Water pump took a dump - Mustang Evolution
Old 01-12-2006, 07:10 PM   #1
KyleUSAF's Avatar
Send a message via AIM to KyleUSAF Send a message via MSN to KyleUSAF
I was driving when suddenly my water temp guage shot all the way up...so i put it in neutral and coasted to the side of the freeway. Opened the hood to find my radiator basically empty and the engine smoking from the heat. There was a reddish liquid sprayed over the front of the engine. I filled the radiator and overflow with water and got it to my house...
so now i need to swap out my water pump. Is there any advice you guys have for this? About how long would it take? Do you happen to know of a how-to?
Thanks everyone
oh, and: I'm not 100% sure it's my water pump..but that is what my grandfather says it probly is so..
ID:	11925   Click image for larger version
Originally Posted by Darkshadow
I could say nothing for my complete awe. He then. confidantly, purchased the gallon.
KyleUSAF is offline   Reply With Quote
Old 01-12-2006, 08:47 PM   #2
DarkShadow's Avatar
Send a message via AIM to DarkShadow
Re: Water pump took a dump
Should take about 2 hours. Water pumps for our cars are still pretty expensive for some reason tho.
DarkShadow is offline   Reply With Quote
Old 01-12-2006, 08:50 PM   #3
MarkuzLS1's Avatar
Send a message via AIM to MarkuzLS1
Did you check for blown hoses or gaskets?
I like turtles.
MarkuzLS1 is offline   Reply With Quote
Old 01-12-2006, 08:55 PM   #4
DarkShadow's Avatar
Actually, it does sound more like you have a leak somewhere, if your radiator was empty. I don't think that would have anything to do with pump...
Like he said above, check your hoses, and see if your radiator is leaking.
Old 01-13-2006, 03:43 PM   #5
check all hoses, redish liquid could be tranny fluid? not sure how it got on the motor... does it smell like tranny fluid?
it could be coolant if you used that orangy coolant stuff.
Old 01-14-2006, 07:39 AM   #6
Yeh, when he called me it sounded like he was talking about tranny fluid...but...it could be that colored coolant, didn't think about that.
Old 01-14-2006, 08:17 AM   #7
KyleUSAF's Avatar
the liquid was coolant for sure..so that's good
Old 01-14-2006, 03:09 PM   #8
feel free to call me with any questions you have, ill try to help.
Old 01-15-2006, 10:24 AM   #9
KyleUSAF's Avatar
^thanks
should i use silicon on both sides of the gasket?
Old 01-15-2006, 11:26 AM   #10
KyleUSAF's Avatar
gah!! does anyone know how to get the upper hose out that goes to the thermostat from the water pump...It's not really a hose, just like a metal pipe. I pull on it like mad and it won't come out. After i get this thing out i should be home free..please help
Old 01-15-2006, 12:00 PM   #11
KyleUSAF's Avatar
the black hose on top...it won't come out!
ID:	11935   Click image for larger version
Name:	water pump hose 2.JPG
Old 01-15-2006, 12:12 PM   #12
DarkShadow's Avatar
Those are very hard to get out, it's probably easier to get it off the engine first and then off the pump....
Old 01-15-2006, 01:16 PM   #13
KyleUSAF's Avatar
yea...it was off the engine.
but i finally got it with a chisel, lol.
this is quite a pita...scraping the old gasket off is horrid
i commend anyone who does this job in 2 hours
Old 01-15-2006, 05:32 PM   #14
KyleUSAF's Avatar
omfg...
1. One of the bolts that connects the water pump to the engine broke off..will it leak without it or am i alright to at least give it a try?
2. Do i need to wait 24 hours for the silicon to fully dry or can i test it after like 12 hours?
Thanks again all
Old 01-15-2006, 10:14 PM   #15
i would wait and i guess it depends on where the bolt is, i would try to get it out and replace it, you may can tap it out depending on how the break is.
Old 01-25-2006, 12:46 PM   #16
PCD
Region: Iowa
Go to Sears and get an easy out. Personally I don't like broken bolts anywhere on an engine.
PCD is offline   Reply With Quote
Old 01-25-2006, 01:35 PM   #17
KyleUSAF's Avatar
fix.t
Water Pump Bolts audi_b Pre-2005 V6 Mustang 3 08-30-2009 01:34 AM
Changing Water Pump wvstang5.0ho 1979-1995 Mustang GT 9 07-13-2008 09:45 PM
water pump ? jumpman1203 Pre-2005 V6 Mustang 0 10-16-2006 12:25 AM
Water Pump Going Bad? mydi777 Pre-2005 V6 Mustang 5 03-22-2005 08:52 PM
electric water pump? widowvirgin Pre-2005 V6 Mustang 15 07-01-2004 03:30 PM
11:16 AM
