smog - Mustang Evolution
Old 01-10-2006, 05:24 PM   #1
powerhungry966's Avatar
Send a message via AIM to powerhungry966
smog
okay two questions.. hypothetically speaking, if i were to have bigger fuel injectors like 42lb would i pass smog? will a v6 ever be able to cross into 300rwhp territory while perfectly passing smog
1989 coupe 5.0 yeessur.
"Shake n bake"
powerhungry966 is offline   Reply With Quote
Old 01-11-2006, 05:27 AM   #2
ricklmesa's Avatar
Re: smog
Thats a good question man. I was wondering if the stage 2 Procharger is street legal. Level 2 put you at 400 at the crank. The stage 1 gets you like 287 at the rear wheel!!! and is legal I believe. But you haft to add Fuel injectors for stage 2 so I wonder if you can have 400hp Mustang and have it be street legal. Im sure 300 is possible. Again im speaking for the 05 & 06's though
Procharger P1SC,3 Corecooler,42lb inj.
301whp & 300wtq @ 10psi dynojet SAE 106 degrees
ricklmesa is offline   Reply With Quote
Old 01-11-2006, 06:44 PM   #3
I_luv_HP&trq's Avatar
Send a message via AIM to I_luv_HP&trq Send a message via MSN to I_luv_HP&trq
Re: smog
Yes you would be able to pass smog but you would have to have your car re tuned if you're adding bigger injectors.
Are you talking about getting 300 rwhp NA or forced induction? If you're going the SC route the biggest thing that will fail you is visual. You can make 500rwhp and with the right tune pass the OBD2 and the tailpipe test but your only worry would be visual, especially if you have someone who is anal.
Which is why I brought up in that other thread about trying to do it legally by going through the smog referee. That way you won't have to dish out a $100 on top of the smog fee to get you to pass at some shady place, and if a cop wants to look under your hood then you have nothing to worry about.
99 Cobra: flowmasters, 18x9.5 cobra R's, soon to be tuned and geared. daily driver
99 V6:in avatar, Mac Cai, true duals/flowmaster 40's ,UDP, custom tuned, bullitt suspension 18" wheels...taken by mother nature
I_luv_HP&trq is offline   Reply With Quote
Old 01-11-2006, 07:25 PM   #4
RGR
Send a message via AIM to RGR
Re: smog
People with 30# inj's pass easily, and 21#'ers make well over 200 RWHP
so 30's should surpass 300 RWHP. 36's at least... but anyway, the bigger
inj's just turn down the pulse width at idle as compared to the 21's.
If one of my new cams in a 4.2 is ever properly tuned and installed, we
may already be at 300 RWHP but I have never heard if he did it. He was
also needing better intake porting to match the heads/cam combo.
A 3.8 going over 300 RWHP would need short runner intakes to do it NA.
Originally Posted by Flex:
You are the true cam master dude...
RGR is offline   Reply With Quote
Old 01-11-2006, 07:27 PM   #5
RGR
Re: smog
PS: The whole combo would be high-RPM biased,
short runners, ported heads, big(ger) cam, higher
CR and built shortblock. But definitely do-able.
Rolling smog check Scut95 The Bar 3 04-01-2009 10:38 PM
WTB: smog parts.. MonteCitan Mustang Parts for Sale and Wanted 0 12-28-2008 10:46 PM
Smog pump eliminator Scut95 1979-1995 Mustang GT 6 11-03-2006 01:45 PM
dudes smog powerhungry966 Regional Mustang Discussion 7 02-06-2006 11:04 AM
Smog pump Feo Mustang Parts for Sale and Wanted 0 10-12-2004 02:50 AM
04:13 PM
