stock fuel pump - Mustang Evolution
Old 01-09-2006, 09:37 PM   #1
Send a message via AIM to Murph00
stock fuel pump
i need to know if I need to upgrade my fuel pump, what is the max output of the 2000 3.8L stock pump? upcomming engine upgrade
Murph00 is offline   Reply With Quote
Old 01-09-2006, 10:20 PM   #2
slvr2000stang's Avatar
Re: stock fuel pump
Justin @ vmptuning.com carries the Focus pump.
Custom Delk motor now DOA
2003 SVT Lightning #1059 of 4270
2000 Vert 4R70W
Only buy from vendors that test and stand behind their products
slvr2000stang is offline   Reply With Quote
Old 01-09-2006, 10:25 PM   #3
Re: stock fuel pump
What kind of engine upgrade? The focus fuel pump should be plenty though
Old 01-09-2006, 10:33 PM   #4
I_luv_HP&trq's Avatar
Send a message via AIM to I_luv_HP&trq Send a message via MSN to I_luv_HP&trq
Re: stock fuel pump
The stock pump should be decent up to 240-250ish rwhp.
99 Cobra: flowmasters, 18x9.5 cobra R's, soon to be tuned and geared. daily driver
99 V6:in avatar, Mac Cai, true duals/flowmaster 40's ,UDP, custom tuned, bullitt suspension 18" wheels...taken by mother nature
I_luv_HP&trq is offline   Reply With Quote
Old 01-16-2006, 07:13 AM   #5
Re: stock fuel pump
Yes, roughly, in a boosted app. In a nitrous app it will support a little more.
The stock one is roughly 150lph out of the bucket assembly. The Focus pump is about 225lph out of the bucket assembly (there are flow losses from the aspirator and bucket assembly, thats why you don't see 300lph).
Justin Starkey
2007 Shelby GT500 705RWHP/708RWTQ
2000 Mustang 3.8 A4 TT 450RWHP/475RWTQ 10.996@127 17psi stock 3.8
2006 F250 CC 4x4 6.0L 14.3 @ 93
2006 Mustang 4.0 M5 Vortech 13psi 395RWHP/374RWTQ wife's car
justin00stang is offline   Reply With Quote
Old 01-16-2006, 08:09 AM   #6
Re: stock fuel pump
Details on your upgrade would also help us providing accurate answers.
2000 Vert 4R70W
Old 01-21-2006, 09:54 PM   #7
Re: stock fuel pump
sorry guys, ive been away for a lil while, next month Im gettin my twin turbo kit for the stang 2 t3/ t4 turbo's, I have to still decide what I wanna do with my fuel.
Old 01-22-2006, 08:27 PM   #8
Re: stock fuel pump
^ In that case I would for sure upgrade that fuel pump. Even if you're going to run a minimum amount of boost at first I think it would be a good idea.
Think of it like an insurance. It's better to spend $160 or whatever it is for the pump of your choice then to spend 3K on a blown motor.
Post up some pics of the tt set up. congrats.
Old 03-16-2006, 06:01 PM   #9
Region: Iowa
Send a message via AIM to Horse Send a message via Yahoo to Horse
Re: stock fuel pump
Ok, so the focus fuel pump is good for 255lph. VMP lists a Ford Returnless pump that will run 310lph. What is this pump out of? Is this the Focus pump at is would be rated outside the bucket or what?
4.2L , CAI, BBK 65MM throttle body, 30lb injectors, SSM ported intakes, FLEX 1/2" spacer, RPM big valve heads, Comp roller rockers and cam, ASP-underdrive pulley, GT rear swaybar, & Quad Shocks, Full MM Coilover conversion, 17" Grey Torque Thrust wheels, FMS Aluminum driveshaft 8.8 rear w/ 3.73 gears, Tri-Ax Shorthrow shifter & SPEC stage II clutch w/ aluminum flywheel
Horse is offline   Reply With Quote
Old 03-17-2006, 06:25 PM   #10
DarkShadow's Avatar
Send a message via AIM to DarkShadow
Re: stock fuel pump
The pump that VMP sells wil be just fine. It's the 255 lph pump in the bucket. If it's rated out of the bucket, it's 310 lph, in the bucket it's 255 lph.
If your going twins, I wouldn't think there would be a question of upgrading the pump. It's like $110 and well worth it. That's less than you can get for a brand new stock pump most anywhere else.
DarkShadow is offline   Reply With Quote
Old 03-18-2006, 11:37 AM   #11
Region: Iowa
Re: stock fuel pump
Ok, last question. What year Focus uses that pump? I can probably get it cheaper through work, since I can buy parts at cost. Also, is it for the SVT focus or just the base model?
Thanks.
Old 03-18-2006, 05:16 PM   #12
Re: stock fuel pump
It's the SVT focus pump, and any year they made the SVT focus is fine I believe...
Old 03-18-2006, 08:16 PM   #13
DarkShadow's Avatar
Re: stock fuel pump
I believe it's the same part number as on Justin's site, because mine said "Ford" on it.
Old 03-19-2006, 08:26 PM   #14
Region: Iowa
Re: stock fuel pump
Thanks guys.
05 fuel pump NEED HELP! sglide18 2005-2010 Mustang GT 5 12-16-2010 09:09 PM
Pruchased my Fuel Injectors and Fuel pump today Brent Pictures and Videos 36 12-14-2010 03:22 PM
Help help- fuel pump-help! The Darkside Pre-2005 V6 Mustang 26 05-08-2009 01:45 PM
19LB Fuel Injectors; 190-255LPH Walbro Fuel Pump Brent Mustang Parts for Sale and Wanted 5 05-11-2005 11:04 PM
03:26 PM
