach 1/Tokico shocks/struts, GT sway bars, GT STB, Sequential turn signals, Euro head lights and clear corners, BBK CAI and GT take-off exhaust.
OR_Red98 is offline   Reply With Quote
Old 01-19-2006, 03:44 PM   #13
red pony V6's Avatar
Send a message via AIM to red pony V6
Re: sway bars?
how hard is it to install a sway bar? and do they come with instructions?
1998 V6
true dual flows
CAI
MGW shifter
and slow as hell...
red pony V6 is offline   Reply With Quote
Old 01-19-2006, 08:28 PM   #14
Re: sway bars?
Installation of a rear swaybar isn't bad. I jacked up my car and pulled off the rear wheels to do mine, just easier access for an air rachet. 4 bolts and 4 nuts and you're done.
Old 01-20-2006, 10:31 AM   #15
greekstang's Avatar
Re: sway bars?
check this out, all is stock on my 04 V6, I purchased a steeda heavy duty rear swaybar from stangsuspension.com
Is this going to help my handeling or hurt, what I mean is do I now need a new front sway bar?
Or will the steada rear be fine?
Old 01-20-2006, 05:49 PM   #16
Re: sway bars?
It will definitely help you, but it won't hurt to beef up the rest of your suspension later if you want to go that way.
Old 01-20-2006, 08:50 PM   #17
greekstang's Avatar
Re: sway bars?
thanks lowflyn I definately want to do shocks and springs and all the rest but im working on a budget so slowly does it.
But I ask if it will hurt as 1998stang mentioned if the rear is heavier then the front it will unbalnce "death" ( read up on top ) that scares me,
SO thats why im asking if i use the heavy duty steeda rear sway bar with the stock front is it safe, if any one knows?
Old 01-20-2006, 08:54 PM   #18
Re: sway bars?
I don't believe there's much difference in most rear sways you buy. As long as the diameter of it is less than the front I really wouldn't worry too bad, unless you are serious into handling on your car. About the only way you'll notice it making that big of a dif is if you're really pushing the limits of your car, as far as negatively effecting the handling.
Old 01-20-2006, 10:13 PM   #19
I liek gramer
Re: sway bars?
yeah, unless you're drivin like a tool, it won't be that much of a problem. When you get a front sway bar, if you do, I would suggest definitely getting bigger than the rear. But I'm only running w/ a rear one at the moment, and all I've seen is a massive increase in handling.
Old 01-21-2006, 12:15 AM   #20
Re: sway bars?
Your car has a front swaybar already.
Old 01-21-2006, 01:19 PM   #21
Danger Dude's Avatar
Re: sway bars?
You dont need to touch the front bar and you paid to much for a steeda rear bar. The Steeda is a rebadged FMS (Ford Motor Sports) sway bar which could be had for 1/2 the price. Almost all Steeda stuff is rebadged. You should have picked up a GT rear sway bar from a junk yard or Midwest Mustang or MPS.
Bigger is not always better. The outside diameter of a sway bar is not as important as the thickness of the tube. All sway bars are hollow and wall thickness determine rigidity or strength. My Cobra sway bars are actually narrower than some others but the wall thickness is thicker.
Old 01-22-2006, 12:16 PM   #22
I liek gramer
Re: sway bars?
Didn't know they were hollow. :chin:
Old 01-24-2006, 09:48 AM   #23
Re: sway bars?
how come Mustang Tuning only sells the front one?
http://mustangtuning.com/suspension.html
1998 V6
true dual flows
CAI
MGW shifter
and slow as hell...
Sway bars... 232stang01 Pre-2005 V6 Mustang 4 04-17-2005 10:30 PM
Last year for rear sway bars on V6 Mustangs? Brent Pre-2005 V6 Mustang 9 05-19-2004 11:30 AM
running skinnies and no sway bars tire The Bar 2 03-05-2004 11:39 AM
sway bars part2 JoeR. Pre-2005 V6 Mustang 10 01-05-2004 11:37 AM
Sway bars JoeR. Pre-2005 V6 Mustang 26 01-05-2004 10:49 AM
05:15 AM
