Gas Mileage - Mustang Evolution
Old 01-10-2006, 05:56 PM   #1
Gas Mileage
I have an 2000 3.8L. If i remove my mufflers, will that decrease my gas mileage?
00BlackStang is offline   Reply With Quote
Old 01-10-2006, 07:03 PM   #2
I liek gramer
WhiteStang99's Avatar
Re: Gas Mileage
doubt it, but it'll sound like ***.
Old 01-11-2006, 05:36 AM   #3
ricklmesa's Avatar
Re: Gas Mileage
Most of the time they sound a lot meaner. More hollowness to them. One thing that i noticed about the older v6's is the exhaust sounds good on them cause the mufflers are underneth the car in the middle of the car not straight out the back. The 05's are sticking right out the back so you get a higher pitched sound. the older stangs have the muffler half way under the car then you get straight pipes out the back. Instead of straight pipes going to mufflers like the 05's & 06's.
You guys got it opposite and I think that provides a better sound. Kinda like how truck's do there exhaust the muffler is always about in the middle of the car and has straight pipes running out to the back.
I'd try to find a few sound clips before haveing a hack fest!! lol
Procharger P1SC,3 Corecooler,42lb inj.
301whp & 300wtq @ 10psi dynojet SAE 106 degrees
ricklmesa is offline   Reply With Quote
Old 01-11-2006, 02:11 PM   #4
Re: Gas Mileage
Taking your mufflers off will sound like *** and lead to headaches.
That and you'll lose torque.
Old 01-11-2006, 03:39 PM   #5
Re: Gas Mileage
Then, What should I do for a better, more deeper sound?
Old 01-11-2006, 06:31 PM   #6
I_luv_HP&trq's Avatar
Send a message via AIM to I_luv_HP&trq Send a message via MSN to I_luv_HP&trq
Re: Gas Mileage
^ get a V8
99 Cobra: flowmasters, 18x9.5 cobra R's, soon to be tuned and geared. daily driver
99 V6:in avatar, Mac Cai, true duals/flowmaster 40's ,UDP, custom tuned, bullitt suspension 18" wheels...taken by mother nature
I_luv_HP&trq is offline   Reply With Quote
Old 01-11-2006, 06:49 PM   #7
RGR
Send a message via AIM to RGR
Re: Gas Mileage
From what I have heard on the Mac stuff, they use 3" tailpipes
with 2 muffs and a y-adapter, but some of the reading I've done
regarding smaller engines, you could get a 2.5" or larger muff set (2)
and run your pipes as this attachment shows: (see below)
Also note, you could use your stock pipe size up to the muffler,
then use 2.25" or 2.5" or 3" out the back. This suggestion was
made by David Vizard and he really knows engines It makes
a deeper sound and more torque.
Originally Posted by Flex:
You are the true cam master dude...
RGR is offline   Reply With Quote
Old 01-11-2006, 07:43 PM   #8
Re: Gas Mileage
Thanks for the info
2000 Ford Mustang 3.8L
5 Speed Manual Transmission
Old 01-11-2006, 11:00 PM   #9
I liek gramer
Re: Gas Mileage
Originally Posted by I_luv_HP&trq
^ get a V8
The reason people love this site so much is because most of the time people don't act like this.
Old 01-11-2006, 11:13 PM   #10
Re: Gas Mileage
If people had a sense of humor they would know i was joking.
Old 01-12-2006, 04:09 AM   #11
RGR
Re: Gas Mileage
Humor has a way of getting lost in translation, so we add
I knew you were JK We Cool
Old 01-19-2006, 07:28 AM   #12
Cool Re: Gas Mileage
I can see how using a larger diameter pipe after the muffler might make the exhaust note a bit louder and deeper (due to an echo effect), but can you explain how that could give you more torque?
In another year or so, I'll have to replace my pipes, and this time around I'd like to research a bit more carefully first! I did notice a slight increase in my mileage when I converted to duals, so taking the mufflers off completely probably would not decrease 00BlackStang's mileage. It might cause other problems, though!
Thanks,
Joe
1998 Laser Red V6 manual . . . Kenny Brown suspension, Eibach pro-kit springs, BBK CAI, JBA shorty headers, Magnaflow duals, GT fogs, Aluminum driveshaft, 3.27 gears, Tri-Ax shifter handle, misc UPR and MGW billet accessories, SS inserts, Redline Goods shift boot
1998Stang is offline   Reply With Quote
Old 01-20-2006, 06:08 PM   #13
RGR
Re: Gas Mileage
Thanks,
Joe
The actual configuration is a bigger diameter muffler and it looks like
same or slightly larger piping after the muffs... I'd go bigger, IMO.
The oversized muffler makes the engine "see" the exhaust system as
terminated, and this oversized setup is transparent or "invisible" to
the engine. Backpressure at the oversized muffler is non-existent
as compared to what the engine needs and tha is the torque boost
as far as I can figure it.
Bigger pipes after the muffs do add lower tones, to wit, the
MAC bolton kit with 3" dual tailpipes, the clips I heard were
VERY V8-like for a V6 system, and it was on a stock 3.8 too.
09:33 AM
